2016-01-18 | imx7_colibri_m4: remove QSPI example | Stefan Agner | |
The Colibri iMX7 module does not provide QSPI flash, hence drop the QSPI example. | |||
2016-01-18 | imx7_colibri_m4: changed pinmux for I2C4, changed board I2C interface to I2C4 | Mateusz Majchrzycki | |
Pin assignment for I2C4 changed to redirect the bus to SODIMM pins 194 and 196 (standard Colibri I2C interface) | |||
2016-01-12 | examples: imx7_colibri_m4: adopted GPIO example | Stefan Agner | |
Use Colibri EXT_IO0-2 as Key/LED GPIO. Those signals can easily be connected to a real button/LED on the Colibri Evaluation board: EXT_IO0 => X21-LED1 EXT_IO1 => X21-SW6 EXT_IO2 => X21-SW5 | |||
2016-01-12 | examples: imx7_colibri_m4: renamed board name | Stefan Agner | |
2016-01-12 | examples: imx7_colibri_m4: use DTE mode for debug UART2 | Stefan Agner | |
2016-01-12 | renamed demo_apps and driver_examples project names | Stefan Agner | |
2016-01-12 | initial commit imx7_colibri_m4 examples | Stefan Agner | |
This adds initial examples for imx7_colibri_m4, currently just a copy of the imx7d_sdb_m4 examples. |
