The upstream kernels were renamed. Follow the rename.
U-Boot was split into a pinned denx + our patches and a latest denx
version. Thus no uprev is needed for U-Boot.
Related-to: ELB-5617
Follow the changed imx-sc-firmware-toradex version to
imx-sc-firmware-toradex_1.14.0.bb.
Related-to: ELB-5054
(cherry picked from commit 9480d591b81316ce0e828f37bed74329de2a5d81)
Follow the changed linux-toradex version to linux-toradex_5.15-2.2.x.bb.
Related-to: ELB-5185
Signed-off-by: Emanuele Ghidoli <emanuele.ghidoli@toradex.com>
(cherry picked from commit 1447911e2b5212f3eaf13c657629d19fd5977221)
Remove the '-staging'.
Related-to: ELB-5238
(cherry picked from commit 555fbd08693c0687176c80fca0d2411dc1df6ded)
U-Boot and Linux in meta-toradex-ti have been updated, reflected in
the recipe name.
Modified the uprev-srcrev script to the new file paths.
(cherry picked from commit aa050275ab9bca764854f6fcf80b9baa1b23be39)
Related-to: ELB-5018
(cherry picked from commit fc76e870b03b4920790560eeafd268af36f4d1e9)
Add U-Boot and Linux kernel for the TI SoC based modules to the
uprev script.
ELB-5012
(cherry picked from commit f6525a402462a51ec65fd854f886e7fbaeb9f72c)
In the OE master builds we want to fetch latest upstream U-Boot with
possible additional patches from our OE meta data.
So enable the uprev of the upstream U-Boot recipe.
(For release OE meta data we want a fixed upstream version, independent
on the use of 'use-head-next' overrides)
Related-to: ELB-4640
Related-to: ELB-4593
(cherry picked from commit 2712e46aadd2ec74711d69503b61dba3548e0aa4)
Follow the changed linux-toradex version to linux-toradex_5.15-2.1.x.bb.
Related-to: ELB-4873
(cherry picked from commit cd3e7aed7069637d462170a8a98313cc76a01ae0)
Releated-to: ELB-4868
(cherry picked from commit bc8579961cd541b16721c67cf0b48009a73e10da)
Related-to: ELB-4597
Signed-off-by: Andrejs Cainikovs <andrejs.cainikovs@toradex.com>
Related-to: ELB-4581
U-Boot changed to the mainline u-boot recipe, but our bbappend can't
be handled by this script, add a note.
The mainline kernel recipe name changed.
TK1 no longer supported.
Backports of kernel drivers no longer used.
Related-to: ELB-4476
Uprev all recipes used by the Toradex Easy Installer.
Do this by refactoring the list of recipes in a bsp list used for all
builds and add the additional ones for TEZI and Torizon.
Related-to: AUT-932
(cherry picked from commit e835edf3bc368fc6beb64acefa96a349ec6da281)
scripts/uprev-srcrev
Fix wrong new override syntax conversion
Relates-to: ELB-4127
(cherry picked from commit e73336f9ff769414c5090640b6f33dc7b3169afb)
This is the result of automated script (0.9.3) conversion:
../openembedded-core/scripts/contrib/convert-overrides.py .
+# meta-toradex-distro
+vars = vars + ["preempt-rt","tdx","upstream"]
+# meta-toradex-* machines
+vars = vars + ["apalis-","colibri-","verdin-","tegra124"]
+# meta-freescale
+vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"]
converting the metadata to use ":" as the override character instead of "_".
(cherry picked from commit 390fb8af9c4b2b13b891df6907b96ee53d201e5f)
So far exceptions have been catched in the python script and
have not been reported back to caller. The status code of the script
was always 0. This makes it impossible to the build scripts to react
on failed runs of uprev-srcrev tool.
In case a recipe can not be found, patching further recipes
gets skipped and a status code not equal to 0 is returned.
Signed-off-by: samuel.bissig <samuel.bissig@toradex.com>
(cherry picked from commit a5fcc0566de94d92f78ab156f641ac5dc58855fc)
(cherry picked from commit 632db61f177acf18df79d40fefdf1c662c6233a8)
Signed-off-by: Denys Drozdov <denys.drozdov@toradex.com>
Use two lists of recipes which should be upreved, one for tdxref and one
for Torizon builds.
Currently Torizon has additionally the linux kmeta repo but lacks the
Apalis TK1 U-Boot.
Relates-to: AUT-507
Force BB_SRCREV_POLICY to 'clear'. Thus the fetcher queries the remote
git repo for the latest HEAD and does not rely on the copy in the local
download directory.
With this, we can change CI to run uprev-srcrev before building the
images if we want to build latest HEAD of our components rather than
using AUTOREV through use-head-next.
This prevents that a push to the repos during a build might cause
build errors.
Related-to: AUT-528
Add imx-sc-firmware to the list of recipes to update src rev. This
recipe is now a regular recipe (not a bbappend) and hence can be used
uprev'ed using recipetool.
Related-to: AUT-355
(cherry picked from commit e3c9f089b2dd3b807d97dec80fa15a5d13f86cea)
Create a Toradex specific script which loops through all recipes using
AUTOREV and updates them to the current git hash.
Related-to: AUT-355
(cherry picked from commit 35fd1b9ead35b45a590b0a478f9ca11512d05921)
