path: root/recipes-multimedia/alsa
2021-08-14layer: convert to new override syntaxMax Krummenacher
This is the result of automated script (0.9.3) conversion: +# meta-toradex-distro +vars = vars + ["preempt-rt","tdx","upstream"] +# meta-toradex-* machines +vars = vars + ["apalis-","colibri-","verdin-","tegra124"] +# meta-freescale +vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"] ../openembedded-core/scripts/contrib/convert-overrides.py . converting the metadata to use ":" as the override character instead of "_". Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2020-06-01apalis-tk1-mainline: rename machine to apalis-tk1Max Krummenacher
Rename the apalis-tk1-mainline machine to the now dropped apalis-tk1 machine name. Related-to: ELB-2733 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 0bf55088d1f34338dd04f83d6b90b7a72f6867de)
2019-04-24alsa: apalis-tk1-mainline: fix asound.conf patchingMarcel Ziswiler
Fix commit 0f59e154bfeb ("alsa: apalis-tk1-mainline: add initial asound.state and asound.conf"). Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit 26cbb6fd9019f28141f8fef42521c82246fa3d03)
2019-04-24alsa: apalis-tk1-mainline: add initial asound.state and asound.confPhilippe Schenker
Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com> (cherry picked from commit 0f59e154bfebd18f4f9eb11a31912ad5cb7e0c93)
