Remove the recipe.
Related-to: ELB-5740
Our X11 distros are unmaintained for a while now. Likely built images
will not run if they even build. Drop them for BSP 7.
Remove them to not create unmet expectation.
For non NXP SoC we do not want the NXP specific use-mainline-bsp override
but rather use directly the override comming from the upstream distro.
Related-to: ELB-5331
The fix-fullscreen-mode.patch is formated incorrectly. This leads to a
build failure. This patch fixes it.
Related-to: ELB-4884
Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
(cherry picked from commit 842174e46db477167f44870160edadb46c7a3468)
When there is no screen attached the Qt application fails to start.
The message when the application crashes is:
xdg_wm_base@17: error 4: xdg_surface geometry (500 x 500) is larger than the configured fullscreen state (0 x 0)
The Wayland connection experienced a fatal error: Protocol error
This leads to a kernel messages each time the application tries to
start. With BSP5 the application just tries to restart every time the
applications exits but doesn't spam the kernel log. The reason
why this changed is this new feature:
https://code.qt.io/cgit/qt/qtwayland.git/commit/?h=5.15&id=d58008c4310f99d0faebcfb2fd9aa9296b813ecf
The change of this commit fixes the application so that it properly
works with no screen attached and doesn't crash at all.
(cherry picked from commit 2ca50c7c93e69cd02028ec5a204b84632d996703)
Since OE-Core commit 9379f80f48 ("license/insane: Show warning for
obsolete license usage"), LICENSE field not containing SPDX identifiers
are treated with WARNING.
An automated conversion using scripts/contrib/convert-spdx-licenses.py to
convert to use the standard SPDX license identifiers has been done on
the entire layer.
This is the result of automated script (0.9.3) conversion:
+# meta-toradex-distro
+vars = vars + ["preempt-rt","tdx","upstream"]
+# meta-toradex-* machines
+vars = vars + ["apalis-","colibri-","verdin-","tegra124"]
+# meta-freescale
+vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"]
../openembedded-core/scripts/contrib/convert-overrides.py .
converting the metadata to use ":" as the override character instead of "_".
Related-to: ELB-2838
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit 72adf20fd19877f245c523b65da8a923b64f6492)
Move all qt5 relevant stuff where it only gets parsed if meta-qt5 is
available.
As several customers reported qtcreator imports that python module when debugging.
https://www.toradex.com/community/questions/11201/qt-creator-debugging-python-issue-colibri-imx7d.html
