2015-10-30 | appends: make sure that there is whitespace | Max Krummenacher | |
2015-08-13 | xserver-xorg: drop pinning to 1.14.7 for vf and mx6 based modules | Max Krummenacher | |
2015-05-12 | recipes: don't use ${PN} as a recipe name placeholder | Max Krummenacher | |
${PN} might be extended with some magic prefix, so don't use it in SRC_URI assignments et. al. | |||
2014-12-11 | xserver-xorg: use the xorg-CVE-2013-6424.patch | Max Krummenacher | |
while at it remove the xserver-xorg.inc file in favour of the identical inc file in the openembedded-core layer. | |||
2014-12-08 | xserver-xorg: fix broken X server rotation on tegras | Marcel Ziswiler | |
Upgrading to 1.14.7 fixes the broken X server rotation issue seen on Apalis/Colibri T20/T30 as noted on our developer website: http://developer.toradex.com/software-resources/arm-family/linux/linux/ release-details?view=all&issue=9562 | |||
2014-12-08 | xserver-xorg: upgrade to 1.14.7 | Marcel Ziswiler | |
This is an upgrade from the former 1.14.4 recipe as found here: http://cgit.openembedded.org/openembedded-core/tree/meta/ recipes-graphics/xorg-xserver?id= b8feee3cf21f70ba4ec3b822d2f596d4fc02a292 | |||
2014-08-04 | xserver: set epoch to prevent update to later versions | Max Krummenacher | |
HACK: during do_rootfs opkg takes the latest and greatest available in any feed, e.g. one built for another machine without prefered version rather than what PREFERRED_VERSION puts in the MACHINE_ARCH feed so we set the recipe epoch here. Thus for our architecture we're always latest and greatest. | |||
2014-08-04 | xserver: tegra: use 1.14.4 from meta-fsl-arm | Max Krummenacher | |
The tegras xdrivers require an 1.14 API Make the xserver ARCH specific | |||
2013-10-09 | xserver: remove the 1.13 recipe, as 1.14 now works | Max Krummenacher | |
2013-10-09 | xserver: fix patching only for the tegras | Max Krummenacher | |
2013-10-07 | xserver: V14, remove pixman_glyph_cache | Max Krummenacher | |
With the propriatry GPU driver, some text is not rendered. e.g. like in this report http://slopjong.de/2012/11/19/problem-with-font-rendering/ -> revert the relevant patch | |||
2013-09-22 | xserver-xf86-config_0.1.bb: don't duplicate that recipe | Max Krummenacher | |
2013-09-22 | remove obsolete file | Max Krummenacher | |
2013-09-22 | x-server: add version 1.13.1 which is removed from core | Max Krummenacher | |
2013-08-26 | xserver: move all xserver stuff in the same directoryT30_LinuxImageV2.0Beta3_20130820Apalis_T30_LinuxImageV2.0Beta2_20130816 | Max Krummenacher | |
2013-08-26 | xserver: enable xinerame for apalis-t30 platform | Max Krummenacher | |
