The resize command confuses Eclipse's launcher.
On a ssh console resize isn't needed anyway so only start it if
the console device starts with /dev/tty to work around the issue.
The mmc unlock function causes troubles when using Poky reference
distribution since Poky uses the busybox shell:
/etc/rc5.d/S09xserver-nodm: /etc/profile.d/fw_unlock_mmc.sh: line 2: syntax error: unexpected "("
This avoids X getting at all.
This patch does not solve the underlying problem, but works around it
by moving the script to the u-boot-toradex-fw-utils recipe, which is
not installed by the Poky images by default.
Use the resize command to set the size of the terminal once upon
login. This is useful for serial console, where the default Unix
signal which takes care of resizing the console (SIGWINCH) is not
available.
There are no more differences in fstab between machines, hence use
the same common file. The default profile has some differences,
however we can seperate them out and create a file which will be
installed in profile.d.
missing
${PN} might be extended with some magic prefix, so don't use it in SRC_URI
assignments et. al.
follow openembedded-core commit c509f948d9c575c45af8c5ed1cb1692c0ca5dade
systemd does not recognize "rootfs" in /etc/fstab so the root
filesystem is not checked. As a result, the following message
is logged by journalctl:
systemd-fstab-generator[68]: Checking was requested for "rootfs", but it
is not a device
Changing "rootfs" to "/dev/root" in /etc/fstab allows systemd to
check the root filesystem when the kernel is booted with the root
filesystem mounted read-only.
- also add the relevant configuration files
