Use systemd V2.18 from meta-angstrom.
Issues with firmware loading and the 3.1.10 kernel for the tegra machines
are fixed with a backport from oe-core.
Also deploy an additional device tree supporting a Colibri iMX6 with
Analog Camera Module.
The default changed to zImage so explicit set uImage for now.
While at it cleanup the recipe, remove pci from Colibri machine features.
This patch fixes the issue of getting serial tty login at ttymxc1 (UART_B).
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
