path: root/tools
2016-10-24tools: moveconfig: support wildcards in --defconfigs fileMasahiro Yamada
Supporting shell-style wildcards for the --defconfigs option will be useful to run the moveconfig tool against a specific platform. For example, "uniphier*" in the file passed by --defconfigs option will be expanded to defconfig files that start with "uniphier". This is easier than listing out all defconfig files you are interested in. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2016-10-14pbl: use "wait" command instead of "flush" commandZhao Qiang
PBL flush command is restricted to CCSR memory space. So use WAIT PBI command to provide enough time for data to get flush in target memory. Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com> [York Sun: rewrap commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-09tools: buildman: Add compiler wrapperYork Sun
Now we can use compiler wrapper such as ccache or distcc for buildman. Signed-off-by: York Sun <york.sun@nxp.com> CC: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09tools: buildman: Remove duplicated codeYork Sun
Signed-off-by: York Sun <york.sun@nxp.com> CC: Simon Glass <sjg@chromium.org> Fixed commit subject: Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09dtoc: Make integer division python 3.x safePaul Burton
If we use the '/' operator then python 3.x will produce a float, and refuse to multiply the string sequence in Conv_name_to_c by it with: TypeError: can't multiply sequence by non-int of type 'float' Use the '//' operator instead to enforce that we want integer rather than floating point division. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09dtoc: Decode strings for struct.unpack on python 3.xPaul Burton
On python 3.x struct.unpack will complain if we provide it with a string since it expects to operate on a bytes object. In order to satisfy this requirement, encode the string to a bytes object when running on python 3.x. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09dtoc: Use items() to iterate over dictionaries in python 3.xPaul Burton
In python 3.x the iteritems() method has been removed from dictionaries, and the items() method does effectively the same thing. On python 2.x using items() is a little less efficient since it involves copying data, but as speed isn't a concern in the affected code switch to using items() anyway for simplicity. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09patman: Fix doctest StringIO import for python 3.xPaul Burton
In python 3.x StringIO is no longer a module, and the class can instead be found in the io module. Adjust the code in the doctest input to account for both. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09patman: Use items() to iterate over dictionariesPaul Burton
In python 3.x the iteritems() method has been removed from dictionaries, and the items() method does effectively the same thing. On python 2.x using items() is a little less efficient since it involves copying data, but as speed isn't a concern in this code switch to using items() anyway for simplicity. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09patman: Import 'configparser' lower case to be python 3.x safePaul Burton
In python 3.x module names used in import statements are case sensitive, and the configparser module is named in all lower-case. Import it as such in order to avoid errors when running with python 3.x. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09patman: Make exception handling python 3.x safePaul Burton
Syntax for exception handling is a little more strict in python 3.x. Convert all uses to a form accepted by both python 2.x & python 3.x. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09patman: Make print statements python 3.x safePaul Burton
In python 3.x, print must be used as a function call. Convert all print statements to the function call style, importing from __future__ where we print with no trailing newline or print to a file object. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09patman: Replace tabs with spacesPaul Burton
In preparation for running on python 3.x, which will refuse to run scripts which mix tabs & spaces for indentation, replace 2 tab characters present in series.py with spaces. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09dtoc: Add a way for tests to request the fallback librarySimon Glass
We need to test both the normal (Python libfdt module) and fallback (fdtget) implementations of the Fdt class. Add a way to select which implementation to use. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09dtoc: Adjust GetProps() in fdt_normal to use the node pathSimon Glass
There is no need to pass a node path separately. Instead we should use the path for the node provided. Correct this. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09dtoc: Fix bug in GetProp()Simon Glass
This does not actually call fdtget correctly when requesting a particular type. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09buildman: Drop the 'alive' flag in BuilderThreadSimon Glass
This is not used, so drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09buildman: Don't show a stacktrace on Ctrl-CSimon Glass
When Ctrl-C is pressed, just exited quietly. There is no sense in displaying a stack trace since buildman will always be in the same place: waiting for threads to complete building all the jobs on the queue. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09buildman: Drop the 'active' flag in the builderSimon Glass
This serves no real purpose, since when we are not active, we exit. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09buildman: Allow builds to terminate cleanlySimon Glass
It is annoying that buildman does not respond cleanly to Ctrl-C or SIGINT, particularly on machines with lots of CPUS. Unfortunately queue.join() blocks the main thread and does not allow it to see the signal. Use a separate thread instead, Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09buildman: Put our local libraries first in the pathSimon Glass
If patman is installed on the machine (e.g. in the standard dist-packages directory), it will find libraries from there in preference to our local libraries. Adjust the order of the path to ensure that local libraries are found first. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09buildman: Print a message indicating the build is startingSimon Glass
Make it clear when buildman actually starts building. This happens when it has prepared the threads, working directory and output directories. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09buildman: Print a message when removing old directoriesSimon Glass
When buildman starts, it prepares its output directory by removing any old build directories which will not be used this time. This can happen if a previous build left directories around for commit hashes which are no-longer part of the branch. This can take quite a while, so print a message to indicate what is going on. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09buildman: Tidy up the 'cloning' messageSimon Glass
On a machine with a lot of CPUs this prints a lot of useless lines of the form: Cloning repo for thread <n> Adjust the output so that these all appear on one line, and disappear when the cloning is complete. Note: This cloning is actually unnecessary and very wasteful on disk space (about 3.5GB each time). It would be better to create symlinks. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09patman: Flush output when there is no newlineSimon Glass
Output which does not include a newline will not be displayed unless flushed. Add a flush to ensure that it becomes visible. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-08Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2016-10-08env: tool: add command line option to input lockfile pathB, Ravi
The default lockname is set to /var/lock. This limits the usage of this application where OS uses different lockfile location parameter. For example, In case of android, the default lock path location is /data. Hence by providing the command line option to input lockfile path will be useful to reuse the tool across multiple operating system. usage: ./fw_printenv -l <lockfile path> Signed-off-by: Ravi Babu <ravibabu@ti.com>
2016-10-06Various, accumulated typos collected from around the tree.Robert P. J. Day
Fix various misspellings of: * deprecated * partition * preceding,preceded * preparation * its versus it's * export * existing * scenario * redundant * remaining * value * architecture Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Stefan Roese <sr@denx.de>
2016-10-06Suspected Spam: Do not open attachements![PATCH 4/6] tools/env: ↵Andreas Fenkart
flash_write_buf: enforce offset to be start of environment This allows to take advantage of the environment being block aligned. This is not a new constraint. Writes always start at the begin of the environment, since the header with CRC/length as there. Every environment modification requires updating the header Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-10-06tools/env: lookup dev_type directly from flash_read_buf/flash_write_bufAndreas Fenkart
flash_write_buf already looks up size/offset/#sector from struct envdev_s. It can look up mtd_type as well. Same applies to flash_read_buf. Makes the interface simpler Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-10-06tools/env: pass bad block offset by valueAndreas Fenkart
the offset is not modified by linux ioctl call see mtd_ioctl{drivers/mtd/mtdchar.c} Makes the interface less ambiguous, since the caller can now exclude a modification of blockstart Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-10-06tools/env: factor out environment_end functionAndreas Fenkart
instead of adhoc computation of the environment end, use a function with a proper name Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-10-06tools: mkimage: add support for Vybrid image formatAlbert ARIBAUD \(3ADEV\)
This format can be flashed directly at address 0 of the NAND FLASH, as it contains all necessary headers. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2016-09-18dtoc: Add methods for reading data from propertiesSimon Glass
Provide easy helpers for reading integer, string and boolean values from device-tree properties. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-18dtoc: Correct quotes in fdt_utilSimon Glass
The style is to use single quotes for strings where possible. Adjust this function. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-18dtoc: Support finding the offset of a propertySimon Glass
Add a way to find the byte offset of a property within the device tree. This is only supported with the normal libfdt implementation since fdtget does not provide this information. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-18dtoc: Support packing the device treeSimon Glass
After any node/property deletion the device tree can be packed to remove spare space. Add a way to perform this operation. Note that for fdt_fallback, fdtput automatically packs the device tree after deletion, so no action is required here. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-18dtoc: Support deleting device tree propertiesSimon Glass
Add support for deleting a device tree property. With the fallback implementation this uses fdtput. With libfdt it uses the API call and updates the offsets afterwards. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-18dtoc: Move to using bytearraySimon Glass
Since we want to be able to change the in-memory device tree using libfdt, use a bytearray instead of a string. This makes interfacing from Python easier. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-18dtoc: Prepare for supporting changing of device treesSimon Glass
For binman we need to support deleting properties in the device tree. This will change the offsets of nodes after the deletion. In preparation, add code to keep track of when the offsets are invalid, and regenerate them. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-18dtoc: Drop the convert_dash parameter to GetProps()Simon Glass
This is not used anywhere in dtoc, so drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-18dtoc: Allow the device tree to be compiled from sourceSimon Glass
If a source device tree is provide to the Fdt() constructors, compile it automatically. This will be used in tests, where we want to build a particular test .dts file and check that it works correctly in binman. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-18patman: Add a library to handle logging and progressSimon Glass
When tools want to display information of varying levels of importance, it helps to provide the user with control over the verbosity of these messages. Progress messages work best if they are displayed and then removed from the display when no-longer relevant. Add a new tout library (terminal out) to handle these tasks. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-18patman: Add a tools library for using temporary filesSimon Glass
For tools which want to use input files and temporary output, it is useful to have the handling of these dealt with in one place. Add a new library which allows input files to be read, and output files to be written, all based on a common directory structure. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-18dtoc: Move a few more common functions into fdt.pySimon Glass
Some functions have the same code in the subclasses. Move these into the superclass to avoid duplication. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-18dtoc: Move Widen() and GetPhandle() into the base classSimon Glass
These functions are identical in both subclasses. Move them into the base class. Note: In fact there is a bug in one version, which was fixed by this patch: https://patchwork.ozlabs.org/patch/651697/ Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-18dtoc: Move BytesToValue() and GetEmpty() into PropBaseSimon Glass
These functions are currently in a separate fdt_util file. Since they are only used from PropBase and subclasses, it makes sense for them to be in the PropBase class. Move these functions into fdt.py along with the list of types. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-18dtoc: Create a base class for FdtSimon Glass
At present we have two separate implementations of the Fdt library, one which uses fdtget/fdtput and one which uses libfdt (via swig). Before adding more functionality it makes sense to create a base class for these. This will allow common functions to be shared, and make the Fdt API a little clearer. Create a new fdt.py file with the base class, and adjust fdt_normal.py and fdt_fallback.py to use it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-18dtoc: Rename fdt.py to fdt_normal.pySimon Glass
In preparation for creating an Fdt base class, rename this file to indicate it is the normal Fdt implementation. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-18dtoc: Move the fdt library selection into fdt_selectSimon Glass
Rather than have dtc worry about which fdt library to use, move this into a helper file. Add a function which creates a new Fdt object and scans it, regardless of the implementation. Signed-off-by: Simon Glass <sjg@chromium.org>
