2015-05-12 | recipes: don't use ${PN} as a recipe name placeholder | Max Krummenacher | |
${PN} might be extended with some magic prefix, so don't use it in SRC_URI assignments et. al. | |||
2014-08-04 | bbappends: remove the deprecated PRINC variable | Max Krummenacher | |
2014-04-30 | xorg-xserver: fix comments in xorg.conf files | Marcel Ziswiler | |
Fix comments in xorg.conf files for the Tegras. | |||
2014-01-23 | xorg-xserver: add entry for fusion touchscreen driver | Stefan Agner | |
2014-01-23 | xorg-xserver: extended default xorg.conf | Stefan Agner | |
Add sections for both monitor outputs, add example configuration to disable an output as well as select prefered mode. | |||
2013-11-21 | Machine: use the changed machinename colibri-vf | Max Krummenacher | |
2013-10-10 | colibri-vf50: add the machine, kernel and u-boot | Max Krummenacher | |
- also add the relevant configuration files | |||
2013-10-09 | xserver: remove bbappend for version 1.11.2 | Max Krummenacher | |
2013-08-26 | xserver: move all xserver stuff in the same directoryT30_LinuxImageV2.0Beta3_20130820Apalis_T30_LinuxImageV2.0Beta2_20130816 | Max Krummenacher | |
2013-03-04 | remove unused files | Max Krummenacher | |
2013-03-04 | xorg.conf: Apalis & Colibri T30: use 16bpp framebuffer | Max Krummenacher | |
- 32bpp framebuffers use a lot of memorybandwidth, 16bpp is a better default | |||
2013-01-29 | xorg.conf: add Apalis-T30 | Max Krummenacher | |
2012-10-18 | xserver hack no longer needed with R16 | Max Krummenacher | |
2012-08-27 | nautilus depends on gobject-introspection-nativeT20_LinuxImageV2.0Alpha1_20120808 | Max Krummenacher | |
libpcre splits into libpcre-*, use packages-dynamic so we can put them into an image rename bbappend because coresponding bb does not exist | |||
2012-08-15 | L4T R15, oe-core Image V2.0Beta1 | Max Krummenacher | |
2012-06-03 | Initial commit | Max Krummenacher | |
