path: root/recipes-support
2021-08-14layer: convert to new override syntaxMax Krummenacher
This is the result of automated script (0.9.3) conversion: +# meta-toradex-distro +vars = vars + ["preempt-rt","tdx","upstream"] +# meta-toradex-* machines +vars = vars + ["apalis-","colibri-","verdin-","tegra124"] +# meta-freescale +vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"] ../openembedded-core/scripts/contrib/convert-overrides.py . converting the metadata to use ":" as the override character instead of "_". Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-06native-tools: remove comment about 32-bit host binariesMax Krummenacher
Remove comment which was obsoleted by commit b34fa66b4159cb6b0952a6821e73fdb93ae7714f Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-07-23recipes: get rid of the 32-bit host binariesGerard Salvatella
Enforcing to build 32-bit binaries for native and portions thereof using -m32 in EXTRA_OEMAKE_class-native may lead to building errors. Also, it seems it's time to move on from 32-bit compatibility. Affected repositories: meta-toradex-demos meta-toradex-nxp meta-toradex-tegra Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-06-30libcryptopp: update to 5.6.4Max Krummenacher
- License has changed - For target builds a versioned shared object is now created Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-06-30libcryptopp: build also shared objectMax Krummenacher
While at it clean-up the calls to make. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-06-30libcryptopp: add test package with the testbinaryMax Krummenacher
2017-06-30libcryptopp: add correct target install prefixMax Krummenacher
2017-06-30libcryptopp: add linker flags for gnu hashMax Krummenacher
This prevents the OE warning 'No GNU_HASH in the elf binary'. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-07meta-toradex-tegra: cleanup whitespace useMax Krummenacher
2016-06-30libcryptopp: update to latest 5.6.3Marcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2015-05-12tegrarcm/cryptopp: build and use as a static libraryMax Krummenacher
We need libcryptopp only for a 32bit x86 target for tegrarcm. However linking libcryptopp dynamically and using the distro supplied 32bit compatibility libcryptopp raises an assertion: tegrarcm: secblock.h:145: CryptoPP::NullAllocator<T>::pointer CryptoPP::NullAllocator<T>::allocate(CryptoPP::NullAllocator<T>::size_type, const void*) [with T = unsigned int; CryptoPP::NullAllocator<T>::pointer = unsigned int*; CryptoPP::NullAllocator<T>::size_type = unsigned int]: Assertion `false' failed. Building only a static library with OE, (if native build forcing 32bit) fixes the issue.
2015-05-12recipes: replace short DESCRIPTION with SUMMARYMax Krummenacher
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY.
2015-03-31libcryptopp: use autotools-brokensepMax Krummenacher
While at it unpack sources in standard S directory
2014-10-31libcryptopp: package/stage to correct pathsMax Krummenacher
The native build needs PREFIX to stage the files correctly into x86 sysroot The target build did not deploy the shared object due to missing soname version symlinks
2014-10-30Add libcryptopp recipeMarcel Ziswiler
