The following error was spotted during the boot of Colibri iMX7S on Tezi
6:
U-Boot 2022.07-6.4.0-devel+git.e092e3250270 (Jul 11 2022 - 13:42:58 +0000)
CPU: Freescale i.MX7S rev1.2 800 MHz (running at 792 MHz)
CPU: Extended Commercial temperature grade (-20C to 105C) at 29C
Reset cause: POR
DRAM: initcall sequence 8786b820 failed at call 87818e09 (err=-3)
\### ERROR ### Please RESET the board ###
This patch solves this issue by calling fdt_increase_size() on
colibri_imx7.c file.
Related-to: TEI-1138
Signed-off-by: Hiago De Franco <hiago.franco@toradex.com>
(cherry picked from commit 30484414981f3652caf43a0a71b3922e269a643b)
This commit introduces patches to the defconfig of Apalis/Colibri iMX6,
Colibri iMX7 and Colibri iMX6ULL to enable fastboot support and adds a
logic to the bootcmd to select SDP or Fastboot based on the configs
enabled.
Related-to: TEI-1136
(cherry picked from commit 266bdf4d7b1ce31bcbc35dd92f52ca45c60eadba)
Add a patch to fix device tree build errors from other boards that are
not related to Colibri.
(cherry picked from commit b49784d54dbdc8532fc87c163f951ebff3073701)
This commit backports two patches submitted to the U-Boot mainline, both of
which relocate the 'nand_padding' function to the Makefile of 'mach-imx.'
The first patch introduces the 'u-boot-nand.imx' target to the Makefile,
producing a binary file with 1024 leading zeros. The second patch adds a 'dd'
command to the Makefile, appending 10k zeros to the end of the binary.
These changes will eliminate the need of the 'nand_padding' function.
(cherry picked from commit 678579d8783e2d24666ca1b6af58544f67579aa0)
Add patch to enable variant detection durint boot time. Depending on the
board configuration, the variant will be set to "-emmc" or cleared in
case it is a NAND device.
This patch improves variant detection during system initialization
through USB recovery mode.
Related-to: TEI-1112
(cherry picked from commit 16e5f73b2b294855fe579e8252b149154bdb7322)
This reduces confusion about the current solution on what version gets
built with use-head-next.
This drops using the `use-head-next` override in favour of having two
recipes. Which recipe is to be built will then be set in the various
<machine.conf> files.
To reduce code duplication split out common code into a inc file and
further split out i.MX and TI specific stuff into two specific inc
files.
Related-to: ELB-5357
Stop deploying u-boot-with-spl.imx, this is not required to properly flash
the board nor for debugging. Separated SPL and U-Boot proper binaries available,
used by Tezi and can be easily flashed using update_uboot and update_spl helper
scripts.
This enables some simplification on Tezi.
(cherry picked from commit 81a446adde4296c7e68f916bc536414a1caa1397)
We no longer provide a kernel based on the NXP downstream BSP.
Drop patching U-Boot to support booting such a kernel on a Colibri iMX7.
This enables building upstream U-Boot for Verdin AM62 including building
and deploying tiboot3 and tispl with binman.
Related-to: ELB-5331
The class now handles to provide an imx-boot symlink to flash.bin.
Also drop redundant entries in DEPENDS which are now part of the
generic u-boot include file.
U-Boot release 2023.07 branched away from the master branch which
is reflected in OE u-boot recipe.
Switch this back to the master branch, so that for use-head-next we
take latest on master rather than latest on branch u-boot-2023.07.y.
Add a patch to fix a DDR RAM issue that can cause bit flips at
temperatures above 60°C.
Related-to: ELB-5211
Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
(cherry picked from commit 63e4e72c5c71d510106c6504074697c30d396e47)
Add patch to use the in band bad block table on Colibri iMX7.
Related-to: ELB-4989
(cherry picked from commit 86e64d70123b2ff55924ec6581c6154e628f661b)
The u-boot-with-spl.imx binary, now is deployed for each u-boot configuration
type and the condition that suppressed the error in case u-boot-with-spl.imx
was not generated has been removed.
Signed-off-by: Stefano Viola <stefano.viola@toradex.com>
(cherry picked from commit 15ec9fe118984cc977016269c069571c4530ef8f)
Update the distro config env memory layout for the Apalis iMX6,
Colibri iMX6, Colibri iMX6ULL and Colibri iMX7.
This fixes a potential issue caused by the compressed kernel being
relocated on top of the ramdisk causing its corruption.
(cherry picked from commit 84c7638a7261561e30bfd574b69e1fddcac546cc)
Add patch to properly size the memory on Verdin iMX8M Plus.
Related-to: ELB-4711
Signed-off-by: Francesco Dolcini <francesco.dolcini@toradex.com>
(cherry picked from commit 6931dff87db18d38a14414fe35ef49805bcf5238)
Keep the file name with the inital U-Boot environment variables
constant, independent of the recipe name U-Boot is built with.
Our image creation and libubootenv expect a fixed name.
Related-to: ELB-4680
The version mismatch between what we want to build and what the recipe
in openembedded-core builds can get big so that CVE backports and other
changes makes our build fail.
Rather create our own recipe reusing the include file from
openembedded-core to reduce the risk of build failures.
Relates-to: ELB-4680
