path: root/recipes-support/libfm
2021-08-14layer: convert to new override syntaxMax Krummenacher
This is the result of automated script (0.9.3) conversion: +# meta-toradex-distro +vars = vars + ["preempt-rt","tdx","upstream"] +# meta-toradex-* machines +vars = vars + ["apalis-","colibri-","verdin-","tegra124"] +# meta-freescale +vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"] ../openembedded-core/scripts/contrib/convert-overrides.py . converting the metadata to use ":" as the override character instead of "_". Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2014-08-04Use generic bbappend filesMax Krummenacher
This uses the % wildcard for recipe matching. remove the deprecated PRINC variable while at it.
2013-09-22libfm: bbappend updated to 1.1Max Krummenacher
2013-02-06libfm: set lxterminal as the terminal applicationMax Krummenacher
