path: root/recipes-support/libcryptopp
2015-05-12tegrarcm/cryptopp: build and use as a static libraryMax Krummenacher
We need libcryptopp only for a 32bit x86 target for tegrarcm. However linking libcryptopp dynamically and using the distro supplied 32bit compatibility libcryptopp raises an assertion: tegrarcm: secblock.h:145: CryptoPP::NullAllocator<T>::pointer CryptoPP::NullAllocator<T>::allocate(CryptoPP::NullAllocator<T>::size_type, const void*) [with T = unsigned int; CryptoPP::NullAllocator<T>::pointer = unsigned int*; CryptoPP::NullAllocator<T>::size_type = unsigned int]: Assertion `false' failed. Building only a static library with OE, (if native build forcing 32bit) fixes the issue.
2015-05-12recipes: replace short DESCRIPTION with SUMMARYMax Krummenacher
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY.
2015-03-31libcryptopp: use autotools-brokensepMax Krummenacher
While at it unpack sources in standard S directory
2014-10-31libcryptopp: package/stage to correct pathsMax Krummenacher
The native build needs PREFIX to stage the files correctly into x86 sysroot The target build did not deploy the shared object due to missing soname version symlinks
2014-10-30Add libcryptopp recipeMarcel Ziswiler
