These binaries can be used to flash the U-Boot via single
binary instead of few as it is done at the moment.
Related-to: ELB-5745
Signed-off-by: Andrejs Cainikovs <andrejs.cainikovs@toradex.com>
(cherry picked from commit ea58594ac5f4d0c1cf84d36068c785e6c4f5688f)
Bump SRCREV hashes as used in build of Mon 03 Jun 2024 05:23:08 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 616
Matrix Build Status: SUCCESS
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/616
Signed-off-by: ci.toradex <cicd@toradex.com>
(cherry picked from commit d001950d165b695ff0dc0f8aaae69663e4050de7)
Since meta-ti: 7b797da2ef43 ("ti-sci-fw: Drop k3-image-gen and only
provide firmware") the tiboot3-* binaries are assembled as part of
the U-Boot build process and no longer within ti-sci-fw.
Thus the bbappend is now obsolete, drop it.
(cherry picked from commit 6a7f8999ef3c7640f8ee3cf4afa59aa71b388c80)
UBOOT_CONFIG was changed to use 'sd' as one of the configs built for
the R5 SPL. However the same is already in use when building the
TEZI specific U-Boot for the Cortex A53 and is set from within the
TEZI distro.
Thus the two configuration clash and the build fails.
Change the config name to include the suffix '-r5' to have the two
seperate.
Fixes: 979d850 ("verdin-am62-k3r5: drop -gp from the u-boot config names")
(cherry picked from commit 6ad496b724d27fdd9d3227931fab34fa34d53f53)
We've seen builds were those made it into the final image instead of
the once from the regular U-Boot. This made such an image unbootable.
It is propbably caused by a race condition when the file and the
symlinks get deployed. Last symlink creator wins.
Related-to: ELB-5751
(cherry picked from commit 7b64c52cad283964691e6b1e0a1f1cea00bbc2d8)
meta-ti stopped removing the u-boot-initial-env files for the
main U-Boot machine. Thus remove the workaround which made the
files available again.
See commit e918d88c ("u-boot-ti: deploy initial-env for the main machine")
(cherry picked from commit 61bac0ad64aeda8bf4cd47c4085fc3a5c575638e)
Checking for the type rather than for the config name allows reuse
for other k3 based SoC.
Related-to: ELB-5482
(cherry picked from commit 27e16c96a7579bb70ef589dd6e38970577d4dbce)
Bump SRCREV hashes as used in build of Fri 26 Apr 2024 07:58:11 AM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 588
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/588
(cherry picked from commit 8bc578adfbe3d5a2a4e02b78a45f2e92532a7843)
To enhance compatibility with a read-only rootfs system, remove the
dynamically assigned and utilize alsa-ucm-conf configuration from
meta-toradex-bsp-common pulled-in via the meta-toradex-demos layer
instead.
Related-to: ELB-4916
Signed-off-by: Hiago De Franco <hiago.franco@toradex.com>
(cherry picked from commit d5d48dc1cc1ab54b3a498a0d5ea19646cab381ee)
Bump SRCREV hashes as used in build of Thu 28 Mar 2024 09:22:53 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 565
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/565
(cherry picked from commit 18b9c3cdefb6fa9236e025c6814ba0262ab61d17)
Bump SRCREV hashes as used in build of Sat 24 Feb 2024 12:44:07 AM UTC
Matrix Build: image-tezi-kirkstone-6.x.y-nightly-matrix 259
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-kirkstone-6.x.y-nightly-matrix/259
(cherry picked from commit 5235540df0edbff0d295520baf500324b0120a03)
Bump SRCREV hashes as used in build of Fri 26 Jan 2024 02:55:00 PM UTC
Matrix Build: image-tezi-kirkstone-6.x.y-nightly-matrix 234
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-kirkstone-6.x.y-nightly-matrix/234
(cherry picked from commit 6e8faeaf7c4b411b098a659bf467cda52b63c492)
Bump SRCREV hashes as used in build of Tue 26 Dec 2023 11:43:54 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 480
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/480
(cherry picked from commit e3713897eaa255112f543f39596350c6b0a2a383)
Bump SRCREV hashes as used in build of Mon 04 Dec 2023 09:24:44 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 462
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/462
(cherry picked from commit c4416ba464203669f7a3379b73ff87cd3b15b6f4)
Bump SRCREV hashes as used in build of Fri 20 Oct 2023 09:11:30 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 423
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/423
(cherry picked from commit 55e8a0ac45a54450ef1cc7c5d6c4e9d45d58bc56)
Bump SRCREV hashes as used in build of Wed 04 Oct 2023 11:08:30 AM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 405
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/405
(cherry picked from commit 704141cace404fcb84f0e5d86fc2658ef2225763)
Bump SRCREV hashes as used in build of Wed 30 Aug 2023 09:36:28 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 375
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/375
Bump SRCREV hashes as used in build of Wed 02 Aug 2023 09:09:58 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 350
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/350
With the move to use binman to create the tiboot3 binaries also handle
the case where we build tiboot3 for use over DFU.
I.e. deploy them with the '-dfu' suffix which we expect when assembling
the Toradex Easy Installer image.
Related-to: TEI-1100
- Update to the toradex_ti-u-boot-2023.04 branch, based on the
ti-u-boot-2023.04.
- This includes/requires the move to use binman to assemble the binaries
used for boot.
- With the change to binman the R5 SPL is now built from one OE machine
only, not one machine per SoC flavour (GP, HS-FS, HS).
- With binman we also change the name for the tiboot3* files to match
the machine they are built form, not claiming to be the evm.
E.g. tiboot3-am62x-hs-fs-verdin.bin.
- With the binman and HS-FS we need to package the kernel also as a
fitimage to prevent a build error in U-Boot, however we keep using
Image.gz
- Drop the '-staging' from the recipe name.
Related-to: ELB-5238
Bump SRCREV hashes as used in build of Fri 23 Jun 2023 10:48:08 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 319
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/319
Add HS-FS SoC type binaries (different SYSFW), GP SoC type is still
the default one and the one used in the generated tezi image,
HS-FS binaries are just deployed and not used yet.
tiboot3.bin renamed to tiboot3-gp.bin to make it clear that this is the
binary for the GP variant.
Related-to: ELB-5226
Signed-off-by: Emanuele Ghidoli <emanuele.ghidoli@toradex.com>
Drop this, it was used only for the initial layer creation.
Related-to: ELB-5190
Bump SRCREV hashes as used in build of Thu 01 Jun 2023 09:49:56 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 299
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/299
As we now have a working Toradex Easy Installer this bringup way
of flashing images is no longer needed.
Related-to: TEI-1066
meta-ti changed to additionally handle HS-FS and HS-SE devices, i.e. to
provide tiboot3 for the different flavours of the SoC.
They added a multiconfig for each of the flavours also renaming stuff
for the gp device we use.
Follow the change to have GP build again, but opt out of additionally
building tiboot3 for HS-FS and HS-SE devices.
meta-ti commit 12bb9e20 ("machine: Add AM62x HS-SE evm configuration")
commit 053002fb ("am62xx-evm: Add AM62x HS-FS evm configuration")
Related-to: ELB-5170
The upstream source now accepts an OE compiler from any distro, not just poky.
Use the same override for fileoverride and SRC_URI:override.
Otherwise a machine which sets the am62xx and tdx override would
want to fetch the files but not find them in any of the paths
searched.
Only install the files for Dahlia and Development Carrier Board
for a Verdin-AM62 so that other TI machines do not get their
configuration messed up.
Bump SRCREV hashes as used in build of Mon 24 Apr 2023 10:04:33 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 268
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/268
Add bbappend with verdin-am62 specific asound.conf and asound.state
files both for the Dahlia (no such device tree during bring-up as of
yet) and the Development board.
Fixes the following race:
| install: cannot stat '/workdir/oe/tmp-glibc/deploy/images/verdin-am62/tispl.bin': No such file or directory
| NOTE: recipe dfu-metadata-0.1-r0: task do_deploy: Failed
Bump SRCREV hashes as used in build of Tue 28 Feb 2023 10:05:55 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 214
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/214
This reverts commit 8fd4be106c2aafa754bb4228bd953635d78fec20.
With this we move to use timings for the Verdin AM62 DDR configuration.
Related-to: ELB-5045
This is to be reverted once we build for our Verdin AM62 module.
This adds scripts for installing a Verdin AM62 over DFU.
- PC loads tiboot-dfu over DFU and executes it
- tiboot initializes the RAM and goes to DFU
- PC loads tispl and u-boot.img over DFU and executes them
- u-boot boots to u-boot proper, detects DFU boot and goes to DFU
- PC loads tiboot, tispl, u-boot.img to eMMC boot area and resets DFU
- u-boot goes to UMS
- PC uses bmaptool to flash eMMC user area
- User resets the board
Change from building the U-Boot am62x-sdk target to verdin-am62.
Additionally build the R5 DFU SPL and deploy it.
Note the u-boot-initial-env no longer gets deleted due to the use of
UBOOT_CONFIG. Thus the deployment of u-boot-initial-env got simplified.
I.e. for specifing UBOOT_CONFIG and not UBOOT_MACHINE. This allows to
build the K3R5 SPL for normal boot and for DFU boot.
This requires to additonally build multiple tiboot.bin for each
version in the ti-sci-fw recipe.
Don't install u-boot-initial-env for the k3r5 spl build to prevent
the following bitbake error:
| ERROR: u-boot-toradex-ti-staging-1_2021.01+gitAUTOINC+f6f7a2258a-r0 do_deploy: The recipe u-boot-toradex-ti-staging is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
| .../deploy/images/verdin-am62/u-boot-initial-env
| (matched in manifest-verdin_am62_k3r5-u-boot-toradex-ti-staging.deploy)
Related-to: ELB-5012
This sets the needed variables for the image_type_tezi class to
create the tezi image.
Related-to: ELB-4978
