Add TI-TFL ("TEXAS INSTRUMENTS TEXT FILE LICENSE") to TI tezi image artifact,
while removing the NXP one.
Current license file come from [1].
Disable the download of an updated license from a specific url, formerly used
for NXP EULA, due to missing proper link.
[1] https://git.ti.com/cgit/graphics/ti-img-rogue-umlibs/tree/?h=linuxws/dunfell/k5.10/1.15.6133109
Related-to: ELB-5161
Signed-off-by: Emanuele Ghidoli <emanuele.ghidoli@toradex.com>
(cherry picked from commit a44240a3d58d353d86be7fed4d79c086dc2f2312)
This changes the layer's compatibility to only kirkstone.
This is the result of automated script (0.9.3) conversion:
+# meta-toradex-distro
+vars = vars + ["preempt-rt","tdx","upstream"]
+# meta-toradex-* machines
+vars = vars + ["apalis-","colibri-","verdin-","tegra124"]
+# meta-freescale
+vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"]
../openembedded-core/scripts/contrib/convert-overrides.py .
converting the metadata to use ":" as the override character instead of "_".
We want to always check the latest EULA file in image_type_tezi.bbclass
So we put LA_OPT_NXP_SW.html to sstate duplicate whitelist, this
ensures it could be deployed to ${DEPLOY_DIR_IMAGE} as a backup even
it's aleady existed.
This fixes a following bitbake error:
| ERROR: tezi-metadata-0.3-r0 do_deploy: The recipe tezi-metadata is
| trying to install files into a shared area when those files already
| exist. Those files and their manifest location are:
| images/colibri-imx8x-v10b/LA_OPT_NXP_SW.html
| (not matched to any task)
| Please verify which recipe should provide the above files.
Related-to: ELB-3485
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit efbdc6e55cbcd49c576c7c8da2b6dd55e200b6d1)
Keep hard-copy version of license file
in sstate cache in case of NXP connection error
Signed-off-by: Denys Drozdov <denys.drozdov@toradex.com>
(cherry picked from commit b29e20964a72e01193b242aefb6cde655dda7d87)
The License window will be shown in case SHOW_EULA_FILE set to "1"
(cherry picked from commit a4f005089d9c286fa33f4fb5f2e41f1a0ee614d6)
Ensure there is a popup that shows the EULA license
to be accepted once installing a tdxref image
(cherry picked from commit 9ececa26080b7abdc96dc1b4b910e735b6eafcfd)
With use-mainline-bsp the SoC overrides mx6/mx6q/mx6ull... are filtered out of
the overrides. Replace them with the specific machine name.
Related-to: ELB-2805
(cherry picked from commit 35a3002fca96cdb8529847187e1509e70a230a37)
Related-to: ELB-2686
(cherry picked from commit 78f228b9b427972a70c91deb5b40af1f307b7246)
(cherry picked from commit d02b7fd19d87eb2dffcaa36ab4427e47a8a749c4)
(cherry picked from commit f38654502d12c13329be747570cfbed144ce9f16)
We have generic prepare.sh and wrapup.sh scripts hence tezi-metadata
is buildable and useable for any machine.
These machines use an old Nvidia provided downstream kernel 3.1.10. They no
longer much the way more recent sysroot components, e.g. libc, xserver et. al.
The maintance burden to keep the userspace components in their old version
becomes simply to high. Keep using the rocko based 2.8 BSP for these machines.
A main package being empty without setting ALLOW_EMPTY can lead to
errors in populate_sdk task. If it does not provide any packages then
we should let it inherit nopackages bbclass.
Signed-off-by: Ming Liu <liu.ming50@gmail.com>
Update the slides shown during image installation. This updates
our presence in Japan.
Use '${COMMON_LICENSE_DIR} for license files
fix the warning:
| WARNING: packagegroup-xfce-base-1.0-r5 do_populate_lic:
| ${COREBASE}/LICENSE is not a valid license file, please use
|'${COMMON_LICENSE_DIR}/MIT' for a MIT License file in LIC_FILES_CHKSUM.
|This will become an error in the future
The default (empty) prepare/wrapup scripts will be used which is
fine since there is no need for special scripting on Colibri iMX7
currently.
The wrapup.sh script updates fuses/eMMC settings on-site. The same
script can be used for Apalis iMX6 as well as for Colibri iMX6.
The boot partition configuration needs to be done _after_ writing
to the boot partition (hence after flashing SPL and U-Boot). Move
the whole migration script to the end by using the wrapup.sh script.
This adds metadata files required by Toradex Easy Installer. Most
notable is the Linux specific migration script which is executed
before flashing an image. The script makes sure that hardware specific
upgrades such as fuses/eMMC reconfiguration get executed, as our
U-Boot based scripts do when using "run update".
