path: root/recipes-graphics/vnc
2024-05-07vnc: remove x11/directfb only toolsMax Krummenacher
Remove the recipes. Related-to: ELB-5740 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2022-03-06layer: Update LICENSE variable to use SPDX license identifiersMax Krummenacher
Since OE-Core commit 9379f80f48 ("license/insane: Show warning for obsolete license usage"), LICENSE field not containing SPDX identifiers are treated with WARNING. An automated conversion using scripts/contrib/convert-spdx-licenses.py to convert to use the standard SPDX license identifiers has been done on the entire layer. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2021-08-14layer: convert to new override syntaxMax Krummenacher
This is the result of automated script (0.9.3) conversion: +# meta-toradex-distro +vars = vars + ["preempt-rt","tdx","upstream"] +# meta-toradex-* machines +vars = vars + ["apalis-","colibri-","verdin-","tegra124"] +# meta-freescale +vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"] ../openembedded-core/scripts/contrib/convert-overrides.py . converting the metadata to use ":" as the override character instead of "_". Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2020-10-18recipes: drop trailing / from path specifierMax Krummenacher
2017-04-07meta-toradex-demo: clean-up whitespace useMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-05-12recipes: replace short DESCRIPTION with SUMMARYMax Krummenacher
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY.
2015-05-12recipes: don't use ${PN} as a recipe name placeholderMax Krummenacher
${PN} might be extended with some magic prefix, so don't use it in SRC_URI assignments et. al.
2014-07-15vnc: add directvnc and tightvnc recipesMarcel Ziswiler
Two popular VNC clients: - DirectVNC based on DirectFB (e.g. without X11) - TightVNC based on X11 (cherry picked from commit ef4113208de357a5b8accd7610f8bf3230125a59)
