2024-05-07 | qedit: remove x11 only tool | Max Krummenacher | |
Remove the recipe. Related-to: ELB-5740 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2022-03-06 | layer: Update LICENSE variable to use SPDX license identifiers | Max Krummenacher | |
Since OE-Core commit 9379f80f48 ("license/insane: Show warning for obsolete license usage"), LICENSE field not containing SPDX identifiers are treated with WARNING. An automated conversion using scripts/contrib/convert-spdx-licenses.py to convert to use the standard SPDX license identifiers has been done on the entire layer. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2021-08-14 | layer: convert to new override syntax | Max Krummenacher | |
This is the result of automated script (0.9.3) conversion: +# meta-toradex-distro +vars = vars + ["preempt-rt","tdx","upstream"] +# meta-toradex-* machines +vars = vars + ["apalis-","colibri-","verdin-","tegra124"] +# meta-freescale +vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"] ../openembedded-core/scripts/contrib/convert-overrides.py . converting the metadata to use ":" as the override character instead of "_". Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2020-01-09 | qt5: do not require meta-qt5 | Max Krummenacher | |
Move all qt5 relevant stuff where it only gets parsed if meta-qt5 is available. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> |
