weston.service and weston.socket are now only deployed if systemd is in
distro features. (OE commit 00e3eb3893 ("weston-init: guard against
systemd configs")
Make their modification also conditionally on the feature.
Fixes Toradex Easy Installer build which doesn't use systemd as
the init manager.
Related-to: TEI-1063
Verdin AM62 uses regular weston also with the downstream kernel,
thus set no idle timeout also without the upstream override.
Related-to: ELB-5064
(cherry picked from commit 3dc7e8a2fdfabc9a1c9c3a718acf6ceebb7a1a24)
Related-to: ELB-4800
(cherry picked from commit 9d61de2a84b78852c74ad0b50910ffd219af621a)
Import the file `profile` and rename it directly to its final name
`weston.sh` from meta-freescale-distro.
This allows to use it in a Toradex Easy Installer setup and it
simplifies the bbappend which does not add the freescale-distro layer.
Also fix several issues as follows:
- Drop INI_UNCOMMENT_ASSIGNMENTS append, the correct fix has been
merged to meta-freescale by commit: 6be9870b505.
- Replace configure_noidle by no-idle-timeout PACKAGECONFIG.
- Replace configure_pixman by use-pixman PACKAGECONFIG.
- Install weston env setup profile.
- Run weston systemd service as root user, this ensures input devices
and GPU acceleration hardwares, reference:
https://source.codeaurora.org/external/imx/meta-imx/commit/?h=hardknott-5.10.72-2.2.0&id=9e08be758765d4a991e0a440f8abef225be094e3
Related-to: ELB-3477
Signed-off-by: Ming Liu <ming.liu@toradex.com>
