Current master and scarthgap-7.x.y updated systemd recipe to version
255.1. The recipe now prints
WARNING: systemd-1_255.1-r0
do_install: Using /home/root as root user's home directory is not fully
supported by systemd
Therefore, use /root instead of /home/root as $ROOT_HOME to fix this
warning.
Related-to: ELB-5646
Signed-off-by: Hiago De Franco <hiago.franco@toradex.com>
openembedded-core commit 941ba1a132 ("kernel-fitImage: Strip path
component from dtb") changed to remove the vendor path components
from fitimage nodes by default. This would require to change our
bootscripts.
Set the variable 'KERNEL_DTBVENDORED' to get the old behaviour back.
Related-to: TEI-1143
On Verdin AM62 SERIAL_CONSOLES is set to multiple ttys. In the old
setup this spawned a getty on each of them.
Using systemd's serial-getty-generator this behaviour is changed to
only spawn a getty on the ttys which are also present in /proc/consoles.
Other entries in SERIAL_CONSOLES are left alone and are free for
generic use.
Related-to: ELB-5346
(cherry picked from commit 491e249099a36c2eb7f8c0192f100265c1eae0b1)
The systemd recipe now requires this.
From https://docs.yoctoproject.org/ref-manual/features.html?highlight=usrmerge
usrmerge: Merges the /bin, /sbin, /lib, and /lib64 directories into
their respective counterparts in the /usr directory to provide better
package and application compatibility.
Related-to: ELB-5339
This has been there forever without anyone speaking up. Seems
the used features weren't that bad.
(cherry picked from commit 6961869d7d4fbeada96d68a978076246941363ba)
Since commit dcf889e93401f7c4de0055d53271eacc3882eccc in OE:
meta: Remove remnants of bluez4 support
bluez4 was removed from meta-oe 2 years ago.
Simplfy the setup of the two level bluetooth and bluez4/bluez5
distro features by removing the bluez4/bluez5 distro features.
This also removes the no longer required bluetooth class.
Signed-off-by: Richard Purdie <richard.purdie@linuxfoundation.org>
bluez5 is no longer a distro feature, and there is no reference to it
neither in Toradex/Freescale/OE meta layers, let's drop it.
Related-to: ELB-4824
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit bdb31caa6c2a6a96112f536c76d4e1eca8da3ea4)
As used in the downstream NXP BSP LLF5.15.32_2.0.0.
Related-to: ELB-4665
(cherry picked from commit 095032507d6560ff6bb916982732a2190019b97f)
We've decided not to support Tegra machines since BSP6, let's drop
their references.
Related-to: ELB-4471
It's an invalid variable, there is not a bitbake instance for
u-boot-default-env.
Related-to: ELB-4536
NXP's gstreamer fork is updated to 1.18.5.imx.
Follow meta-freescale commit 30f5ce1d ("Generalize overrides subsystem for
NXP and Mainline support").
TEZI_SHOW_EULA_LICENSE shall be a machine global variable but not image
specific, move it to tdx-base.inc in meta-toradex-distro layer.
Torizoncore/Tezi/BSP now use the same setting of
TEZI_SHOW_EULA_LICENSE.
Related-to: TOR-2102
(cherry picked from commit a991a45459b7f3c0870ef94da6e48c279eaa97f0)
These versions were pinned when backporting a newer NXP BSP to dunfell.
In master these versions were bumped in meta-freescale and the new versions
are set to preferred there. The override here interferes and instead of
the i.MX specific recipe the upstream recipe from OE-Core is built.
NXP's gstreamer fork is updated to 1.18.0.imx.
Currently the preferred version for the gstreamer components is
assigned with '='. Relax that to '?=' to allow for a easier override
in other configuration files.
Proposed-by: Carlos Rafael Giani <crg7475@mailbox.org>
This is the result of automated script (0.9.3) conversion:
../openembedded-core/scripts/contrib/convert-overrides.py .
+# meta-toradex-distro
+vars = vars + ["preempt-rt","tdx","upstream"]
+# meta-toradex-* machines
+vars = vars + ["apalis-","colibri-","verdin-","tegra124"]
+# meta-freescale
+vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"]
converting the metadata to use ":" as the override character instead of "_".
Some Toradex recipes like linux-toradex, u-boot-toradex,
device-tree-overlays are appending SCM hashes to PV, version numbers
going backwards are not a problem as we don't provide binary feeds.
This avoids some annoying errors as follows:
| QA Issue: Package version went backwards which would break package feeds
Related-to: ELB-3583
(cherry picked from commit 3c1f97ef5bbea7f6afaaea5b58ce1b8baa4ce82f)
meta-freescale added the revision part of the gstreamer imx forks to the version,
i.e. 1.16.imx -> 1.16.2.imx. Rework the preferred versions.
NXP release imx_5.4.70_2.3.0.
Related-to: ELB-3327
(cherry picked from commit 2561e4a6cc6d5a8f6badb32ed3ead6eb4b536519)
We dont really need 'ptest' and that would invovle in a lot of recipes
to be built which could be very time consuming.
Related-to: ELB-3195
(cherry picked from commit 27000bd0282b681ab083430b5e49d81e42ce1f71)
SDK_VERSION is used as a path element for the nativesdk packages. Thus,
if variables are used to form it which are excluded to force a rebuild,
when using sstate or previous build artefacts paths stay not the same
resulting in various build failures.
So drop all elements which are marked with "vardepsexclude".
E.e.:
Dependencies not found in compile/configure as the search paths don't match.
Build output not found:
| rm: cannot remove '.../image/opt/tdx-xwayland/5.0.0-devel-20200821220610+build.0/sysroots/x86_64-tdxsdk-linux/usr/lib/aarch64-tdx-linux/gcc/aarch64-tdx-linux/9.3.0/install-tools': No such file or directory
Related-to: ELB-2758
Related-to: ELB-2552
Use separate variables for version components. This is useful to form
the new OSTree branch names which use the major version only.
Related-to: TOR-1107
(cherry picked from commit 3f69c5d786d0677ff1f1d959e5e8e482a4e4148b)
Define PREFERRED_PROVIDER_virtual/dtb to device-tree-overlays.
Signed-off-by: Igor Opaniuk <igor.opaniuk@gmail.com>
(cherry picked from commit c4b1a3d10e0245ff7ac9e4c11ad135f8488f8409)
NXP's 2.3.1. BSP is based on the following version.
wayland-protocols: "1.17.imx"
weston: "5.0.0.imx"
Related-to: ELB-2303
(cherry picked from commit be3bebbc165727418f261d29bd75dd413527fd97)
(cherry picked from commit f0fd9dc7da066aa5d49903b518f01e6bce4cafaa)
'DISTRO' is in DISTROOVERRIDES by default, we should not use "=" to
override that when adding 'tdx' to DISTROOVERRIDES, use ".=" to append
to it.
With the above change, we do not need to append 'tdx-x11' and
'tdx-xwayland' to DISTROOVERRIDES, drop them.
(cherry picked from commit 9a93acdeda3fed168b74c33788f385ac42702ed4)
The imx gstreamer update is updated to 1.16.imx.
Add TDX_VERSION which can be used by Toradex customized software
artifacts like U-Boot or the Linux kernel. This version number does
not contain a date timestamp to prevent unnecessary rebuilds. It is
assumed that the software artifact adds a build number (e.g. git
hash).
Implement new version number scheme. This has been tested recently in
meta-toradex-torizon and proven to work reliably. Lets move it to
meta-toradex-distro so all Toradex distribution can make use of it.
Using python to conditionally set PREFERRED_VERSION_xxx does work, however
bitbake evaluates the value of PREFERRED_VERSION_xxx before set in the
python function.
Reverting the conditional assignment in favour of a hard coded upstream value.
fixes: 1e400c68e
The recipes for gstreamer* with version 1.14.imx set compatible version to
mx6, mx7, mx8. So for machines which use use-mainline-bsp we get a lot of
OE warnings during build, e.g.:
| NOTE: preferred version 1.14.imx of gstreamer1.0 not available (for item gstreamer1.0)
| NOTE: versions of gstreamer1.0 available: 1.14.4
build is actually a file not a directory.
If a derived distro does not want /etc/hostname then that should be added
for that distro only.
Only adds a tdx-x11 distro. Additional flavours to follow.
