OE master (styhead) no longer unpacks in ${WORKDIR} but rather does
it in path defined by the new variable UNPACKDIR.
Additionally '${S} = ${WORKDIR}' is no longer allowed and results in
a parse time error.
Cope with the change so that the layer builds against scarthgap and
styhead.
While at it set the pointers to the documentation in the README to
latest developer website.
OE master will soon require setting a branch, i.e. no longer defaulting
to master. Prepare for that.
| WARNING: clpeak-git-r0 do_fetch: URL: git://github.com/krrishnarraj/clpeak.git;protocol=https does not set any branch parameter. The future default branch used by tools and repositories is uncertain and we will therefore soon require this is set in all git urls.
This is the result of automated script (0.9.3) conversion:
+# meta-toradex-distro
+vars = vars + ["preempt-rt","tdx","upstream"]
+# meta-toradex-* machines
+vars = vars + ["apalis-","colibri-","verdin-","tegra124"]
+# meta-freescale
+vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"]
../openembedded-core/scripts/contrib/convert-overrides.py .
converting the metadata to use ":" as the override character instead of "_".
This reduces the binary from 400 to 4k.
(cherry picked from commit 832e3954f29df6ce1f5cc385ebefa2ef7f27ebd0)
(cherry picked from commit 2bba608252c7c09447e94bbacf8b1310113b12ff)
