This reverts commit ab3fd3b9a801a9faa2619e2e65207e736f859a6d.
This reverts commit 1b4e6ad4d927c7998fa578f2d29e0c4ec01a9217.
Said commit broke b43 on older kernels (<3.16).
I am not aware of any user of the NFC coded in backports, at least I
haven't seen any patches regarding this. Remove this code to reduce the
efforts needed in the backports project.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Use the versions shipped with the kernel instead.
bcma and ssb didn't change much in the last few years, most of the
changes were related to code only used on embedded devices. Removing
this reduces the number of parts we have to backport. b43, b43legacy and
brcmsmac work well with the in kernel version.
This removes parts which were only used by subsystems which are not
included in backports any more, for example media, bluetooth and
Ethernet.
The patches which are removed in this commit are not applied to the
kernel tree anyway with the default configuration because non of the
files get copied. The freezer, media, regulator and sound parts were
only used by the already removed media drivers. The flow dissector file
is not copied any more.
This adds the staging Realtek drivers which are making use of cfg80211
and mac80211.
802.15.4 has been removed by this commit,
15a3df8 backports: remove 802.15.4 entirely
but there are some files left behind.
Remove them all.
Signed-off-by: AceLan Kao <acelan.kao@canonical.com>
This is needed by bluetooth and ieee802154.
This splits up the Kconfig from things which are needed due to
our copy of code from the kernel and things which we need
specifically only for packaging backports. We will later then
share the Kconfig.souce for instance for kernel integration.
While at it, split up the list of files that we need to copy
into what we know could be shared for integration. The the
case of backport packaging Kconfig.package will be copied to
the package's Kconfig when building the package with gentree.py.
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
