At least imx-boot requires u-boot. Bitbake would thus not consider
our upstream U-Boot recipe as a valid provider and the build will
fail for machines not using binman within U-Boot to build the
boot container.
So the change is required once we start building the upstream
U-Boot for Apalis iMX8 and Colibri iMX8X.
To build tiboot3 binman uses additional python modules. Add them
to the dependencies.
The correct override matching all i.MX based machines is now
imx-generic-bsp, not imx. Fix that.
Fixes 7a2d6ff ("u-boot-toradex: split into a release/pinned and latest head recipe")
Related-to: ELB-5357
This reduces confusion about the current solution on what version gets
built with use-head-next.
This drops using the `use-head-next` override in favour of having two
recipes. Which recipe is to be built will then be set in the various
<machine.conf> files.
To reduce code duplication split out common code into a inc file and
further split out i.MX and TI specific stuff into two specific inc
files.
