2023-11-29 | classes: toradex-kernel-config: Add general config variable function | Hiago De Franco | |
Add a general-purpose configuration variable handling function within the toradex-kernel-config classe. This function can be used for various software configurations, including U-Boot. By doing so, we reduce code duplication in other layers that dynamically modify configurations, such as meta-toradex-tezi. Related-to: ELB-5409 Signed-off-by: Hiago De Franco <hiago.franco@toradex.com> (cherry picked from commit 6e86c264494d0309ac76c1bc3fc1246a7ac96180) | |||
2021-08-14 | layer: convert to new override syntax | Max Krummenacher | |
This is the result of automated script (0.9.3) conversion: +# meta-toradex-distro +vars = vars + ["preempt-rt","tdx","upstream"] +# meta-toradex-* machines +vars = vars + ["apalis-","colibri-","verdin-","tegra124"] +# meta-freescale +vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"] ../openembedded-core/scripts/contrib/convert-overrides.py . converting the metadata to use ":" as the override character instead of "_". Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2020-03-13 | toradex-kernel-config: add bbclass | Ming Liu | |
It contains a helper function kernel_configure_variable that could be called in do_configure_append task to assign a value to a config variable in ${B}/.config. Change toradex-kernel-localversion.bbclass to use this function. Signed-off-by: Ming Liu <ming.liu@toradex.com> |
