Changes specific to vendor kernels
The media backports are not used by so many users in my opinion and to
reduce the efforts needed to make the new changes to media introduced
by new kernel versions work on older kernel versions just make it
depend on kernel 3.8 and do not support all the older kernel versions
for media any more. This makes it possible to remove some patches and
other changes.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Since support for kernels < 3.0 was removed, there's now a bunch
of dead code that can be removed - do it.
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
There are two users of of_find_property_value_of_size() which is
originally static in the kernel, but we need it exposed (but not
exported) so that multiple backport files can use it; do that.
- add pci_sriov_set_totalvfs()
- add patches/collateral-evolutions/network/84-ethernet/0002-igb_pci_sriov_configure.patch
Several ifdefs in igb_main.c to avoid compiler warnings.
Signed-off-by: Stefan Assmann <sassmann@kpanic.de>
A user reported that the linux/mm.h header was missing on his mips
device with kernel 2.6.26.
This fixes a compile error with some config options.
Closes bug: https://bugzilla.kernel.org/show_bug.cgi?id=66601
Reported-by: Richard Röjfors <richard.rojfors@gmail.com>
This was added in 3.8 and not used until now.
Since it it being used by the wireless stack, backport it.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
[mcgrof: fixed renamed prandom_bytes_state to prandom_bytes on symbol]
This is needed by drivers/bluetooth/btmrvl_main.c
In terms of project naming the backports project has evolved
as follows:
compat-wireless --> compat-drivers --> backports
All along the design and intent behind the initial project
has been to provide a framework for delivery of *upstream*
drivers using a backported infrastructure. I've made it
clear that in no way shape or form did I ever want any
proprietary driver to make use of the framework. As the
project has grown I'm not alone with this sentiment so
lets document that and also fix a few symbols that have
slipped along the way.
Make these descriptions generic.
This adds vm_iomap_memory() from:
commit b4cbb197c7e7a68dbad0d491242e3ca67420c13e
Author: Linus Torvalds <torvalds@linux-foundation.org>
Date: Tue Apr 16 13:45:37 2013 -0700
vm: add vm_iomap_memory() helper function
On some kernels, hid_match_id() exists, so mask it.
This reverts commit 91bf647c3a157688ce8e94c0df512cde1b3f5a87.
Also fix the #ifdef for netdev_set_default_ethtool_ops() as
it was backported into kernel 3.7.8.
This needs to be included for kernel 3.7.
Then we can also move all the plumbing/ stuff into it.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
