UBOOT_CONFIG was changed to use 'sd' as one of the configs built for
the R5 SPL. However the same is already in use when building the
TEZI specific U-Boot for the Cortex A53 and is set from within the
TEZI distro.
Thus the two configuration clash and the build fails.
Change the config name to include the suffix '-r5' to have the two
seperate.
Fixes: 979d850 ("verdin-am62-k3r5: drop -gp from the u-boot config names")
(cherry picked from commit 6ad496b724d27fdd9d3227931fab34fa34d53f53)
Aquila AM69 was added to u-boot-toradex-ti. Change the machine
to use that.
Related-to: ELB-5482
(cherry picked from commit 4d5907acdfdd2eabac1ee179025945f75361e522)
Signed-off-by: Hiago De Franco <hiago.franco@toradex.com>
(cherry picked from commit d2b57d4eea25aa36458a59f52c79aca57333c8b5)
The TORADEX_PRODUCT_IDS[<PID4>] flag is only used to choose the
installed dtb on modules with raw NAND storage.
Drop defining that as the setting is not used at all.
(cherry picked from commit 98b06e1c7ee86731a26ef4016fad0b206c308b40)
The R5 U-Boot now builds binaries for all SoC variants (gp, hs-fs, hs).
Reflect that in the UBOOT_CONFIG variable.
(cherry picked from commit 979d850ac241cffb15963794245813256c025898)
All AM62 based SKUs were moved to a hs-fs based SoC.
While with a tezi image this does not matter create the
tiboot3.bin symlink to point to the hs-fs based binary
to be consistent.
(cherry picked from commit ad0aaee5cabd08652635b440353a88640db50a77)
The make_dtb_boot_files python function can be also used to other future
machines added to meta-toradex-ti, therefore make it naming more generic
instead of calling it verdin-am62.inc.
(cherry picked from commit 3c042fdce2c8d4e2fea5836be9fc49b49400fe7a)
Add linux-firmware-powervr required for the GPU found on the AM62.
Related-to: ELB-5607
Override meta-ti-bsp setting this to downstream mesa-pvr if nothing else
is set.
Revert this commit once upstream meta-ti-bsp has this properly solved.
Starting from V1.1B Verdin AM62 Solo variants (0071 and 0072 PID4s) use
HSFS SOC and not GP, this requires to use a different firmware.
After this change V1.1A variants will no longer work out of the box.
Related-to: ELB-5592
Signed-off-by: Francesco Dolcini <francesco.dolcini@toradex.com>
(cherry picked from commit f0f61eb26607d15a3d77feaa789a6d7edd02c5bf)
This reverts commit 8d479786dcec3cbfb1e1ef6ed8f53b89b7d9bc0b.
The dts files made it into 6.8. Revert the commit which excludes
those device tree files from the build.
The mallow device tree sources are not yet merged in mainline.
Don't try to build them for now.
Revert this commit once mainline has the sources merged.
Verdin SoM can have a hardware TPM with them (for now on carrier boards),
so add the tpm2 machine feature to enable software support for the device.
The tmp2 means that the software supports TPM 2.0 specification.
Related-to: ELB-5500
Signed-off-by: Joao Paulo Goncalves <joao.goncalves@toradex.com>
(cherry picked from commit 86652d4cf3bb2291e8c936e1fa20cabf81b3bfae)
Add Mallow device tree to machine configuration.
Related-to: ELB-5217
(cherry picked from commit 74e73502e653e7ee9acb126d4335393695b053b3)
MACHINE_FIRMWARE is a variable existing and managed only on meta-freescale,
to have the Wi-Fi firmware properly deployed we need it to be added to
the standard MACHINE_EXTRA_RRECOMMENDS variable.
Related-To: ELB-5457
(cherry picked from commit 98c579337436e55e09bcc032e54f00ed9b9f0464)
Add btnxpuartconf as Verdin AM62 is (optionally) featuring Bluetooth.
(cherry picked from commit 390791c4d1e29958dc330d481a6c6dada8591ec2)
Add mwifiexconf as Verdin AM62 is (optionally) featuring Wi-Fi.
(cherry picked from commit b91f7ff504a9c767070960f29fe8bf96f2e4ac35)
Add device tree overlays to upstream distro, latest kernel supports
the default overlays enabled.
The upstream Linux recipe in meta-toradex-bsp-common was renamed to
linux-toradex-upstream and currently only builds latest mainline.
For a next BSP we will add a recipe which will build the to be used
stable tree.
Related-to: ELB-5359
The upstream U-Boot recipe in meta-toradex-bsp-common was split into
a always pinned and a latest head recipe.
For a OE master branch we always use the latest development version.
Related-to: ELB-5357
Currently we don't have any overlays against a mainline kernel.
This prepares to actually deploy overlays meant for a
Verdin AM62 when using an upstream distro.
Related-to: ELB-5331
Latest master of U-Boot allows building for a Verdin AM62 SoM.
If using a upstream distro build the upstream u-boot-toradex
recipe.
For non NXP SoM we decided to directly use the `upstream` override
specified in the distro.
Fix the last occurrence of `use-mainline-bsp`.
The driver does currently not compile if compiled against an upstream
kernel, initial solution does compile but fails at runtime:
https://lore.kernel.org/yocto-meta-ti/20230728160005.905140-2-rs@ti.com/T/#u
Additionally for kernel 6.3 a used API changed which makes it fail
compiling against such kernels, see kernel commit bc292ab00f6c7
("mm: introduce vma->vm_flags wrapper functions").
By booting from eMMC the file content is read from the eMMC boot area,
not from a filesystem.
Keeping them additionally in the bootfs might confuse people.
Fixes: 4c40178 ("u-boot: updated to the toradex_ti-u-boot-2023.04 branch")
The variables TPL_BINARY and OFFSET_TPL_PAYLOAD are not choosen wisely
as they are not used to specify a TPL (Tertiary Program Loader).
The tiboot3 binary is not a TPL (Tertiary Program Loader) but
actually contains the binaries first booted by the boot ROM.
Rename TPL_BINARY and OFFSET_TPL_PAYLOAD to FIRMWARE_BINARY and
OFFSET_FW_PAYLOAD respectively.
Related-to: ELB-5244
Remove the from meta-ti inherited u-boot splashsceen.
The configured Verdin AM62 U-Boot doesn't support any splashscreen.
Related-to: ELB-5238
- Update to the toradex_ti-u-boot-2023.04 branch, based on the
ti-u-boot-2023.04.
- This includes/requires the move to use binman to assemble the binaries
used for boot.
- With the change to binman the R5 SPL is now built from one OE machine
only, not one machine per SoC flavour (GP, HS-FS, HS).
- With binman we also change the name for the tiboot3* files to match
the machine they are built form, not claiming to be the evm.
E.g. tiboot3-am62x-hs-fs-verdin.bin.
- With the binman and HS-FS we need to package the kernel also as a
fitimage to prevent a build error in U-Boot, however we keep using
Image.gz
- Drop the '-staging' from the recipe name.
This change adds linux-firmware-iw416 package, which makes iw416
wifi firmware available on verdin-am62 root filesystem, since this
is required on the HW V1.1 where the NXP IW416 chip is used.
Related-to: ELB-5247
Signed-off-by: Andrejs Cainikovs <andrejs.cainikovs@toradex.com>
Follow the pattern used in meta-toradex nxp commit ce9a5ef
("machines: arch arm: follow change to vendor subdir for dtbs")
Set the variable KERNEL_DTB_PREFIX with the relative path to the device
tree source files and then use it. This variable can then be used
in the creation of the u-boot-distro-boot script.
Related-to: ELB-5263
Add the following PID4s SOMs:
- 0071 Verdin AM62 Solo 512MB
- 0072 Verdin AM62 Solo 512MB WB IT
- 0073 Verdin AM62 Dual 1GB ET
- 0074 Verdin AM62 Dual 1GB IT
- 0075 Verdin AM62 Dual 1GB WB IT
- 0076 Verdin AM62 Quad 2GB WB IT
to the list of Toradex modules.
Related-to: ELB-5222
Signed-off-by: Emanuele Ghidoli <emanuele.ghidoli@toradex.com>
Change TPL_BINARY to a varflags variable, following the changes in commit
7fd635f58748 ("image_type_tezi: select TPL binary based on PID4")
in meta-toradex-bsp-common and
f538188f86c1 ("image_type_tezi_run: select TPL binary based on PID4")
in meta-toradex-tezi.
There are three different AM62x SoC types:
- General Purpose (GP)
- High Security - Field Securable state (HS-FS)
- High Security - Security Enforced state (HS-SE)
Each type must be flashed with the relevant SYSFW (tiboot3) binary and
every Verdin AM62 SKU has its own specific SoC type.
Select GP binary for 0069 PID4.
Related-to: ELB-5227
Add HS-FS SoC type binaries (different SYSFW), GP SoC type is still
the default one and the one used in the generated tezi image,
HS-FS binaries are just deployed and not used yet.
tiboot3.bin renamed to tiboot3-gp.bin to make it clear that this is the
binary for the GP variant.
Related-to: ELB-5226
Now that we build our own machine verdin-am62 we don't need the
hackish and hidden overrides of certain variables.
Move these settings into the machine configuration.
Related-to: ELB-5190
Enable HDMI to DSI adapter overlay by default.
This deploys Image.gz instead of Image into the boot partition.
The boot.scr will pick that up and direct U-Boot to decompress
the kernel before passing control to the kernel.
Related-to: ELB-5205
U-Boot is now fixed and now uses the raw binary blobs from the eMMC
boot area.
Don't inherit meta-ti's deployment of the boot binary blobs into
the boot FAT partition.
Completes commit 25be292 ("Revert "verdin-am62: workaround, deploy
u-boot to boot partition"")
Related-to: ELB-5080
This reverts commit d99284cfa23f114de55126af2647d58cf7ba3a54.
boot area.
The used driver is now set with virtual/gpudriver and installed
automatically.
This additionally allows to not use a GPU driver at all as used
by the Toradex Easy Installer.
Related-to: TEI-1066, ELB-5190
Set UBOOT_ENTRYPOIN and UBOOT_LOADADDRESS to the same address as
kernel_comp_addr_r.
These are used when putting the kernel in a fitimage.
As we now have a working Toradex Easy Installer this bringup way
of flashing images is no longer needed.
Currently the R5 U-Boot doesn't load the A53 SPL and U-Boot proper from
the raw eMMC boot area but from the first fat partition of the eMMC
user area. As a workaround deploy these binaries additionally to FAT FS.
Related-to: TEI-1066, ELB-5080
Add Yavia dtbs to the machine.conf file.
Related-to: ELB-5174
Add Dahlia dtbs to the machine.conf file.
meta-ti changed to additionally handle HS-FS and HS-SE devices, i.e. to
provide tiboot3 for the different flavours of the SoC.
They added a multiconfig for each of the flavours also renaming stuff
for the gp device we use.
Follow the change to have GP build again, but opt out of additionally
building tiboot3 for HS-FS and HS-SE devices.
meta-ti commit 12bb9e20 ("machine: Add AM62x HS-SE evm configuration")
commit 053002fb ("am62xx-evm: Add AM62x HS-FS evm configuration")
Related-to: ELB-5170
meta-ti kirkstone recipes have been updated to latest, i.e. sdk v08.06.04.
Related-to: ELB-5068
Keep the layer also compatible against a master checkout until we
have it production ready.
