path: root/recipes-bsp
2015-11-03Update Linux kernel and U-Boot to latest.Marcel Ziswiler
2015-10-30apalis/colibri_imx6/t30: u-boot-fw-utils: update fw_printenv/setenvMarcel Ziswiler
Introduce/update postinst code to dynamically adjust fw_env.config and fw_unlock_mmc.sh shell profile extension script to cope with our new unified eMMC layout: boot area partition 1 aka primary eMMC boot sector: with U-Boot boot loader and the U-Boot environment before the configblock at the end of that boot area partition
2015-10-30apalis/colibri_t20/t30: u-boot/fw-utils: introduce srcbranch notationMarcel Ziswiler
Introduce SRCBRANCH notation for easier switching to our -next branch.
2015-10-12Apalis iMX6: cleanup filename for V1.0 HWMax Krummenacher
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb in the kernel. The v1_0 denotes the Apalis module version, not the evaluation board version.
2015-08-13colibri-vf: update u-boot fw-utils to latestMax Krummenacher
2015-08-13colibri-vf: update u-boot to latestMax Krummenacher
2015-08-07u-boot-toradex_git: add virtual/bootloader to PROVIDESMax Krummenacher
2015-08-07u-boot: remove obsolete overridesMax Krummenacher
2015-08-07colibri-vf: use U-Boot recipe from meta-fsl-arm-extraMax Krummenacher
2015-08-07alsa-state: choose extended record volumeStefan Agner
The WM9715L AC97 codec supports two volume modes for audio capturing: basic (AC97 conform) and extended. The extended range allows smaller gain steps and a large range, hence use this mode by default.
2015-06-16base-files/u-boot-toradex-fw-utils: move MMC unlockStefan Agner
The mmc unlock function causes troubles when using Poky reference distribution since Poky uses the busybox shell: /etc/rc5.d/S09xserver-nodm: /etc/profile.d/fw_unlock_mmc.sh: line 2: syntax error: unexpected "(" This avoids X getting at all. This patch does not solve the underlying problem, but works around it by moving the script to the u-boot-toradex-fw-utils recipe, which is not installed by the Poky images by default.
2015-05-18Apalis/Colibri: update U-Boot to latestMax Krummenacher
And use 2015.04-toradex branch
2015-05-18Apalis/Colibri: update U-Boot to latest in -nextMax Krummenacher
2015-05-18Apalis iMX6 IT: u-boot: use the IT defconfig for ITMax Krummenacher
2015-05-12update to latest u-bootMax Krummenacher
2015-05-12update U-Boot and Colibri VFxx Linux to latest git revisionStefan Agner
2015-05-12update to latest u-bootMarcel Ziswiler
2015-05-12colibri_t20: fix fw_printenv/setenvMarcel Ziswiler
2015-05-12tegrarcm/cryptopp: build and use as a static libraryMax Krummenacher
We need libcryptopp only for a 32bit x86 target for tegrarcm. However linking libcryptopp dynamically and using the distro supplied 32bit compatibility libcryptopp raises an assertion: tegrarcm: secblock.h:145: CryptoPP::NullAllocator<T>::pointer CryptoPP::NullAllocator<T>::allocate(CryptoPP::NullAllocator<T>::size_type, const void*) [with T = unsigned int; CryptoPP::NullAllocator<T>::pointer = unsigned int*; CryptoPP::NullAllocator<T>::size_type = unsigned int]: Assertion `false' failed. Building only a static library with OE, (if native build forcing 32bit) fixes the issue.
2015-05-12u-boot: use latest from gitMax Krummenacher
While at it remove warning about stripped fw_printenv binary when building u-boot-toradex-fsl-fw-utils.
2015-05-12Apalis/Colibri iMX6: kernel/U-Boot update to latest in -nextMax Krummenacher
Also deploy an additional device tree supporting a Colibri iMX6 with Analog Camera Module.
2015-05-12colibri_vf: update to U-Boot 2015.04/Linux 4.0Stefan Agner
2015-05-12apalis/colibri_t20/t30: integrate latest stuffMarcel Ziswiler
2015-05-12u-boot-fw-utils: deploy fw_saveenv as symlinkMax Krummenacher
2015-05-12licenses: fix license string to known values or formatMax Krummenacher
2015-05-12u-boot-toradex-fsl-fw-utils: fix compileMax Krummenacher
cross strip tool not found without this patch.
2015-05-12recipes: replace short DESCRIPTION with SUMMARYMax Krummenacher
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY.
2015-05-12u-boot-fw-utils: fix compiler optionsMax Krummenacher
With dizzy we got compiler errors when compiling with the new 4.9 gcc.
2015-03-31u-boot-fw-utils: fix passing of compiler optionsMax Krummenacher
Without this the compiler tries to use a soft abi and stops with an error. fatal error: gnu/stubs-soft.h: No such file or directory # include <gnu/stubs-soft.h>
2015-02-03colibri-vf: update Linux kernel and U-Boot git hashesStefan Agner
Also update default defconfig for colibri-vf.
2015-02-02alsa-state: update Vybrid default ALSA stateStefan Agner
Update default ALSA state for WM9712 AC97 codec support on 3.18 kernel.
2015-01-09u-boot: build additional binary for Apalis iMX6Q 2GB ITMax Krummenacher
The IT variant needs different RAM timings
2014-12-19u-boot/u-boot-fw-utils: update all to latestMax Krummenacher
2014-12-19colibri_vf: update U-Boot and Linux kernel git hashesStefan Agner
Two last minute fixes: Default Product/Vendor ID for USB peripheral in U-Boot and fix for the USB peripheral RNDIS freeze.
2014-12-18Update all to latest and greatest U-Boot and Linux kernel.Marcel Ziswiler
2014-12-16colibri-vf: switch to mainline kernel based on 3.18Stefan Agner
Switch default kernel recipe to linux-toradex-vf which will build a kernel based on the toradex 3.18-next branch.
2014-12-11colibri-vf: update U-BootMax Krummenacher
2014-12-11apalis/colibri-imx6: U-Boot and Kernel for V1.0/V1.1Max Krummenacher
Update to a U-Boot and Kernel which can be used for Apalis iMX6 HW version V1.0 and V1.1. Also deploy additional device tree for Apalis iMX6 V1.0 modules
2014-11-13apalis/colibri_t30: fix fw_setenvMarcel Ziswiler
2014-11-13cbootimage/imx-loader/mtd-utils/tegrarcm: fix 32-bit build of our bsp/devtoolsMarcel Ziswiler
2014-10-31apalis/colibri_t30: introduce fw_printenv/setenvMarcel Ziswiler
2014-10-31tegrarcm: add include path to sysroot libcryptoppMax Krummenacher
The include path to libcryptopp is hardcoded to the buildhosts /usr/include/...
2014-10-31apalis/colibri_t30: fix noisy analogue audio playbackMarcel Ziswiler
Fix noisy analogue audio playback by updating initial ALSA state.
2014-10-30u-boot: iMX6/VF update to latest from gitMax Krummenacher
2014-10-30apalis/colibri_t30: latest u-boot git migrated to cbootimage/tegrarcmMarcel Ziswiler
Use latest U-Boot from git. Migrate to using cbootimage and tegrarcm.
2014-10-30Add tegrarcm recipeMarcel Ziswiler
2014-10-30Add cbootimage recipeMarcel Ziswiler
2014-10-20colibri-vf: u-boot: switch to 2014.10Stefan Agner
Use rebased U-Boot release 2014.10. The README has a new md5sum and U-Boots new build system has default configurations ending with defconfig too.
2014-10-06colibri-imx6: add machine specific config filesMax Krummenacher
2014-10-06colibri-imx6: refactor recipes for new moduleMax Krummenacher
