path: root/recipes-bsp/cbootimage
2022-03-06layer: Update LICENSE variable to use SPDX license identifiersMax Krummenacher
Since OE-Core commit 9379f80f48 ("license/insane: Show warning for obsolete license usage"), LICENSE field not containing SPDX identifiers are treated with WARNING. An automated conversion using scripts/contrib/convert-spdx-licenses.py to convert to use the standard SPDX license identifiers has been done on the entire layer. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2021-12-02github: use https protocol and set branch explicitlyMax Krummenacher
Github no longer allows a plain git protocol. https://github.blog/2021-09-01-improving-git-protocol-security-github/#no-more-unauthenticated-git OE is dropping setting the branch to master implicitly if none is specified. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 657a1121250d5e55b435f2f26ef45e29ab832590)
2021-08-14layer: convert to new override syntaxMax Krummenacher
This is the result of automated script (0.9.3) conversion: +# meta-toradex-distro +vars = vars + ["preempt-rt","tdx","upstream"] +# meta-toradex-* machines +vars = vars + ["apalis-","colibri-","verdin-","tegra124"] +# meta-freescale +vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"] ../openembedded-core/scripts/contrib/convert-overrides.py . converting the metadata to use ":" as the override character instead of "_". Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-06native-tools: remove comment about 32-bit host binariesMax Krummenacher
Remove comment which was obsoleted by commit b34fa66b4159cb6b0952a6821e73fdb93ae7714f Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-07-23recipes: get rid of the 32-bit host binariesGerard Salvatella
Enforcing to build 32-bit binaries for native and portions thereof using -m32 in EXTRA_OEMAKE_class-native may lead to building errors. Also, it seems it's time to move on from 32-bit compatibility. Affected repositories: meta-toradex-demos meta-toradex-nxp meta-toradex-tegra Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-07meta-toradex-tegra: cleanup whitespace useMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30cbootimage: update to latest 1.7Marcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2014-11-13cbootimage/imx-loader/mtd-utils/tegrarcm: fix 32-bit build of our bsp/devtoolsMarcel Ziswiler
2014-10-30Add cbootimage recipeMarcel Ziswiler
