They are unmaintained for a while now. Likely built images will not run
if they even build. Drop them for BSP 7.
Remove them to not create unmet expectation.
Related-to: ELB-5740
Current master and scarthgap-7.x.y updated systemd recipe to version
255.1. The recipe now prints
WARNING: systemd-1_255.1-r0
do_install: Using /home/root as root user's home directory is not fully
supported by systemd
Therefore, use /root instead of /home/root as $ROOT_HOME to fix this
warning.
Related-to: ELB-5646
Signed-off-by: Hiago De Franco <hiago.franco@toradex.com>
The upstream kernels were renamed. Follow the rename.
U-Boot was split into a pinned denx + our patches and a latest denx
version. Thus no uprev is needed for U-Boot.
Related-to: ELB-5617
Add meta-tpm layer to bblayers for the TPM software stack.
Related-to: ELB-5500
Signed-off-by: Joao Paulo Goncalves <joao.goncalves@toradex.com>
(cherry picked from commit 946425761f7aa044dd3721c0ef604490814be1aa)
openembedded-core commit 941ba1a132 ("kernel-fitImage: Strip path
component from dtb") changed to remove the vendor path components
from fitimage nodes by default. This would require to change our
bootscripts.
Set the variable 'KERNEL_DTBVENDORED' to get the old behaviour back.
Related-to: TEI-1143
Assert that for both machines, verdin-am62 and verdin-am62-k3r5,
the downstream distro is set.
With adding the mainlinish U-Boot to the machine configuration that
now matters if use-head-next is set.
Without the change a bitbake build failure is seen when building
the SPL for verdin-am62-k3r5:
| Can't find default configuration "arch/../configs/verdin-am62_r5_defconfig"!
Reported-by: Emanuele Ghidoli <emanuele.ghidoli@toradex.com>
(cherry picked from commit 8363ba48d2c3207a97974aec662b373692310b08)
Follow the changed imx-sc-firmware-toradex version to
imx-sc-firmware-toradex_1.14.0.bb.
Related-to: ELB-5054
(cherry picked from commit 9480d591b81316ce0e828f37bed74329de2a5d81)
Commit 97905d6 ("local.conf skeleton: fix build with common deploy
directory") fixed build failures due to multiconfig builds and
changes in what fails may be deployed from multiple recipes.
Integrating that in to CI/CD proofed difficult as there we have to
override DEPLOY_DIR to preserve artifacts into different location.
Improve the fix to have it easier to integrate it into CI/CD.
openembedded-core tightend the rules on what files are allowed to be
deployed into the deploy directory from two (or more) recipes.
As a result builds now fail for Verdin AM62, as both the default and
the k3r5 config deploy license files into the same directory with the
same name. This has been seen on with ‘native’ recipes.
| ERROR: mc:k3r5:python3-rfc3987-native-1.3.8-r0 do_populate_lic_setscene: Recipe python3-rfc3987-native is trying to install files into a shared area when those files already exist. The files and the manifests listing them are:
| .../tmp-glibc/deploy/licenses/x86_64/python3-rfc3987-native/PKG-INFO
| (not matched to any task)
Related-to: ELB-5485
The meta-ti commit: ("4dcc70a8 conf: switch k3r5 multiconfig to
baremetal") places the deploy directory outside of the tmp directory,
something we already do.
Keep our "${TOPDIR}/deploy" rather than moving to "${TOPDIR}/deploy-ti".
(cherry picked from commit 67d25b69c15c8b14ef54c6be0ea27039b69a06b7)
Follow the changed linux-toradex version to linux-toradex_5.15-2.2.x.bb.
Related-to: ELB-5185
Signed-off-by: Emanuele Ghidoli <emanuele.ghidoli@toradex.com>
(cherry picked from commit 1447911e2b5212f3eaf13c657629d19fd5977221)
On Verdin AM62 SERIAL_CONSOLES is set to multiple ttys. In the old
setup this spawned a getty on each of them.
Using systemd's serial-getty-generator this behaviour is changed to
only spawn a getty on the ttys which are also present in /proc/consoles.
Other entries in SERIAL_CONSOLES are left alone and are free for
generic use.
Related-to: ELB-5346
(cherry picked from commit 491e249099a36c2eb7f8c0192f100265c1eae0b1)
The systemd recipe now requires this.
From https://docs.yoctoproject.org/ref-manual/features.html?highlight=usrmerge
usrmerge: Merges the /bin, /sbin, /lib, and /lib64 directories into
their respective counterparts in the /usr directory to provide better
package and application compatibility.
Related-to: ELB-5339
This has been there forever without anyone speaking up. Seems
the used features weren't that bad.
Remove the '-staging'.
Related-to: ELB-5238
(cherry picked from commit 555fbd08693c0687176c80fca0d2411dc1df6ded)
U-Boot and Linux in meta-toradex-ti have been updated, reflected in
the recipe name.
Modified the uprev-srcrev script to the new file paths.
(cherry picked from commit aa050275ab9bca764854f6fcf80b9baa1b23be39)
local.conf: Add verdin-am62 MACHINE and set its default DISTRO to
tdx-wayland (downstream).
Related-to: ELB-5064
(cherry picked from commit 50942e30e5d81e3894fd4db3d8b79e2cb53d2a9b)
Related-to: ELB-5127
(cherry picked from commit fda3e56a06f7d3cef7f73b174bb68c4f1074c26e)
Related-to: ELB-5018
(cherry picked from commit fc76e870b03b4920790560eeafd268af36f4d1e9)
Add U-Boot and Linux kernel for the TI SoC based modules to the
uprev script.
ELB-5012
(cherry picked from commit f6525a402462a51ec65fd854f886e7fbaeb9f72c)
Related-to: ELB-5012
(cherry picked from commit 3d14036d65d944186dfc05c284bf9835ac881a23)
bblayers.conf: Split the NXP specific layers into a variable and
add the layers used to build for TI SoCs into its own variable.
Note the the layers required to build for TI SoCs are not yet
added to the list of active layers.
local.conf: Rework the setting of DISTRO, so that the downstream
distro is only applied for NXP i.MX8 based SoC.
Related-to: ELB-4978
(cherry picked from commit b72f11c9adf0b35e4016e7b9e58fc8c86d37f0e8)
(cherry picked from commit 6961869d7d4fbeada96d68a978076246941363ba)
In the OE master builds we want to fetch latest upstream U-Boot with
possible additional patches from our OE meta data.
So enable the uprev of the upstream U-Boot recipe.
(For release OE meta data we want a fixed upstream version, independent
on the use of 'use-head-next' overrides)
Related-to: ELB-4640
Related-to: ELB-4593
(cherry picked from commit 2712e46aadd2ec74711d69503b61dba3548e0aa4)
Follow the changed linux-toradex version to linux-toradex_5.15-2.1.x.bb.
Related-to: ELB-4873
(cherry picked from commit cd3e7aed7069637d462170a8a98313cc76a01ae0)
Toradex Modules based on i.MX 6/6ULL/7 are only supported with the
tdx-xwayland-upstream DISTRO, select it as default in local.conf.
Related-to: ELB-4716
(cherry picked from commit 382211f6e51a72996831949002c8c418f0f55636)
plus squashed
(cherry picked from commit 373359bb690ec623b1a167f30c10a9d398c9704a)
Releated-to: ELB-4868
(cherry picked from commit bc8579961cd541b16721c67cf0b48009a73e10da)
Since openembedded-core commit c88304a78e ("arch-armv7a.inc: default to
Thumb2 instruction set for armv7a and above") a build of an armv7a
based machine defaults to the Thumb2 instruction set. So repeating this
default setting in the distro is not needed and can be completely
removed.
The way Thumb2 is set in the distro is wrong in the first place and
would need fixing anyway.
By setting `ARM_INSTRUCTION_SET:override ??= "..."` this will take
precedence over any assignment to ARM_INSTRUCTION_SET without a
override. So any recipe which wants to force the 'ARM' instruction set
will end up being compiled with Thumb2.
(cherry picked from commit a0c78e246961778a5ea420af82a257cbf962bbed)
Add comments to point out which DISTRO is compatible/recommended for
which Toradex module.
Related-to: ELB-4544
(cherry picked from commit 4274075ff69800e1cede8f593ea89a081c1c263c)
Since commit dcf889e93401f7c4de0055d53271eacc3882eccc in OE:
meta: Remove remnants of bluez4 support
bluez4 was removed from meta-oe 2 years ago.
Simplfy the setup of the two level bluetooth and bluez4/bluez5
distro features by removing the bluez4/bluez5 distro features.
This also removes the no longer required bluetooth class.
Signed-off-by: Richard Purdie <richard.purdie@linuxfoundation.org>
bluez5 is no longer a distro feature, and there is no reference to it
neither in Toradex/Freescale/OE meta layers, let's drop it.
Related-to: ELB-4824
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit bdb31caa6c2a6a96112f536c76d4e1eca8da3ea4)
All i.MX8 series family members support the tune armv8a-crypto. Use that
unified instead of building each family with its own specific tune.
As used in the downstream NXP BSP LLF5.15.32_2.0.0.
Related-to: ELB-4665
(cherry picked from commit 095032507d6560ff6bb916982732a2190019b97f)
toradex-fitimage.bbclass has been dropped from meta-toradex-bsp-common
layer, let's drop its reference here, use kernel-fitimage instead.
Related-to: ELB-4700
(cherry picked from commit 08dc5aa49fedffb76f4cdcb80d97cdc2b483418f)
We dont need any recipes from meta-initramfs, drop it from
bblayers.conf.
We've decided not to support Tegra machines since BSP6, let's drop
their references.
Related-to: ELB-4471
Related-to: ELB-4597
It's an invalid variable, there is not a bitbake instance for
u-boot-default-env.
Related-to: ELB-4536
Signed-off-by: Andrejs Cainikovs <andrejs.cainikovs@toradex.com>
Related-to: ELB-4581
The uprev-srcrev tool currently crashes with some python backtraces.
This is caused by changes in the bitbake fetcher code.
See bitbake, commit 4b5eed16 ("fetch2/cooker: Fix source revision
handling with floating upstreams")
Workaround it by calling bb.fetch2.get_srcrev() if AUTOINC is not
in PV. For makes all recipes we currently uprev succeed.
Related-to: ELB-4590
U-Boot changed to the mainline u-boot recipe, but our bbappend can't
be handled by this script, add a note.
The mainline kernel recipe name changed.
TK1 no longer supported.
Backports of kernel drivers no longer used.
Related-to: ELB-4476
NXP's gstreamer fork is updated to 1.18.5.imx.
This follows variable renames and thus
changes the layer's compatibility to only kirkstone.
Follow meta-freescale commit 30f5ce1d ("Generalize overrides subsystem for
NXP and Mainline support").
TEZI_SHOW_EULA_LICENSE shall be a machine global variable but not image
specific, move it to tdx-base.inc in meta-toradex-distro layer.
Torizoncore/Tezi/BSP now use the same setting of
TEZI_SHOW_EULA_LICENSE.
Related-to: TOR-2102
(cherry picked from commit a991a45459b7f3c0870ef94da6e48c279eaa97f0)
