The immediate evaluation of ${PV} fails here and leads to a not
existing extra search path entry.
Thus linux-toradex-upstream-6.6 is searched after
linux-toradex-upstream and thus files which can be found under both
directories are taken from linux-toradex-upstream.
Fix that by not relying on ${PN} or ${PV} and giving the verbatim
directory name.
That also allows to remove setting FILESEXTRAPATHS in the linux rt
recipe.
Change the the stable RT kernel branch and include the settings
from the 6.6 stable kernel recipe do not dublicate the used
patches.
Related-to: ELB-5616
latest mainline
For OE master we want to build only latest mainline.
For a next BSP we will add a recipe which will build the to be used
stable tree.
Related-to: ELB-5359
