2015-05-12 | recipes: don't use ${PN} as a recipe name placeholder | Max Krummenacher | |
${PN} might be extended with some magic prefix, so don't use it in SRC_URI assignments et. al. | |||
2015-05-12 | lxde-common: use generic panel-buttons.patch | Max Krummenacher | |
There is no difference between iMX6 / Tegra based modules | |||
2015-05-12 | lxde-common: remove screenlock from panel | Max Krummenacher | |
2015-05-12 | lxde-common: move version to % placeholder | Max Krummenacher | |
remove consistent_defconfig_dirs.patch as it is no longer needed starting with 0.5.6 consistent_defconfig_dirs.patch is no longer needed. change bbappend to contain % instead of the version | |||
2014-11-13 | apalis/colibri_imx6: fix wallpaper | Marcel Ziswiler | |
2014-10-24 | colibri_vf: detect module type on dt kernels | Stefan Agner | |
Detect the module type using the compatible property of the device tree to symlink the module specific background image. | |||
2014-10-06 | lxde-common_0.5.5: add Colibri iMX6 specific wallpapers | Max Krummenacher | |
2014-08-04 | bbappends: remove the deprecated PRINC variable | Max Krummenacher | |
2014-05-28 | lxde-common: remove obsolete commands in autostart | Max Krummenacher | |
- remove workarounds for hdmiaudio and xrandr which are no longer needed. - while at it fix some whitespace issues | |||
2014-04-01 | lxde-common_0.5.5: add iMX6 specific wallpapers | Max Krummenacher | |
2013-11-21 | lxde-common: choose wallpaper for colibri-vf at runtime | Max Krummenacher | |
2013-10-17 | lxpanel: add module dependent browser to launch bar | Max Krummenacher | |
For tegra use firefox, for vybrid midori | |||
2013-10-10 | colibri-vf50: add the machine, kernel and u-boot | Max Krummenacher | |
- also add the relevant configuration files | |||
2013-03-20 | Wallpaper: correct new CI colors | Max Krummenacher | |
2013-03-04 | lxde-common: wallpapers are MACHINE_ARCH dependent | Max Krummenacher | |
2013-01-29 | wallpaper, change to new Toradex CI | Max Krummenacher | |
2013-01-29 | wallpaper, added Apalis-T30 | Max Krummenacher | |
2013-01-23 | wallpaper: renamed in preparation of upcomming Apalis | Max Krummenacher | |
2012-08-15 | L4T R15, oe-core Image V2.0Beta1 | Max Krummenacher | |
2012-07-17 | append our V1.1 lxde specialities to the oe-tworaz recipes | Max Krummenacher | |
