path: root/tools
2014-10-31tools/kwbimage: Fix compilation warningStefan Roese
This patch fixes a compilation warning of kwbimage.c: tools/kwbimage.c: In function ‘kwbimage_set_header’: tools/kwbimage.c:784:8: warning: ‘headersz’ may be used uninitialized in this function [-Wmaybe-uninitialized] memcpy(ptr, image, headersz); ^ Instead of using multiple if statements, use a switch statement with a default entry. And return with error if an unsupported version is configured in the cfg file. Signed-off-by: Stefan Roese <sr@denx.de> Acked-By: Wolfgang Denk <wd@denx.de>
2014-10-31tools/kwbimage.c: fix build on darwinAndreas Bießmann
kwbimage uses get_current_dir_name(3) which is a gnu extension and not available on darwin host. Fix this by converting to portable getcwd(3) function. This patch fixes the following error: ---8<--- HOSTCC tools/kwbimage.o tools/kwbimage.c:399:16: warning: implicit declaration of function 'get_current_dir_name' is invalid in C99 [-Wimplicit-function-declaration] char *cwd = get_current_dir_name(); ^ tools/kwbimage.c:399:10: warning: incompatible integer to pointer conversion initializing 'char *' with an expression of type 'int' [-Wint-conversion] char *cwd = get_current_dir_name(); ^ ~~~~~~~~~~~~~~~~~~~~~~ 2 warnings generated. ... Undefined symbols for architecture x86_64: "_get_current_dir_name", referenced from: _image_headersz_v1 in kwbimage.o ld: symbol(s) not found for architecture x86_64 --->8--- Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de> [agust: fixed getcwd() return warning] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2014-10-27gitignore: ignore atmel pmecc parameter toolAndreas Bießmann
2014-10-27Merge branch 'master' of git://git.denx.de/u-boot-mpc5xxxTom Rini
2014-10-27ppc: Zap Hymod boardMarek Vasut
Remove this board as this is the only one last user of eeprom_probe(), which is pretty non-standard stuff. This patch also removes all the PHP, SQL and CSS stuff from U-Boot, which probably makes U-Boot a bit less IoT ;-) Signed-off-by: Marek Vasut <marex@denx.de> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Heiko Schocher <hs@denx.de>
2014-10-27tools/socfpgaimage.c: fix build on darwinAndreas Bießmann
socfpgaimage utilizes htole32 and friends, unfortunately these functions are not available on darwin. Fix it by using the cpu_to_le32 and friends defined in compiler.h as other parts in mkimage do. This patch fixes the following error: ---8<--- HOSTCC tools/socfpgaimage.o tools/socfpgaimage.c:77:22: warning: implicit declaration of function 'htole32' is invalid in C99 [-Wimplicit-function-declaration] header.validation = htole32(VALIDATION_WORD); ^ tools/socfpgaimage.c:80:22: warning: implicit declaration of function 'htole16' is invalid in C99 [-Wimplicit-function-declaration] header.length_u32 = htole16(length_bytes/4); ^ tools/socfpgaimage.c:95:6: warning: implicit declaration of function 'le32toh' is invalid in C99 [-Wimplicit-function-declaration] if (le32toh(header.validation) != VALIDATION_WORD) ^ tools/socfpgaimage.c:97:6: warning: implicit declaration of function 'le16toh' is invalid in C99 [-Wimplicit-function-declaration] if (le16toh(header.checksum) != hdr_checksum(&header)) ^ 4 warnings generated. ... HOSTLD tools/dumpimage Undefined symbols for architecture x86_64: "_htole16", referenced from: _socfpgaimage_set_header in socfpgaimage.o "_htole32", referenced from: _socfpgaimage_set_header in socfpgaimage.o "_le16toh", referenced from: _verify_buffer in socfpgaimage.o "_le32toh", referenced from: _verify_buffer in socfpgaimage.o ld: symbol(s) not found for architecture x86_64 --->8--- Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Pavel Machek <pavel@denx.de>
2014-10-23tools: kwbimage: Add image version 1 support for Armada XP / 370Stefan Roese
This patch integrates the Barebox version of this kwbimage.c file into U-Boot. As this version supports the image version 1 type for the Armada XP / 370 SoCs. It was easier to integrate the existing and known to be working Barebox source than to update the current U-Boot version to support this v1 image header format. Now all Marvell MVEBU SoCs are supported: Image type 0: Kirkwood & Dove Image type 1: Armada 370 & Armada XP Please note that the current v1 support has this restuction (same as has Barebox version): Not implemented: support for the register headers and secure headers in v1 images Tested on Marvell DB-78460-BP eval board. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Luka Perkov <luka@openwrt.org>
2014-10-23tools: Compile kwboot for Marvell Armada XP as those SoCs are now supportedStefan Roese
2014-10-23tools/kwboot: Sync with latest barebox version to support Armada XPStefan Roese
The barebox version of the kwboot tool has evolved a bit. To support Armada XP and Dove. Additionally a few minor fixes have been applied. So lets sync with the latest barebox version. Please note that the main difference between both versions now is, that the U-Boot version still supports the -p option, to dynamically patch an image for UART boot mode. I didn't test it now though. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Luka Perkov <luka@openwrt.org>
2014-10-06tools: socfpga: Add socfpga preloader signing to mkimageCharles Manning
Like many platforms, the Altera socfpga platform requires that the preloader be "signed" in a certain way or the built-in boot ROM will not boot the code. This change automatically creates an appropriately signed preloader from an SPL image. The signed image includes a CRC which must, of course, be generated with a CRC generator that the SoCFPGA boot ROM agrees with otherwise the boot ROM will reject the image. Unfortunately the CRC used in this boot ROM is not the same as the Adler CRC in lib/crc32.c. Indeed the Adler code is not technically a CRC but is more correctly described as a checksum. Thus, the appropriate CRC generator is added to lib/ as crc32_alt.c. Signed-off-by: Charles Manning <cdhmanning@gmail.com> Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Acked-by: Pavel Machek <pavel@denx.de> V2: - Zap unused constant - Explicitly print an error message in case of error - Rework the hdr_checksum() function to take the *header directly instead of a plan buffer pointer
2014-09-24tools: remove reformat.pyMasahiro Yamada
This tools is unnecessary since commit f6c8f38ec601 (tools/genboardscfg.py: improve performance more with Kconfiglib). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-24tools/genboardscfg.py: pick up also commented maitainersMasahiro Yamada
We are still keeping invalid email addressed in MAINTAINERS because they carry information. The problem is that scripts/get_maintainer.pl adds emails in the "M:" field including invalid ones. We want to comment out invalid email addresses in MAINTAINERS to prevent scripts/get_maintainer.pl from picking them up. On the other hand, we want to collect them for boards.cfg to know the last known maintainer of each board. This commit adjusts tools/genboardscfg.py to parse also the commented "M:" fields, which is useful for the next commit. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-24tools/env: change stripping strategy to allow no-strippingThomas Petazzoni
When building the U-Boot tools for non-ELF platforms (such as Blackfin FLAT), since commit 79fc0c5f498c3982aa4740c273ab1a9255063d9c ("tools/env: cross-compile fw_printenv without setting HOSTCC"), the build fails because it tries to strip a FLAT binary, which does not make sense. This commit solves this by changing the stripping logic in tools/env/Makefile to be similar to the one in tools/Makefile. This logic continues to apply strip to the final binary, but does not abort the build if it fails, and does the stripping in place on the final binary. This allows the logic to work fine if stripping doesn't work, as it leaves the final binary untouched. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Sonic Zhang <sonic.zhang@analog.com> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Sonic Zhang <sonic.zhang@analog.com>
2014-09-21patman: Add a -m option to avoid copying the maintainersSimon Glass
The get_maintainers script is a useful default, but sometimes is copies too many people, or takes a long time to run. Add an option to disable it and update the README. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-21buildman: Fix the logic for the bloat commandSimon Glass
This check should now be done whatever mode buildman is running in, since we may be displaying information while building. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-17kconfiglib: change SPDX-License-Identifier to ISCMasahiro Yamada
Commit f219e01311b2 (tools: Import Kconfiglib) added SPDX GPL-2.0+ to this library by mistake. It should be ISC. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Ulf Magnusson <ulfalizer@gmail.com>
2014-09-17Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-09-16tools/genboardscfg.py: improve performance more with KconfiglibMasahiro Yamada
The idea of using Kconfiglib was given by Tom Rini. It allows us to scan lots of defconfigs very quickly. This commit also uses multiprocessing for further acceleration. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Suggested-by: Tom Rini <trini@ti.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-16tools: Import KconfiglibMasahiro Yamada
Kconfiglib is the flexible Python Kconfig parser and library created by Ulf Magnusson. (https://github.com/ulfalizer/Kconfiglib) This commit imports kconfiglib.py from commit ce84c22e58fa59cb93679d4ead03c3cd1387965e, with ISC SPDX-License-Identifier. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Ulf Magnusson <ulfalizer@gmail.com> Cc: Ulf Magnusson <ulfalizer@gmail.com> Cc: Wolfgang Denk <wd@denx.de>
2014-09-09buildman: fix typos of --dry-run help messageMasahiro Yamada
try run => dry run no nothing => do nothing "..." => '...' The last one is for consistency with the other option helps. Change-Id: I1d69047d1fae6ef095a18f69f44ee13c448db9b7 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-09buildman: Create parent directories as necessaryThierry Reding
When creating build directories also create parents as necessary. This fixes a failure when building a hierarchical branch (i.e. foo/bar). Signed-off-by: Thierry Reding <treding@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Tom Rini <trini@ti.com>
2014-09-09patman: make run results better visibleVadim Bendebury
For an occasional user of patman some failures are not obvious: for instance when checkpatch reports warnings, the dry run still reports that the email would be sent. If it is not dry run, the warnings are shown on the screen, but it is not clear that the email was not sent. Add some code to report failure to send email explicitly. Tested by running the script on a patch with style violations, observed error messages in the script output. Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Reviewed-by: Doug Anderson <dianders@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-09buildman: Ignore conflicting tagsSimon Glass
Tags like Series-version are normally expected to appear once, and with a unique value. But buildman doesn't actually look at these tags. So ignore conflicts. This allows bulidman to build a branch containing multiple patman series. Reported-by: Steve Rae <srae@broadcom.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-09buildman: Permit branch names with an embedded '/'Simon Glass
At present buildman naively uses the branch name as part of its directory path, which causes problems if the name has an embedded '/'. Replace these with '_' to fix the problem. Reported-by: Steve Rae <srae@broadcom.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-09buildman: Expand output test to cover directory prefixesSimon Glass
Now that buildman supports removing the build directory prefix from output, add a test for it. Also ensure that output directories are removed when the test completes. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-09buildman: Add additional functional testsSimon Glass
This adds coverage of core features of the builder, including the command-line options which affect building. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-09patman: Start with a clean series when neededSimon Glass
For reasons that are not well-understood, GetMetaDataForList() can end up adding to an existing series even when it appears that it should be starting a new one. Change from using a default constructor parameter to an explicit one, to work around this problem. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-09buildman: Provide an internal option to clean the outpur dirSimon Glass
For testing it is useful to clean the output directory before running a test. This avoids a test interfering with the results of a subsequent test by leaving data around. Add this feature as an optional parameter to the control logic. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-09buildman: Correct counting of build failures on retrySimon Glass
When a build is to be performed, buildman checks to see if it has already been done. In most cases it will not bother trying again. However, it was not reading the return code from the 'done' file, so if the result was a failure, it would not be counted. This depresses the 'failure' count stats that buildman prints in this case. Fix this bug by always reading the return code. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-09buildman: Allow tests to have their own boardsSimon Glass
Rather than reading boards.cfg, which may take time to generate and is not necessarily suitable for running tests, create our own list of boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-09buildman: Avoid looking at config file or toolchains in testsSimon Glass
These files may not exist in the environment, or may not be suitable for testing. Provide our own config file and our own toolchains when running tests. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-09buildman: Set up bsettings outside the control moduleSimon Glass
Move the bsettings code back to the main buildman.py file, so we can do something different when testing. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-09buildman: Add a functional testSimon Glass
Buildman currently lacks testing in many areas, including its use of git, make and many command-line flags. Add a functional test which covers some of these areas. So far it does a fake 'build' of all boards for the current source tree. This version reads the real ~/.buildman and boards.cfg files. Future work will improve this. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-09patman: Provide a way to intercept commands for testingSimon Glass
Add a test point for the command module. This allows tests to emulate the execution of commands. This provides more control (since we can make the fake 'commands' do whatever we like), makes it faster to write tests since we don't need to set up as much environment, and speeds up test execution. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-09buildman: Move full help code into the control moduleSimon Glass
There is no good reason to keep this code separate. Move it into control.py so it is easier to test. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-09buildman: Move the command line code into its own fileSimon Glass
We want to be able to issue parser commands from within buildman for test purposes. Move the parser code into its own file so we don't end up needing the buildman and test modules to reference each other. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-09patman: RunPipe() should not pipe stdout/stderr unless askedSimon Glass
RunPipe() currently pipes the output of stdout and stderr to a pty, but this is not the intended behaviour. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-09buildman: Enhance basic test to check summary outputSimon Glass
Adjust the basic test so that it checks all console output. This will help to ensure that the builder is behaving correctly with printing summary information. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-09buildman: Send builder output through a function for testingSimon Glass
To allow us to verify the builder's console output, send it through a function which can collect it when running in test mode. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-09patman: Add a way of recording terminal output for testingSimon Glass
When running unit tests we don't want output to go to the terminal. Provide a way of collecting it so that it can be examined by test code later. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-09imximage: Fix imximage IVT bug for EIM-NOR bootYe.Li
The load region size of EIM-NOR are defined to 0. For this case, the parameter "imximage_init_loadsize" must be calculated. The imximage tool implements the calculation in the "imximage_generate" function, but the following function "imximage_set_header" resets the value and not calculate. This bug cause some fields of IVT head are not correct, for example the boot_data and DCD overlay the application area. Signed-off-by: Ye.Li <B37916@freescale.com>
2014-09-09tools: imximage: Fix the maximum DCD size for mx53/mx6Fabio Estevam
According to mx53 and mx6 reference manuals: "The maximum size of the DCD limited to 1768 bytes." As each DCD entry consists of 8 bytes, we have a total of 1768 / 8 = 221, and excluding the first entry, which is the header leads to 220 as the maximum number for DCD size. Reported-by: Jonas Karlsson <jonas.d.karlsson@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Nitin Garg <nitin.garg@freescale.com> Acked-by: Nitin Garg <nitin.garg@freescale.com>
2014-09-05patman: Fix detection of git versionSimon Glass
A missing 'global' declaration means that this feature does not currently work. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-05buildman: Separate out display of warnings and errorsSimon Glass
Some boards unfortunately build with warnings and it is useful to be able to easily distinguish the warnings from the errors. Use a simple pattern match to categorise gcc output into warnings and errors, and display each separately. New warnings are shown in magenta (with a w+ prefix) and fixed warnings are shown in yellow with a w- prefix. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-05buildman: Add an option to show which boards caused which errorsSimon Glass
Add a -l option to display a list of offending boards against each error/warning line. The information will be shown in brackets as below: 02: wip sandbox: + sandbox arm: + seaboard +(sandbox) arch/sandbox/cpu/cpu.c: In function 'timer_get_us': +(sandbox) arch/sandbox/cpu/cpu.c:40:9: warning: unused variable 'i' [-Wunused-variable] +(seaboard) board/nvidia/seaboard/seaboard.c: In function 'pin_mux_mmc': +(seaboard) board/nvidia/seaboard/seaboard.c:36:9: warning: unused variable 'fred' [-Wunused-variable] +(seaboard) int fred; +(seaboard) ^ Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-05buildman: Remove the directory prefix from each error lineSimon Glass
The full path is long and also includes buildman private directories. Clean this up, so that only a relative U-Boot path is shown. This will change warnings like these: /home/sjg/c/src/third_party/u-boot/buildman5/.bm-work/00/arch/sandbox/cpu/cpu.c: In function 'timer_get_us': /home/sjg/c/src/third_party/u-boot/buildman5/.bm-work/00/arch/sandbox/cpu/cpu.c:40:9: warning: unused variable 'i' [-Wunused-variable] /home/sjg/c/src/third_party/u-boot/files/arch/sandbox/cpu/cpu.c: In function 'timer_get_us': /home/sjg/c/src/third_party/u-boot/files/arch/sandbox/cpu/cpu.c:40:9: warning: unused variable 'i' [-Wunused-variable] to: arch/sandbox/cpu/cpu.c: In function 'timer_get_us': arch/sandbox/cpu/cpu.c:40:9: warning: unused variable 'i' [-Wunused-variable] Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-05buildman: Implement an option to exclude boards from the buildSimon Glass
Some boards are known to be broken and it is convenient to be able to exclude them from the build. Add an --exclude option to specific boards to exclude. This uses the same matching rules as the normal 'include' arguments, and is a comma- separated list of regular expressions. Suggested-by: York Sun <yorksun@freescale.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-05buildman: Allow make-flags variables to include '-' and '_'Simon Glass
These characters are commonly used in variables, so permit them. Also document the permitted characters. Reported-by: Tom Rini <trini@ti.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-05buildman: Set the return code to indicate build resultSimon Glass
When buildman finds errors/warnings when building, set the return code to indicate this. Suggested-by: York Sun <yorksun@freescale.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-05patman: Avoid changing the order of tagsSimon Glass
patman collects tags that it sees in the commit and places them nicely sorted at the end of the patch. However, this is not really necessary and in fact is apparently not desirable. Suggested-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
