path: root/recipes-bsp
2014-10-06u-boot: remove don't build the examples patchMax Krummenacher
u-boot.inc no longer builds the standalone examples by default so do patch to not do so is no longer needed. The source tree will no longer be marked as git dirty.
2014-08-04u-boot: update to latest git versionMax Krummenacher
2014-08-04colibri-t20: add configuration to u-boot-fw-utilsMax Krummenacher
u-boot-fw-utils allows for U-Boot environmenmt access from Linux. Add the needed configuration file for colibri_t20 with a postinst script which choses the right NAND flash sector sizes from /proc/mtd While at it, fix some whitespace issues.
2014-08-04u-boot-toradex: update to latest git versionMax Krummenacher
2014-08-04gpio-export: fix gpios-export.serviceMax Krummenacher
2014-08-04u-boot-fw-utils: add config für colibri-vf and apalis-imx6Max Krummenacher
2014-08-04gpio-export: add recipe for userspace export of gpiosMax Krummenacher
2014-08-04mcc/m4: use recipes from meta-fsl-armMax Krummenacher
deleted: recipes-bsp/libmcc/libmcc_1.04.bb deleted: recipes-bsp/mqxboot/mqxboot_1.0.bb deleted: recipes-kernel/kernel-module-mcc/kernel-module-mcc_1.04.bb
2014-08-04bbappends: remove the deprecated PRINC variableMax Krummenacher
2014-05-24colibri-vf: use latest u-boot and burnflashMarcel Ziswiler
Use the latest U-Boot and burnflash.
2014-05-07u-boot: make use of shared U-Boot branchStefan Agner
2014-04-30colibri-vf: switch to U-Boot 2014.04 and latest gitStefan Agner
This commit switches Colibri VF machine to use the 2014.04 git branch. The change to latest U-Boot brings proper NAND hardware ECC support, which is also enabled in latest Linux kernel. Beside that, burnflash is updated to correctly work with the new U-Boot version and the altered Config Block location.
2014-04-05u-boot-fw-utils: provide matching recipesMax Krummenacher
With the change to our own u-boot recipes the bbappend to the common u-boot-fw-utils recipe is no longer a sane solution. While at it cleanup COMPATIBLE_MACHINE style.
2014-04-03u-boot: apalis-imx6 update to latest git versionMax Krummenacher
2014-04-02u-boot: apalis-imx6 update to latest git versionMax Krummenacher
2014-04-01asound.state: apalis-imx6 set volume to maximumMax Krummenacher
2014-04-01u-boot: convert bbappend to a bbMax Krummenacher
2014-04-01u-boot: add Apalis iMX6 and Colibri VF recipeMax Krummenacher
2014-04-01alsa-state: add file for iMX6Max Krummenacher
2014-04-01colibri-vf: use meta-fsl* layer for BSP filesMax Krummenacher
remove the files copied from meta-fsl* for Colibri-VF V2.1 move the colibri-vf u-boot and kernel stuff to meta-fsl-arm-extra
2014-03-26mqxboot/libmcc: fixed dependencies to kernel moduleStefan Agner
We need to have the kernel modules header at build time, so mark it as not only a runtime dependency.
2014-03-18u-boot Txx: update to latestMax Krummenacher
2014-03-17kernel/u-boot: update to latest git revisionStefan Agner
2014-03-17vybrid: backport Cortex-M utilites from meta-fslStefan Agner
- Add utility mqxboot to load firmware into IRAM and reset M4 - Add kernel module mcc needed by libmcc - Add multi-core communication library libmcc for message queue based communication with Cortex-M core
2014-02-10kernel/u-boot: update to latest gitColibri_T30_LinuxImageV2.1Beta2_20140206Colibri_T20_LinuxImageV2.1Beta2_20140207Apalis_T30_LinuxImageV2.1Beta2_20140206Stefan Agner
2013-11-21u-boot: colibri-vf: use the unified u-boot 50/61Max Krummenacher
2013-11-21Machine: use the changed machinename colibri-vfMax Krummenacher
2013-10-23u-boot: update to latest git versionColibri_VF50_LinuxImageV2.1Beta1_20131022Colibri_T30_LinuxImageV2.1Beta1_20131022Colibri_T20_LinuxImageV2.1Beta1_20131022Apalis_T30_LinuxImageV2.1Beta1_20131022Max Krummenacher
2013-10-10colibri-vf50: add the machine, kernel and u-bootMax Krummenacher
- also add the relevant configuration files
2013-10-10u-boot-fw-utils: add bbappend to use the same u-boot sourcesMax Krummenacher
2013-10-07u-boot: clean up recipeMax Krummenacher
2013-09-22u-boot: don't build the examplesMax Krummenacher
- they do fail because they don't heed the private libgcc
2013-08-23u-boot: update to latest git versionMax Krummenacher
2013-07-02lvds-ctrl: replace hi with the correct high in the scriptsMax Krummenacher
2013-06-26u-boot: update to latest git revisionMax Krummenacher
2013-04-15Apalis: make the lvds configuration glitch freeMax Krummenacher
2013-03-20lvds: autostart the dual lane scriptMax Krummenacher
2013-03-04remove unused filesMax Krummenacher
2013-02-06Apalis-T30: add lvds setup scriptsMax Krummenacher
2013-01-29u-boot: add Apalis-T30Max Krummenacher
- add Apalis-T30 - remove u-boot machine definition, this is also defined in the machine conf.
2013-01-29alsa: add Apalis-T30 initial asound.stateMax Krummenacher
2013-01-22u-boot: update to latest on git.toradex.comMax Krummenacher
2012-12-31T30: add specific alsa asound.stateT30_LinuxImageV2.0Alpha0_20121227Max Krummenacher
2012-12-31update u-boot and kernel git versionsMax Krummenacher
remove testfile
2012-12-18u-boot: remove all modification, they are moved to u-boot gitT20_LinuxImageV2.0Beta1_20121218Max Krummenacher
2012-10-18u-boot: update to 16a9368a88a28252ea1daedc1df03ccc49ea5b22Max Krummenacher
2012-10-18removed *~ backup files from git repoMax Krummenacher
2012-10-18u-boot: update to a1ab5236759b1cd6fae427517d44d7be90b02c07Max Krummenacher
2012-08-23Use kernel and u-boot from git.toradex.comMax Krummenacher
Move changes done to other repos into .bbappends in meta-toradex
2012-08-15L4T R15, oe-core Image V2.0Beta1Max Krummenacher
