Since OE-Core commit 9379f80f48 ("license/insane: Show warning for
obsolete license usage"), LICENSE field not containing SPDX identifiers
are treated with WARNING.
An automated conversion using scripts/contrib/convert-spdx-licenses.py to
convert to use the standard SPDX license identifiers has been done on
the entire layer.
Github no longer allows a plain git protocol. https://github.blog/2021-09-01-improving-git-protocol-security-github/#no-more-unauthenticated-git
OE is dropping setting the branch to master implicitly if none is specified.
(cherry picked from commit 657a1121250d5e55b435f2f26ef45e29ab832590)
This is the result of automated script (0.9.3) conversion:
+# meta-toradex-distro
+vars = vars + ["preempt-rt","tdx","upstream"]
+# meta-toradex-* machines
+vars = vars + ["apalis-","colibri-","verdin-","tegra124"]
+# meta-freescale
+vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"]
../openembedded-core/scripts/contrib/convert-overrides.py .
converting the metadata to use ":" as the override character instead of "_".
Remove comment which was obsoleted by commit
b34fa66b4159cb6b0952a6821e73fdb93ae7714f
Enforcing to build 32-bit binaries for native and portions thereof
using -m32 in EXTRA_OEMAKE_class-native may lead to building errors.
Also, it seems it's time to move on from 32-bit compatibility.
Affected repositories:
meta-toradex-demos
meta-toradex-nxp
meta-toradex-tegra
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
