This fixes NXP having renamed and updated the license (again).
Fixes: a7100f0ca20b ("linux-firmware: update imx-firmware to lf-6.1.55-2.2.0")
(cherry picked from commit 239237c27511902a9d7b430e44386791b8fa8fbc)
Update imx-firmware to commit 7be5a936ce8677962dd7b41c6c9f41dd14350bec
on branch lf-6.1.55_2.2.0. This updates the IW416 Bluetooth and Wi-Fi
Firmware to 16.92.21.p84.128.
(cherry picked from commit a7100f0ca20b6f6b2b61bbe112028cd3c703598b)
For legal compliance there's a need to ship EULA along with
any firmware files from imx-firmware.
Related-to: ELB-5247
(cherry picked from commit c91a1b80c24712f835b1d7b9c83947727583749c)
Rather than unpacking in ${WORKDIR}/imx-firmware, unpack it in
${S}/imx-firmware and adjust the install commands accordingly.
This in preparation of properly adding the imx-firmware licence info.
When using the openembedded-core create-spdx-2.2.bbclass the specified
files are to be specified relative to ${S} which is easier to achieve
if in a subdirectory of ${S}.
(cherry picked from commit ee4386c2420368eb447ca6255bc387f16fe2097b)
Move common files into separate package and add it to sd89xx and iw416
dependencies.
Signed-off-by: Andrejs Cainikovs <andrejs.cainikovs@toradex.com>
(cherry picked from commit 9b7bd08b10582056b9cecf7be694231cba75d992)
Recent change switched the branch of imx-firmware to the
latest release (lf-6.1.22_2.0.0), but did not update srcrev,
effectively making no change to the target image at all.
This bumps imx-firmware srcrev to the latest commit on the
mentioned branch.
Fixes: 8154788a0cfc ("linux-firmware: bump imx-firmware to latest version")
(cherry picked from commit 337a077d0cf63aea1c104bf9e8c730810721206a)
This bumps imx-firmware to latest lf-6.1.22_2.0.0.
(cherry picked from commit 8154788a0cfcb950e104da7b67cc7244e8e3cdf6)
This adds the sdiouartiw416_combo_v0.bin firmware for IW416 based
Wi-Fi/Bluetooth modules which are present on Verdin AM62 modules.
This particular firmware variant is supposed to be used for
configuration of Wi-Fi via SDIO and Bluetooth via UART.
(cherry picked from commit 5e0f9936994fcd6c04910c4d33d266fddf054efa)
With the addition of Verdin AM62 with IW416 based WiFi module we
need to get rid of meta-toradex-nxp dependency for TI based SoM.
This change moves linux-firmware recipe from meta-toradex-nxp.
(cherry picked from commit 05c6a1ae9639ad990af1ff1fc52c5af290568ad8)
Completes commit 48ea0df ("linux-firmware: drop bbappend").
The package split for sd8997 has been upstreamed to openembedded-core.
openembedded-core provides now a rtl8188 package which contains the
firmware for rtl8188 and rtl8188eu. Use that one.
The firmware for Marvell 8997 using SDIO as the interface is also
available from the regular linux-firmware repo, although with an
other filename.
Use that one and provide a symlink to cope with the old name.
When building with usrmerge, the firmware directory is in /usr/lib.
Make sure we pickup firmwares from nonarch_base_libdir.
This fixes a build warning when building Torizon:
* Problem 1/1:
* - nothing provides linux-firmware-rtl8188eu needed by linux-firmware-1:0.0+git0+d114732723-r0.all
This reverts commit e6641b0a6f93ebf752534b283d0dfb0c2c656ec2.
