2015-08-07 | icu: upgrade reduced icu data to version 54 | Max Krummenacher | |
2015-05-12 | icu: upgrade reduced icu data to version 53 | Max Krummenacher | |
While at it move version to % placeholder and use wildcards in receipe icu: use wildcard to be independent of version | |||
2014-08-04 | bbappends: remove the deprecated PRINC variable | Max Krummenacher | |
2014-04-30 | icu: add break iterator support for webkitgtk | Stefan Agner | |
Webkitgtk needs break iterator support in order to work. This avoids segmentation fault when using Midori web browser. | |||
2014-04-04 | icu: update to match bb version | Max Krummenacher | |
2014-03-31 | icu: is machine specific for colibri-vf | Max Krummenacher | |
For colibri-vf we deploy icu only partly to save diskspace, so set the PACKAGE_ARCH for that machine. | |||
2013-11-21 | Machine: use the changed machinename colibri-vf | Max Krummenacher | |
2013-10-16 | icu: fix SRC_URI | Max Krummenacher | |
2013-10-11 | icu: replace database with minimzed version | Max Krummenacher | |
