2015-11-24 | colibri_vf: updated defconfig enables RTL8192CU driver | Stefan Agner | |
Enable RTL8192CU driver to support LM006 USB WiFi adapter. | |||
2015-11-06 | Update Tegra Linux kernel to latest.Colibri_iMX6_LinuxImageV2.5Beta2_20151106Colibri_VF_LinuxImageV2.5Beta2_20151106Colibri_T30_LinuxImageV2.5Beta2_20151106Colibri_T20_LinuxImageV2.5Beta2_20151106Apalis_iMX6_LinuxImageV2.5Beta2_20151106Apalis_T30_LinuxImageV2.5Beta2_20151106 | Marcel Ziswiler | |
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2015-11-04 | Apalis/Colibri iMX6: Update Linux kernel to latest | Max Krummenacher | |
2015-11-04 | linux: fix B != S | Marcel Ziswiler | |
2015-11-04 | apalis/colibri_imx6/t20/t30: add version/git hash to Kernel | Stefan Agner | |
Add LOCALVERSION and generate a scmversion file to annotate the Kernel with the Toradex release and a git hash. | |||
2015-11-04 | apalis/colibri_imx6: update/load USB Gadget ConfigFS automatically | Stefan Agner | |
Since we use USB Gadget ConfigFS now use libusbg to load the USB Gadget configuration automatically. | |||
2015-11-03 | Update Linux kernel and U-Boot to latest. | Marcel Ziswiler | |
2015-10-21 | colibri_vf: update/load USB Gadget ConfigFS automatically | Stefan Agner | |
Update defconfig and kernel version to latest version from git. This also configures the USB Gadget ConfigFS as a module. Add the ConfigFS module to the list of autoloaded modules. | |||
2015-10-12 | Apalis iMX6: cleanup filename for V1.0 HW | Max Krummenacher | |
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb in the kernel. The v1_0 denotes the Apalis module version, not the evaluation board version. | |||
2015-10-12 | apalis-imx6: update kernel to toradex_imx_3.14.28_1.0.0_ga-next | Max Krummenacher | |
2015-08-13 | colibri-vf: initial kernel based on upstream 4.1 | Max Krummenacher | |
2015-08-07 | kernel: adapt to oe's new shared work dir | Max Krummenacher | |
2015-08-07 | colibri-vf: moved to meta-fsl-arm, remove here | Max Krummenacher | |
2015-06-03 | colibri_vf: enable SCSI disk required for USB mass storage | Stefan Agner | |
SCSI lock device disk support is required for USB mass storage to work. Also enable asynchronous SCSI scanning by default. | |||
2015-05-18 | Apalis/Colibri iMX6: use toradex_imx_3.10.17_1.0.0_ga branch | Max Krummenacher | |
2015-05-18 | Colibri VF: use latest from toradex_vf_4.0 branch | Max Krummenacher | |
2015-05-18 | Apalis/Colibri T20/T30: use tegra branch | Max Krummenacher | |
2015-05-18 | Apalis/Colibri iMX6: update kernel to latest in -next | Max Krummenacher | |
2015-05-18 | Apalis/Colibri T20/T30: update kernel to latest in -next | Max Krummenacher | |
2015-05-12 | recipes-kernel: remove orphaned 3.17 defconfig | Max Krummenacher | |
2015-05-12 | Apalis/Colibri iMX6: kernel/U-Boot update to latest in -next | Max Krummenacher | |
2015-05-12 | update U-Boot and Colibri VFxx Linux to latest git revision | Stefan Agner | |
Also deploy an additional device tree supporting a Colibri iMX6 with Analog Camera Module. | |||
2015-05-12 | colibri_vf: update to U-Boot 2015.04/Linux 4.0 | Stefan Agner | |
2015-05-12 | linux-toradex-fsl_git.bb: remove 3.0.15 Vybrid Kernel | Max Krummenacher | |
This removes the 3.0.15 based Kernel for Colibri VFxx. Since some time now we use a more recent Kernel provided from the linux-toradex-vf_3.18.bb recipe. | |||
2015-05-12 | apalis/colibri_t20/t30: integrate latest stuff | Marcel Ziswiler | |
2015-05-12 | recipes: replace short DESCRIPTION with SUMMARY | Max Krummenacher | |
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY. | |||
2015-03-19 | colibri-vf: update to top of -next branch | Stefan Agner | |
Update to top of -next branch which also includes FEC unbind fixes. | |||
2015-03-19 | tegras: update to latest kernelColibri_T20_LinuxImageV2.3_20150320V2.3 | Marcel Ziswiler | |
This contains some eMMC fixes for Apalis/Colibri T30 as well as a CSI-2 fix for Apalis T30 and an ACM fix. | |||
2015-02-03 | tegras: update git hash of Linux kernelColibri_VF_LinuxImageV2.3Beta7_20150203Colibri_T20_LinuxImageV2.3Beta7_20150203 | Stefan Agner | |
2015-02-03 | colibri-vf: update Linux kernel and U-Boot git hashes | Stefan Agner | |
Also update default defconfig for colibri-vf. | |||
2014-12-19 | colibri_vf: update U-Boot and Linux kernel git hashes | Stefan Agner | |
Two last minute fixes: Default Product/Vendor ID for USB peripheral in U-Boot and fix for the USB peripheral RNDIS freeze. | |||
2014-12-18 | Update all to latest and greatest U-Boot and Linux kernel. | Marcel Ziswiler | |
2014-12-18 | tegras: update to latest kernel | Marcel Ziswiler | |
This kernel can be used on latest Apalis T30 V1.1A hardware with Toshiba eMMC and optional UHS SD cards in MMC slot. | |||
2014-12-16 | colibri-vf: switch to mainline kernel based on 3.18 | Stefan Agner | |
Switch default kernel recipe to linux-toradex-vf which will build a kernel based on the toradex 3.18-next branch. | |||
2014-12-11 | colibri-vf: update Kernel | Max Krummenacher | |
2014-12-11 | apalis/colibri-imx6: U-Boot and Kernel for V1.0/V1.1 | Max Krummenacher | |
Update to a U-Boot and Kernel which can be used for Apalis iMX6 HW version V1.0 and V1.1. Also deploy additional device tree for Apalis iMX6 V1.0 modules | |||
2014-11-13 | Apalis/Colibri iMX6/T20/T30/VF50/VF61: rev kernel version to V2.3b4 | Marcel Ziswiler | |
2014-11-13 | colibri-vf: add mainline kernel recipe | Stefan Agner | |
Add recipe to build mainline kernel. Currently, the 3.17 next branch will be built. To use this kernel, add this lines to your local.conf PREFERRED_PROVIDER_virtual/kernel ?= "linux-toradex" IMAGE_INSTALL_append = "kernel-devicetree" KERNEL_DEVICETREE += "vf500-colibri-eval-v3.dtb vf610-colibri-eval-v3.dtb" Also, the multi-core communication packages (mqxboot, libmcc, mcc-pingpong and kernel-module-mcc) need to be removed from recipes/images/trdx-extra.inc since the required kernel interfaces are not available on the 3.17 mainline port. | |||
2014-10-30 | linux: iMX6/VF update to latest from git | Max Krummenacher | |
2014-10-30 | linux: tegra latest from git | Marcel Ziswiler | |
2014-10-06 | colibri-imx6: refactor recipes for new module | Max Krummenacher | |
2014-09-03 | linux-toradex: update to latestApalis_T30_LinuxImageV2.3Beta2_20140903 | Max Krummenacher | |
This pulls in the fix for PCIe rarely unavailable at boot. Branch changed from colibri to tegra | |||
2014-08-04 | kernel: update to latest on git.toradex.comColibri_VF_LinuxImageV2.3Beta1_20140804Colibri_T30_LinuxImageV2.3Beta1_20140804Colibri_T20_LinuxImageV2.3Beta1_20140804Apalis_iMX6_LinuxImageV2.3Beta1_20140804Apalis_T30_LinuxImageV2.3Beta1_20140804 | Max Krummenacher | |
2014-08-04 | t20, t30: update kernel to latest in git | Max Krummenacher | |
2014-08-04 | apalis-imx: update kernel to 3.10.17 | Max Krummenacher | |
Base kernel on Freescales 3.10.17_1.0.0_ga and provide a device tree plus code changes for Apalis iMX6. | |||
2014-08-04 | colibri-vf: update kernel to latest, port recipe for use with daisy | Max Krummenacher | |
2014-08-04 | linux-toradex-fsl: remove linux-toradex-fsl.inc usage | Max Krummenacher | |
2014-05-20 | colibri-vf: switch back to latest git on colibri_vf branch | Marcel Ziswiler | |
This commit switches Colibri VF machine back to use the colibri_vf branch and use the latest Linux kernel. |
