2015-11-03 | Update Linux kernel and U-Boot to latest. | Marcel Ziswiler | |
2015-10-30 | apalis/colibri_imx6/t30: u-boot-fw-utils: update fw_printenv/setenv | Marcel Ziswiler | |
Introduce/update postinst code to dynamically adjust fw_env.config and fw_unlock_mmc.sh shell profile extension script to cope with our new unified eMMC layout: boot area partition 1 aka primary eMMC boot sector: with U-Boot boot loader and the U-Boot environment before the configblock at the end of that boot area partition | |||
2015-08-13 | colibri-vf: update u-boot fw-utils to latest | Max Krummenacher | |
2015-05-18 | Apalis/Colibri: update U-Boot to latest | Max Krummenacher | |
And use 2015.04-toradex branch | |||
2015-05-18 | Apalis/Colibri: update U-Boot to latest in -next | Max Krummenacher | |
2015-05-12 | update to latest u-boot | Max Krummenacher | |
2015-05-12 | update U-Boot and Colibri VFxx Linux to latest git revision | Stefan Agner | |
2015-05-12 | update to latest u-boot | Marcel Ziswiler | |
2015-05-12 | u-boot: use latest from git | Max Krummenacher | |
While at it remove warning about stripped fw_printenv binary when building u-boot-toradex-fsl-fw-utils. | |||
2015-05-12 | Apalis/Colibri iMX6: kernel/U-Boot update to latest in -next | Max Krummenacher | |
Also deploy an additional device tree supporting a Colibri iMX6 with Analog Camera Module. | |||
2015-05-12 | u-boot-toradex-fsl-fw-utils: fix compile | Max Krummenacher | |
cross strip tool not found without this patch. | |||
2015-05-12 | recipes: replace short DESCRIPTION with SUMMARY | Max Krummenacher | |
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY. | |||
2015-05-12 | u-boot-fw-utils: fix compiler options | Max Krummenacher | |
With dizzy we got compiler errors when compiling with the new 4.9 gcc. | |||
2015-02-03 | colibri-vf: update Linux kernel and U-Boot git hashes | Stefan Agner | |
Also update default defconfig for colibri-vf. | |||
2014-12-19 | u-boot/u-boot-fw-utils: update all to latest | Max Krummenacher | |
2014-10-30 | u-boot: iMX6/VF update to latest from git | Max Krummenacher | |
2014-10-20 | colibri-vf: u-boot: switch to 2014.10 | Stefan Agner | |
Use rebased U-Boot release 2014.10. The README has a new md5sum and U-Boots new build system has default configurations ending with defconfig too. | |||
2014-08-04 | u-boot: update to latest git version | Max Krummenacher | |
2014-08-04 | u-boot-toradex: update to latest git version | Max Krummenacher | |
2014-08-04 | u-boot-fw-utils: add config für colibri-vf and apalis-imx6 | Max Krummenacher | |
2014-04-05 | u-boot-fw-utils: provide matching recipes | Max Krummenacher | |
With the change to our own u-boot recipes the bbappend to the common u-boot-fw-utils recipe is no longer a sane solution. While at it cleanup COMPATIBLE_MACHINE style. |
