As suggested by Wolfgang Denk:
- image printing functions:
- remove wrappers
- remove indentation prefix from functions' signatures
- merge getenv_verify and getenv_autostart into one parametrized function
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
The envcrc.c does sizeof(unsigned long) when calculating the crc, but
this is done with the build toolchain instead of the target tool
chain, so if the build is a 64bit system but the target is 32bits,
the size will obviously be wrong. This converts all unsigned long
stuff related to crc32 to uint32_t types. Compile tested only: output
of ./tools/envcrc when run on a 32bit build system matches that of a
64bit build system.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Currently U-Boot building in some external directory
doesn't work. This patch tries to fix the problem.
common/cmd_bootm.c
cpu/mpc8xx/cpu.c
Change the automatic local version to have the form -nnnnn-gSHA1SUMID,
where 'nnnnn' is the number of commits since the last tag (i.e.,
1.3.2-rc3). This makes it much easier to recognize "newer" versions
and to see how much has been changed since the referenced tag.
Stolen from Linux kernel's scripts/setlocalversio, see commit d882421f.
Support for the new uImage format (FIT) is added to mkimage tool.
Commandline syntax is appropriately extended:
mkimage [-D dtc_options] -f fit-image.its fit-image
mkimage (together with dtc) takes fit-image.its and referenced therein
binaries (like vmlinux.bin.gz) as inputs, and produces fit-image file -- the
final image that can be transferred to the target (e.g., via tftp) and then
booted using the bootm command in U-Boot.
Add FDT-based functions for handling new format component images,
configurations, node operations, property get/set, etc.
fit_ - routines handling global new format uImage operations
like get/set top level property, process all nodes, etc.
fit_image_ - routines handling component images subnodes
fit_conf_ - routines handling configurations node
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
This patch adds the following common routines:
1) Dedicated mkimage print_header() is replaced with common
image_print_contents()
image_print_contents_noindent()
2) Common os/arch/type/comp fields name <--> id translation routines
genimg_get_os_name()
genimg_get_arch_name()
genimg_get_type_name()
genimg_get_comp_name()
genimg_get_os_id()
genimg_get_arch_id()
genimg_get_type_id()
genimg_get_comp_id()
This patch introduces the following prefix convention for the
image format handling and bootm related code:
genimg_ - dual format shared code
image_ - legacy uImage format specific code
fit_ - new uImage format specific code
boot_ - booting process related code
Related routines are renamed and a few pieces of code are moved around and
re-grouped.
In the thread "[1.3.2-rc1] MPC8548CDS/MPC8555CDS configs fails to link",
the define2mk.sed script was identified as the source of the link
failure on FreeBSD. The problem is that sed(1) does not always support
the '+' operator. It isn't on FreeBSD. The attach patch implements the
equivalent, using the '*' operator instead and should work everywhere.
Signed-off-by: Marcel Moolenaar <marcelm@juniper.net>
Michael Hennerich added support for outputting an image in RGB format rather
than forcing YUYV all the time. This makes obvious sense if the display you
have takes RGB input rather than YUYV.
Rather than hack in support for options, I've converted it to use getopt and
cleaned up the argument parsing in the process.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
- Add inline helper macros for basic header processing
- Move common non inline code common/image.c
- Replace direct header access with the API routines
- Rename IH_CPU_* to IH_ARCH_*
remove sha1.o from mkimage linking since it isn't actually used.
Signed-Off-By: Mike Frysinger <vapier@gentoo.org>
didnt realize how out of shape easylogo actually was until i tried using it.
this patch does byte swapping as need be on the input tga header since the tga
is in little endian but the host could just as well be big endian. i didnt
bother using bswap macros or such stuff from system headers as nothing in
POSIX dictates byte swapping functionality.
- make the Makefile not suck
- include proper headers for prototypes
- fix obvious broken handling of strchr() when handling '.' in filenames
This patch allows u-boot to build without error in a cygwin
environment. Cygwin does not define __u64 in it's
include/asm/types.h file. The -idirafter flag in the u-boot
build causes the inclusion of the cygwin types.h file as opposed
to u-bot/include/asm/types.h file which does define __u64.
Subsequently, sha1.c compile fails due to unknown symbol.
Signed-off-by: Brian Miller <raptorbrino@netscape.net>
This patch updates the fw_printenv/fw_setenv userspace tool to include
the correct MTD header in order to compile against current kernel
headers. Backward compatibility is preserved by introducing an option
MTD_VERSION which can be set to "old" for compilation using the old MTD
headers. Along with this a number of warnings are fixed.
Signed-off-by: Markus Klotzbuecher <mk@denx.de>
Use cpp and sed to postprocess config.h and import the defined values
into include/autoconf.mk. autoconf.mk is then included by config.mk to
give 'make' access to the board configuration.
Doing this enables conditional compilation at the Makefile level instead
of by wrapping every .c file with #ifdef/#endif wrappers.
Acked-by: Kim Phillips <kim.phillips@freescale.com>
CHANGELOG
fs/fat/fat.c
include/configs/MPC8560ADS.h
include/configs/pcs440ep.h
net/eth.c
Fixed some broken instances of "#ifdef CMD_CFG_IDE" too.
Those always evaluated TRUE, and thus were always compiled
even when IDE really wasn't defined/wanted.
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
- Show on the Status LEDs, some States of the board.
- Get the MAC addresses from the EEProm
- use PREBOOT
- use the CF on the board.
- check the U-Boot image in the Flash with a SHA1
checksum.
- use dynamic TLB entries generation for the SDRAM
Singed-off-by: Marc Hoffman <Marc.Hoffman@analog.com>
Signed-off-by: Aubrey Li <aubrey.adi@gmail.com>
Make it possible to generate AVR32 uImage files with mkimage and
make cmd_bootm recognize them.
Patch by Haavard Skinnemoen, 22 Sep 2006
Patch by David Updegraff, 06 Sep 2006
Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
Signed-off-by: Matthew McClintock <msm@freescale.com>
Patch by Murray Jensen, 15 Jul 2005
- add support for Analog Devices Blackfin BF533 CPU
- add support for the ADI BF533 Stamp uClinux board
- add support for the ADI BF533 EZKit board
Patches by Richard Klingler, June 11th 2005:
As done in the linux kernel, the U-Boot version (U_BOOT_VERSION)
of all unreleased (untagged) U-Boot images will be automatically
extended upon compiletime with a part of the GIT commit ID and
possibly with "dirty" if uncommited changes are detected.
Here an example for the resulting version:
"U-Boot 1.1.4-g3457ac18-dirty"
The version is now maintained in the toplevel Makefile and the
version headers are autogenerated.
Patch by Stefan Roese, 9 Feb 2006
