path: root/tools
2008-09-09fw_env: add NAND supportGuennadi Liakhovetski
Add support for environment in NAND with automatic NOR / NAND recognition, including unaligned environment, bad-block skipping, redundant environment copy. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-09-02fw_env.c: fix build problems with MTD_VERSION=oldWolfgang Denk
(as needed to support old 2.4 Linux kernel based releases) Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-08-18Add 'license' command to U-Boot command lineHarald Welte
The 'license' command includes the U-Boot license (GPLv2) into the actual bootloader binary. The license text can be shown interactively at the U-Boot commandline. For products where the commandline can actually be accessed by the end user, this helps to prevent inadvertent GPL violations, since the GPLv2 license text can no longer be 'forgotten' to be included into the product. The 'license' command can be enabled by CONFIG_CMD_LICENSE. Signed-off-by: Harald Welte <laforge@openmoko.org>
2008-07-15tools/gitignore: update to all generated filesJean-Christophe PLAGNIOL-VILLARD
2008-07-14Code cleanup: fix old style assignment ambiguities like "=-" etc.Wolfgang Denk
2008-07-11Fixed some out-of-tree build issuesWolfgang Denk
2008-07-02Add logos for RRvision boardGary Jennejohn
Signed-off-by: Gary Jennejohn <garyj@denx.de>
2008-05-24Merging Stelian Pop AT91 patchesJean-Christophe PLAGNIOL-VILLARD
Merge branch 'testing-V2' Conflicts: board/atmel/at91cap9adk/Makefile Fixing copyright board/atmel/at91sam9260ek/Makefile Fixing copyright board/atmel/at91sam9260ek/u-boot.lds Delete no more needed ld script Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10Use custom logo for Atmel boardsStelian Pop
This patch adds a custom vendor logo for the Atmel AT91 boards. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-09Propagate Error Status to the Shell on fw_printenv ErrorsGrant Erickson
Changed implementation such that fw_printenv returns failure status when one or more specified variables do not exist or when incorrect command syntax is used. This aids scripting fw_printenv such that the script can key of the return status rather than relying on standard error "scraping". Signed-off-by: Grant Erickson <gerickson@nuovations.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-05-09Fix Compilation Errors with 'tools/env/fw_printenv'Grant Erickson
In the current top-of-tree, 1.3.3.-rc2, the optional tool 'tools/env/fw_printenv' fails to compile for two reasons: 1) The header watchdog.h cannot be found. 2) The header zlib.h is picked up from the tool chain rather than the project causing a prototype conflict for crc32. This patch addresses both of these issues. Platforms Tested On: - AMCC "Kilauea" Signed-off-by: Grant Erickson <gerickson@nuovations.com>
2008-05-03mkimage: make mmap() checks consistentMike Frysinger
The mmap() related code is full of inconsistent casts/constants when it comes to error checking, and may break when building on some systems (like ones that do not implicitly define the caddr_t type). Let's just avoid the whole mess by writing the code nice and clean in the first place. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-04-29Update .gitignore for zlib.hKumar Gala
2008-04-24Memory footprint optimizationsBartlomiej Sieka
As suggested by Wolfgang Denk: - image printing functions: - remove wrappers - remove indentation prefix from functions' signatures - merge getenv_verify and getenv_autostart into one parametrized function Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-04-24crc32: use uint32_t rather than unsigned longMike Frysinger
The envcrc.c does sizeof(unsigned long) when calculating the crc, but this is done with the build toolchain instead of the target tool chain, so if the build is a 64bit system but the target is 32bits, the size will obviously be wrong. This converts all unsigned long stuff related to crc32 to uint32_t types. Compile tested only: output of ./tools/envcrc when run on a 32bit build system matches that of a 64bit build system. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-04-18Add support for u-boot in svn and localversion-* filesMike Frysinger
2008-03-27Fix out of tree building issueAnatolij Gustschin
Currently U-Boot building in some external directory doesn't work. This patch tries to fix the problem. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-03-26Merge branch 'new-image' of git://www.denx.de/git/u-boot-testingBartlomiej Sieka
Conflicts: common/cmd_bootm.c cpu/mpc8xx/cpu.c Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-03-14Add MD5 support to the new uImage formatBartlomiej Sieka
2008-03-14tools/setlocalversion: use a git-describe-ish formatWolfgang Denk
Change the automatic local version to have the form -nnnnn-gSHA1SUMID, where 'nnnnn' is the number of commits since the last tag (i.e., 1.3.2-rc3). This makes it much easier to recognize "newer" versions and to see how much has been changed since the referenced tag. Stolen from Linux kernel's scripts/setlocalversio, see commit d882421f. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-03-11[new uImage] Add support for new uImage format to mkimage toolBartlomiej Sieka
Support for the new uImage format (FIT) is added to mkimage tool. Commandline syntax is appropriately extended: mkimage [-D dtc_options] -f fit-image.its fit-image mkimage (together with dtc) takes fit-image.its and referenced therein binaries (like vmlinux.bin.gz) as inputs, and produces fit-image file -- the final image that can be transferred to the target (e.g., via tftp) and then booted using the bootm command in U-Boot. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-03-10[new uImage] New uImage low-level APIMarian Balakowicz
Add FDT-based functions for handling new format component images, configurations, node operations, property get/set, etc. fit_ - routines handling global new format uImage operations like get/set top level property, process all nodes, etc. fit_image_ - routines handling component images subnodes fit_conf_ - routines handling configurations node Signed-off-by: Bartlomiej Sieka <tur@semihalf.com> Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Add libfdt support to mkimageBartlomiej Sieka
2008-02-29[new uImage] Add sha1.o object to mkimage binary buildBartlomiej Sieka
2008-02-29[new uImage] Share common uImage code between mkimage and U-bootMarian Balakowicz
This patch adds the following common routines: 1) Dedicated mkimage print_header() is replaced with common image_print_contents() image_print_contents_noindent() 2) Common os/arch/type/comp fields name <--> id translation routines genimg_get_os_name() genimg_get_arch_name() genimg_get_type_name() genimg_get_comp_name() genimg_get_os_id() genimg_get_arch_id() genimg_get_type_id() genimg_get_comp_id() Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Update naming convention for bootm/uImage related codeMarian Balakowicz
This patch introduces the following prefix convention for the image format handling and bootm related code: genimg_ - dual format shared code image_ - legacy uImage format specific code fit_ - new uImage format specific code boot_ - booting process related code Related routines are renamed and a few pieces of code are moved around and re-grouped. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29Merge branch 'master' of git://www.denx.de/git/u-boot into new-imageMarian Balakowicz
2008-02-22make define2mk.sed work on FreeBSDMarcel Moolenaar
In the thread "[1.3.2-rc1] MPC8548CDS/MPC8555CDS configs fails to link", the define2mk.sed script was identified as the source of the link failure on FreeBSD. The problem is that sed(1) does not always support the '+' operator. It isn't on FreeBSD. The attach patch implements the equivalent, using the '*' operator instead and should work everywhere. Signed-off-by: Marcel Moolenaar <marcelm@juniper.net>
2008-02-22easylogo: clean up some more and add -r (rgb) supportMike Frysinger
Michael Hennerich added support for outputting an image in RGB format rather than forcing YUYV all the time. This makes obvious sense if the display you have takes RGB input rather than YUYV. Rather than hack in support for options, I've converted it to use getopt and cleaned up the argument parsing in the process. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-02-21Merge branch 'master' of /home/git/u-bootMarian Balakowicz
2008-02-07[new uImage] Define a API for image handling operationsMarian Balakowicz
- Add inline helper macros for basic header processing - Move common non inline code common/image.c - Replace direct header access with the API routines - Rename IH_CPU_* to IH_ARCH_* Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-04add the default Blackfin logo used by Blackfin boards with splash screensMike Frysinger
2008-01-09Do not reference sha1.c when building mkimage.Mike Frysinger
remove sha1.o from mkimage linking since it isn't actually used. Signed-Off-By: Mike Frysinger <vapier@gentoo.org>
2008-01-09Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-01-09fix easylogo on big endian dev systemsMike Frysinger
didnt realize how out of shape easylogo actually was until i tried using it. this patch does byte swapping as need be on the input tga header since the tga is in little endian but the host could just as well be big endian. i didnt bother using bswap macros or such stuff from system headers as nothing in POSIX dictates byte swapping functionality. Signed-Off-By: Mike Frysinger <vapier@gentoo.org>
2008-01-09cleanup easylogoMike Frysinger
- make the Makefile not suck - include proper headers for prototypes - fix obvious broken handling of strchr() when handling '.' in filenames Signed-Off-By: Mike Frysinger <vapier@gentoo.org>
2008-01-09Fix build problems under Cygwinraptorbrino@aim.com
This patch allows u-boot to build without error in a cygwin environment. Cygwin does not define __u64 in it's include/asm/types.h file. The -idirafter flag in the u-boot build causes the inclusion of the cygwin types.h file as opposed to u-bot/include/asm/types.h file which does define __u64. Subsequently, sha1.c compile fails due to unknown symbol. Signed-off-by: Brian Miller <raptorbrino@netscape.net>
2008-01-09Fix compile problem with new env code.Wolfgang Denk
2008-01-09tools: fix fw_printenv tool to compile againMarkus Klotzbücher
This patch updates the fw_printenv/fw_setenv userspace tool to include the correct MTD header in order to compile against current kernel headers. Backward compatibility is preserved by introducing an option MTD_VERSION which can be set to "old" for compilation using the old MTD headers. Along with this a number of warnings are fixed. Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2007-11-20[BUILD] Generate include/autoconf.mk from board config filesGrant Likely
Use cpp and sed to postprocess config.h and import the defined values into include/autoconf.mk. autoconf.mk is then included by config.mk to give 'make' access to the board configuration. Doing this enables conditional compilation at the Makefile level instead of by wrapping every .c file with #ifdef/#endif wrappers. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-15Add .gitignore filesGrant Likely
Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-03Merge branch 'testing' into workingAndy Fleming
Conflicts: CHANGELOG fs/fat/fat.c include/configs/MPC8560ADS.h include/configs/pcs440ep.h net/eth.c
2007-07-10disk/ doc/ lib_*/ and tools/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09tools/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-10Coding style cleanup; update CHANGELOG.Wolfgang Denk
2007-07-09Merge with /home/hs/Atronic/u-bootWolfgang Denk
2007-07-04tools/ : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-06-22[PCS440EP] upgrade the PCS440EP board:Heiko Schocher
- Show on the Status LEDs, some States of the board. - Get the MAC addresses from the EEProm - use PREBOOT - use the CF on the board. - check the U-Boot image in the Flash with a SHA1 checksum. - use dynamic TLB entries generation for the SDRAM Signed-off-by: Heiko Schocher <hs@denx.de>
2007-05-15Fix compilation issues on MACOSXAubrey.Li
Singed-off-by: Marc Hoffman <Marc.Hoffman@analog.com> Signed-off-by: Aubrey Li <aubrey.adi@gmail.com>
