To avoid code duplication call fwd_blk from fwd_mmc. This adds
one more indirection, but since flash_mmc.img is a compatibility
script anyway it is not the common case...
Source the update script only if loading succeeded. This avoids
loops if board_name is not set. Also add a test if board_name is
really set since this variable is/was not available in older
U-Boots.
With update.sh one creates files on e.g. a SD-card or a tftp server
which enables updating the SW on a module from U-Boot running on
said module.
This commit adds a module type specific directory on that output media
so that update data for multiple module types can be stored on one media.
Generic U-Boot scripts in the media's root directory do select the
matching update data depending on module type.
