Disable LVDS output in favour of primary HDMI one on Apalis TK1.
Fix pkg_postrm by renaming from previous erroneous pkg_postremove and
remove /${bindir}/ which would need escaping.
And while at it replace Apalis-T30 in summary with Apalis T30 and get
rid of PR and empty do_compile.
Note: Currently only compiles -native but fails compiling for target!
The upgrade is required to match to the latest update scripts which
deploy the kernel and device tree into static UBI volumes.
This overrides the meta-fsl-arm provided settings from machconfig.
This allows building U-Boot supporting Toradex Colibri iMX7 modules.
Based on upstream Freescale/NXP 3.14.52_1.1.0_ga release which is based on 2015.04.
machine/u-boot/kernel files have been added to meta-fsl-arm-extra.
Use them from there now.
Change the name form u-boot-it.imx to u-boot.imx-it.
This prepares for the upcomming move of the i.MX 6 based modules BSP
Introduce/update postinst code to dynamically adjust fw_env.config and
fw_unlock_mmc.sh shell profile extension script to cope with our new
unified eMMC layout:
boot area partition 1 aka primary eMMC boot sector:
with U-Boot boot loader and the U-Boot environment before the
configblock at the end of that boot area partition
Introduce SRCBRANCH notation for easier switching to our -next branch.
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb
in the kernel.
The v1_0 denotes the Apalis module version, not the evaluation board version.
The WM9715L AC97 codec supports two volume modes for audio capturing:
basic (AC97 conform) and extended. The extended range allows smaller
gain steps and a large range, hence use this mode by default.
The mmc unlock function causes troubles when using Poky reference
distribution since Poky uses the busybox shell:
/etc/rc5.d/S09xserver-nodm: /etc/profile.d/fw_unlock_mmc.sh: line 2: syntax error: unexpected "("
This avoids X getting at all.
This patch does not solve the underlying problem, but works around it
by moving the script to the u-boot-toradex-fw-utils recipe, which is
not installed by the Poky images by default.
And use 2015.04-toradex branch
We need libcryptopp only for a 32bit x86 target for tegrarcm.
However linking libcryptopp dynamically and using the distro supplied 32bit
compatibility libcryptopp raises an assertion:
tegrarcm: secblock.h:145: CryptoPP::NullAllocator<T>::pointer CryptoPP::NullAllocator<T>::allocate(CryptoPP::NullAllocator<T>::size_type, const void*) [with T = unsigned int; CryptoPP::NullAllocator<T>::pointer = unsigned int*; CryptoPP::NullAllocator<T>::size_type = unsigned int]: Assertion `false' failed.
Building only a static library with OE, (if native build forcing 32bit)
fixes the issue.
While at it remove warning about stripped fw_printenv binary
when building u-boot-toradex-fsl-fw-utils.
Also deploy an additional device tree supporting a Colibri iMX6 with
Analog Camera Module.
cross strip tool not found without this patch.
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
With dizzy we got compiler errors when compiling with the new 4.9 gcc.
Without this the compiler tries to use a soft abi and stops with an error.
fatal error: gnu/stubs-soft.h: No such file or directory # include <gnu/stubs-soft.h>
Also update default defconfig for colibri-vf.
