2024-05-07 | lxqt: remove lxqt integration files | Max Krummenacher | |
LXQt relies on the dropped X11. Remove the recipes and related files. Also remove sddm, the display manager used with lxqt. Related-to: ELB-5740 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2021-08-14 | layer: convert to new override syntax | Max Krummenacher | |
This is the result of automated script (0.9.3) conversion: +# meta-toradex-distro +vars = vars + ["preempt-rt","tdx","upstream"] +# meta-toradex-* machines +vars = vars + ["apalis-","colibri-","verdin-","tegra124"] +# meta-freescale +vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"] ../openembedded-core/scripts/contrib/convert-overrides.py . converting the metadata to use ":" as the override character instead of "_". Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2018-03-22 | sddm.conf: allow for root autologin to lxqt | Max Krummenacher | |
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> |
