path: root/tools
2012-06-19patman: Handle creation of patman config fileVikram Narayanan
patman shouts when it couldn't find a $(HOME)/.patman file. Handle it in a sane way by creating a new one for the user. It looks for a user.name and user.email in the global .gitconfig file, waits for the user input if it can't find there. Update the same in the README Signed-off-by: Vikram Narayanan <vikram186@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Simon Glass <sjg@chromium.org> Cc: Wolfgang Denk <wd@denx.de>
2012-06-19patman: Change the location of patman config fileVikram Narayanan
Move the config file from ~/.config/patman to ~/.patman as it is more appropriate to have it there. Update the same in the README. Signed-off-by: Vikram Narayanan <vikram186@gmail.com> Cc: Simon Glass <sjg@chromium.org> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Simon Glass <sjg@chromium.org>
2012-06-19easylogo: add lzma supportMike Frysinger
Compressing the logos with lzma rather than gzip saves ~9kb with the Blackfin 24bit images and ~3kb with the 16bit images. Add a new -l option to easylogo so people can pick lzma as their decompression routine. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-05-15tools, config.mk: Add gcc-version.sh, cc-version test from LinuxTom Rini
Added from Linux - commit fde7d9049e55ab85a390be7f415d74c9f62dd0f9 Signed-off-by: Tom Rini <trini@ti.com>
2012-04-30patman: Change the location of patman pathVikram Narayanan
Fix the location of patman path in README Signed-off-by: Vikram Narayanan <vikram186@gmail.com> Cc: Simon Glass <sjg@chromium.org>
2012-04-30patman: Fix a typo errorVikram Narayanan
Signed-off-by: Vikram Narayanan <vikram186@gmail.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2012-04-21Prepare v2012.04v2012.04Wolfgang Denk
Also tiny style cleanup to tools/patman/README Signed-off-by: Wolfgang Denk <wd@denx.de>
2012-04-21Add 'patman' patch generation, checking and submission scriptSimon Glass
What is this? ============= This tool is a Python script which: - Creates patch directly from your branch - Cleans them up by removing unwanted tags - Inserts a cover letter with change lists - Runs the patches through checkpatch.pl and its own checks - Optionally emails them out to selected people It is intended to automate patch creation and make it a less error-prone process. It is useful for U-Boot and Linux work so far, since it uses the checkpatch.pl script. It is configured almost entirely by tags it finds in your commits. This means that you can work on a number of different branches at once, and keep the settings with each branch rather than having to git format-patch, git send-email, etc. with the correct parameters each time. So for example if you put: in one of your commits, the series will be sent there. See the README file for full details. END Signed-off-by: Simon Glass <sjg@chromium.org>
2012-04-10mkenvimage: Fix compiler warningDirk Behme
Fix the compiler warning mkenvimage.c: In function ‘main’: mkenvimage.c:218: warning: format ‘%ld’ expects type ‘long int’, but argument 3 has type ‘unsigned int’ mkenvimage.c:226: warning: format ‘%ld’ expects type ‘long int’, but argument 3 has type ‘unsigned int’ introduced with the commit mkenvimage: Use mmap() when reading from a regular file 6ee39f8055680654f9cc97b98dcce9588f1ab71e Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> CC: David Wagner <david.wagner@free-electrons.com> CC: Anatolij Gustschin <agust@denx.de> CC: Mike Frysinger <vapier@gentoo.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: David Wagner <deubeuliou@gmail.com>
2012-03-30Merge branch 'agust@denx.de' of git://git.denx.de/u-boot-stagingWolfgang Denk
* 'agust@denx.de' of git://git.denx.de/u-boot-staging: lzma: fix printf warnings Remove CONFIG_SYS_EXTBDINFO from snapper9260.h cmd_pxe.c: fix strict-aliasing warnings net: smc91111: use mdelay() doc: Fix some typos in different files disk/part.c: Fix device enumeration through API mkenvimage: Really set the redundant byte when applicable mkenvimage: Don't try to detect comments in the input file mkenvimage: Use mmap() when reading from a regular file mkenvimage: Read/Write from/to stdin/out by default or if the filename is "-" mkenvimage: More error handling mkenvimage: Correct an include and add a missing one mkenvimage: correct and clarify comments and error messages MAKEALL: display SPL size if present ARMV7/Vexpress: add missing get_ticks() and get_tbclk() mkenvimage: fix usage message cmd_fat: add FAT write command fs/fat/fat_write.c: Fix GCC 4.6 warnings FAT write: Fix compile errors
2012-03-27mkenvimage: Really set the redundant byte when applicableDavid Wagner
Signed-off-by: David Wagner <david.wagner@free-electrons.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-27mkenvimage: Don't try to detect comments in the input fileDavid Wagner
Remove this feature since it seems impossible to reliably detect them. Signed-off-by: David Wagner <david.wagner@free-electrons.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-27mkenvimage: Use mmap() when reading from a regular fileDavid Wagner
Fall back to read() if it fails. Signed-off-by: David Wagner <david.wagner@free-electrons.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-27mkenvimage: Read/Write from/to stdin/out by default or if the filename is "-"David Wagner
2012-03-27mkenvimage: More error handlingDavid Wagner
Verbosly fail if the target environment size or the padding byte are badly formated. Verbosly fail if something bad happens when reading from standard input. Signed-off-by: David Wagner <david.wagner@free-electrons.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-27mkenvimage: Correct an include and add a missing oneDavid Wagner
compiler.h needs to be included from U-Boot's headers. Also, group U-Boot-specific includes together stdlib.h was missing. Signed-off-by: David Wagner <david.wagner@free-electrons.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-27mkenvimage: correct and clarify comments and error messagesDavid Wagner
Also, don't split error messages over several lines as per a coding style exception making them easier to grep. Signed-off-by: David Wagner <david.wagner@free-electrons.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-27imximage: Remove overwriting of flash_offsetDirk Behme
The flash header supports different flash offsets for different boot devices. E.g. parallel NOR or OneNAND use a different offset than FLASH_OFFSET_STANDARD (== 0x400). The flash offset is correctly read from the configuration in parse_cfg_cmd(). But is then overwritten wrongly in set_imx_hdr_v1/2(). Fix this by removing this overwriting. Use the flash offset correctly read from the configuration, instead. If there is no flash_offset read from the configuration file, i.e. the BOOT_FROM tag is missing, exit with an error message. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> CC: Jason Liu <liu.h.jason@gmail.com> CC: Stefano Babic <sbabic@denx.de> Tested-by: Stefano Babic <sbabic@denx.de>
2012-03-26mkenvimage: fix usage messageWolfgang Denk
Don't use argv[0] for usage() because it may or may not be clobbered by the previous call to basename(). Use "prg" instead as it is done in the rest of the code. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-17mxsboot: fix tool name in usage messageOtavio Salvador
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2012-03-06tools: checkstack.pl from Linux added to toolsTom Rini
Added from Linux - commit 62aa2b537c6f5957afd98e29f96897419ed5ebab Signed-off-by: Tom Rini <trini@ti.com>
2012-02-12EXYNOS: SMDK5250: Add MMC SPL supportChander Kashyap
This patch adds support for MMC SPL booting. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-02-12imximage: Sort bootops alphabeticallyDirk Behme
Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> CC: Fabio Estevam <festevam@gmail.com> CC: Stefano Babic <sbabic@denx.de> CC: Jason Liu <jason.hui@linaro.org> Acked-by: Jason Liu <jason.hui@linaro.org>
2012-02-12imximage: Add support for i.MX6Dirk Behme
The i.MX6 processor can boot from NOR flash and SATA disks, additionally. Add the flash offsets for these additional boot modes. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Fabio Estevam <festevam@gmail.com> CC: Stefano Babic <sbabic@denx.de> CC: Jason Liu <jason.hui@linaro.org> Acked-by: Jason Liu <jason.hui@linaro.org>
2012-02-11fw_env.h: fix commentFrans Meulenbroeks
made description according to implementation (where the config file is the default). Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com>
2012-01-16MX28: Fix MXSBOOT segfault if no params specifiedMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2012-01-13Strip mkenvimageDavid Wagner
2012-01-05Correctly handle input files beginning with several newlinesDavid Wagner
Also, fix some comments (minor) Signed-off-by: David Wagner <david.wagner@free-electrons.com>
2012-01-05tools/env: allow overwrite of ethaddr on defaultGrant Erickson
This patch allows the U-Boot user space companion utility, fw_setenv, to overwrite the 'ethaddr' key/value pair if the current value is set to a per-board-configured default. This change allows 'fw_setenv' to match the behavior of 'setenv' / 'env set' on the U-Boot command line. Signed-off-by: Grant Erickson <marathon96@gmail.com> Fixed excessive white space. Signed-off-by: Wolfgang Denk <wd@denx.de>
2012-01-05Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: tegra2: Optimize out-of-tree build for Ventana. tegra: Move boards over to use arch-level board UART function tegra: Add support for UART init in cpu board.c tegra: Add a function mux feature tegra: add clock_ll_start_uart() to enable UART prior to reloc tegra: Move clock_early_init() to arch_cpu_init() tegra: Move cpu_init_cp15() to arch_cpu_init() arm: Tegra: Fix Harmony and Ventana builds in u-boot-tegra/master tegra: Fix build error in plutux, medcom tegra2: Add Avionic Design Medcom support. tegra2: Add Avionic Design Plutux support. tegra2: Add common Avionic Design Tamonten support. tegra2: Move tegra2_mmc_init() prototype to public header. tegra2: Change CONFIG_SYS_TEXT_BASE to 0x00108000. tegra2: Always build with USE_PRIVATE_LIBGCC=yes. tegra2: Plumb in SPI/UART switch code tegra2: spi: Support SPI / UART switch tegra2: Implement SPI / UART GPIO switch tegra2: Enable SPI environment on Seaboard tegra2: config: Enable SPI flash on Seaboard tegra2: spi: Add SPI driver for Tegra2 SOC tegra2: Add UARTB support tegra2: Tidy UART selection arm, davinci: Fix build warnings for cam_enc_4xx Devkit8000: Switch over to enable_gpmc_cs_config arm, davinci: Add support for generating AIS images to the Makefile mkimage: Fix variable length header support arm, da850evm: Add an SPL for SPI boot arm, davinci: Add SPL support for DA850 SoCs sf: Add spi_boot() to allow booting from SPI flash in an SPL spl: display_options.o is required for SPI flash support in SPL ARM: omap3: add support to Technexion twister board ARM: omap3: added common configuration for Technexion TAM3517 vision2: Fix checkpatch warning
2012-01-05tools/mkenvimage.c: Fix a merge issueHorst Kronstorfer
With bfcc40bb09b05c90cc3b1496abb270eb8aa72134 'optopt' was reverted. Signed-off-by: Horst Kronstorfer <hkronsto@frequentis.com>
2012-01-05env: remove value from boolean definesIgor Grinberg
Several boolean defines have a value assigned. Remove the value as defining the symbol is enough. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-01-05fw_env.h: added a few missing definesFrans Meulenbroeks
The README file lists 4 defined that were not actually present in the .h file but that were needed to get things working with settings compiled in. They are Added these to the .h file (the values above are the ones from the README file) Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com>
2011-12-24mkimage: Fix variable length header supportChristian Riesch
Support for variable length images like AIS image was introduced in commit f0662105b674a3874227316abf8536bebc9b5995. A parameter "-s" was also introduced to prohibit copying of the image file automatically in the main program. However, this parameter was implemented incorrectly and the image file was copied nevertheless. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2011-12-23Merge branch 'next' of ../nextWolfgang Denk
* 'next' of ../next: mkenvimage: Add version info switch (-V) mkenvimage: Fix getopt() error handling mkenvimage: Fix some typos phy: add Micrel KS8721BL phy definition net: introduce per device index mvgbe: remove setting of ethaddr within the driver x86: Add support for specifying an initrd with the zboot command x86: Refactor the zboot innards so they can be reused with a vboot image x86: Add infrastructure to extract an e820 table from the coreboot tables x86: Add support for booting Linux using the 32 bit boot protocol x86: Clean up the x86 zimage code in preparation to extend it x86: Import code from coreboot's libpayload to parse the coreboot table x86: Initial commit for running as a coreboot payload CHECKPATCH: ./board/esd/hh405/logo_320_240_8bpp.c CHECKPATCH: ./board/esd/hh405/logo_1024_768_8bpp.c CHECKPATCH: ./board/esd/hh405/logo_320_240_4bpp.c CHECKPATCH: ./board/esd/hh405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/apc405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/voh405/logo_320_240_4bpp.c CHECKPATCH: ./board/esd/voh405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/hh405/fpgadata.c CHECKPATCH: ./board/esd/pci405/fpgadata.c CHECKPATCH: ./board/esd/tasreg/fpgadata.c CHECKPATCH: ./board/esd/apc405/fpgadata.c CHECKPATCH: ./board/esd/voh405/fpgadata.c CHECKPATCH: ./board/esd/ash405/fpgadata.c CHECKPATCH: ./board/esd/dasa_sim/fpgadata.c CHECKPATCH: ./board/esd/ar405/fpgadata_xl30.c CHECKPATCH: ./board/esd/ar405/fpgadata.c CHECKPATCH: ./board/esd/plu405/fpgadata.c CHECKPATCH: ./board/esd/wuh405/fpgadata.c CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405.c CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405ab.c CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci4052.c CHECKPATCH: ./board/esd/canbt/fpgadata.c CHECKPATCH: ./board/esd/du405/fpgadata.c CHECKPATCH: ./board/esd/cpciiser4/fpgadata.c CHECKPATCH: ./board/dave/PPChameleonEVB/fpgadata.c avr32:mmu.c: fix printf() length modifier fat.c: fix printf() length modifier cmd_sf.c: fix printf() length modifier Make printf and vprintf safe from buffer overruns vsprintf: Move function documentation into header file Add safe vsnprintf and snprintf library functions Move vsprintf functions into their own header Conflicts: tools/mkenvimage.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-22Print program basename instead of whole path in usage()Horst Kronstorfer
2011-12-20mkenvimage: Add version info switch (-V)Horst Kronstorfer
2011-12-20mkenvimage: Fix getopt() error handlingHorst Kronstorfer
Since the original implementation indicates explicit error handling we turn off getopt()'s internal error messaging to avoid duplicate error messages. Additionally we add ':' (missing option argument) error handling. Signed-off-by: Horst Kronstorfer <hkronsto@frequentis.com>
2011-12-20mkenvimage: Fix some typosHorst Kronstorfer
2011-12-17tools/setlocalversion: Update from the Linux KernelKyle Moffett
Several bugfixes have occurred upstream since this script was imported into U-Boot. In particular, the script currently in U-Boot does not describe commit f8bbb4dad0e9d91b7a51d6cc54dcf66d142f50fe correctly, resulting in a version of "2011.09" instead of "2011.09-01460-gf8bbb4d". With that commit checked out, the command "git name-rev --tags HEAD" gives this result: HEAD tags/v2011.12-rc1~30^2 Then the "changes" regex does not match because of the trailing '^2': grep -E '^HEAD[[:space:]]+(.*~[0-9]*|undefined)$' The new version of tools/setlocalversion in the kernel correctly handles those situations by using different plumbing commands. The version from the kernel is not directly usable as it does not append the full GIT version that U-Boot expects unless the right config options are set (CONFIG_LOCALVERSION_AUTO=y). Other than a few minor changes for Kconfig, the imported version is very similar to Linux v3.2-rc4. Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-12-06omap: Improve PLL parameter calculation toolAneesh V
Improve the tool that finds multiplier and divider for PLLs: The previous algorithm could get stuck on local maxima and required the user to specify the tolerance. Improve the algorithm to go through the entire search space and find the optimal solution. Signed-off-by: Aneesh V <aneesh@ti.com>
2011-12-06tools/envcrc: fix compile breakageIgor Grinberg
When ENV_IS_EMBEDDED is not set, but CONFIG_BUILD_ENVCRC is set, the environment.h file does not get included resulting in unrecognized env_t type. Fix this by moving the include directive. Reported-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Tested-by: Mike Frysinger <vapier@gentoo.org>
2011-12-05Fix tsize warning in tools/aisimage.cSimon Glass
This fixes the following warning with gcc 4.4.3. aisimage.c: In function 'aisimage_generate': aisimage.c:365: warning: 'tsize' may be used uninitialized in this function Signed-off-by: Simon Glass <sjg@chromium.org>
2011-12-02tools/os_support: add OS X Lion supportAndreas Bießmann
OS X Lion's c-library implements getline(), therefore prevent including the old helper implementation for __DARWIN_C_LEVEL < 200809L. Without this patch following error occours: ---8<--- In file included from os_support.h:32, from img2srec.c:55: getline.h:1: error: conflicting types for ‘getline’ /usr/include/stdio.h:449: error: previous declaration of ‘getline’ was here --->8--- Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2011-12-01image: Implement IH_TYPE_KERNEL_NOLOADStephen Warren
The legacy uImage format includes an absolute load and entry-point address. When bootm operates on a kernel uImage in memory that isn't loaded at the address in the image's load address, U-Boot will copy the image to its address in the header. Some kernel images can actually be loaded and used at any arbitrary address. An example is an ARM Linux kernel zImage file. To represent this capability, IH_TYPE_KERNEL_NOLOAD is implemented, which operates just like IH_TYPE_KERNEL, except that the load address header is ignored, and U-Boot does not copy the image to its load address, but rather uses it in-place. This is useful when sharing a single (uImage-wrapped) zImage across multiple boards with different memory layouts; in this case, a specific load address need not be picked when creating the uImage, but instead is selected by the board-specific U-Boot environment used to load and boot that image. v2: Rename from IH_TYPE_KERNEL_ANYLOAD to IH_TYPE_KERNEL_NOLOAD. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Stefan Roese <sr@denx.de>
2011-11-27ignore new mkenvimage toolMike Frysinger
2011-11-22tools/env: use lib/crc32.c directlyAndreas Bießmann
Instead of linking the file into $(obj) tree use directly the source file. This also prevents littered source tree if building not out-of-tree. Signed-off-by: Andreas Bießmann <biessmann@corscience.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-11-22env: move extern environment[] to environment.hIgor Grinberg
Extract all extern declarations for environment out of c files into the environment.h header. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-11-22new tool mkenvimage: generates an env image from an arbitrary config fileDavid Wagner
This tool takes a key=value configuration file (same as would a `printenv' show) and generates the corresponding environment image, ready to be flashed. use case: flash the environment with an external tool Signed-off-by: David Wagner <david.wagner@free-electrons.com> Acked-by; Mike Frysinger <vapier@gentoo.org> Tested-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2011-11-17tools: checkpatch.pl from Linux added to toolsJoe Hershberger
Added from Linux - commit 30ecad51849ae132dc6ef6ddb62d499c7257515b Include config file to ignore common false-positives Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de>
