path: root/tools
2013-04-04patman: Minor help message/README fixesSimon Glass
A few of the help messages are not quite right, and there is a typo in the README. Fix these. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Doug Anderson <dianders@chromium.org>
2013-04-04patman: Fix the comment in CheckTags to mention multiple tagsSimon Glass
This comment is less than helpful. Since multiple tags are supported, add an example of how multiple tags work. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Doug Anderson <dianders@chromium.org>
2013-04-04patman: Don't allow spaces in tagsSimon Glass
At present something like: Revert "arm: Add cache operations" will try to use Revert "arm as a tag. Clearly this is wrong, so fix it. If the revert is intended to be tagged, then the tag can come before the revert, perhaps. Alternatively the 'Cc' tag can be used in the commit messages. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Doug Anderson <dianders@chromium.org>
2013-04-04patman: Fix up checkpatch parsing to deal with 'CHECK' linesSimon Glass
checkpatch has a new type of warning, a 'CHECK'. At present patman fails with these, which makes it less than useful. Add support for checks, making it backwards compatible with the old checkpatch. At the same time, clean up formatting of the CheckPatches() output, fix erroneous "internal error" if multiple patches have warnings and be more robust to new types of problems. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Doug Anderson <dianders@chromium.org>
2013-04-04patman: Add Cover-letter-cc tag to Cc cover letter to peopleSimon Glass
The cover letter is sent to everyone who is on the Cc list for any of the patches in the series. Sometimes it is useful to send just the cover letter to additional people, so that they are aware of the series, but don't need to wade through all the individual patches. Add a new Cover-letter-cc tag for this purpose. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Doug Anderson <dianders@chromium.org>
2013-04-04patman: Allow specifying the message ID your series is in reply toDoug Anderson
Some versions of git don't seem to prompt you for the message ID that your series is in reply to. Allow specifying this from the command line. Signed-off-by: Doug Anderson <dianders@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-04-04patman: Make "Reviewed-by" an important tagDoug Anderson
Although "Reviewed-by:" is a tag that gerrit adds, it's also a tag used by upstream. Stripping it is undesirable. In fact, we should treat it as important. Signed-off-by: Doug Anderson <dianders@chromium.org> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Simon Glass <sjg@chromium.org>
2013-04-04patman: Add additional git utiltiesSimon Glass
Add methods to find out the commits in a branch, clone a repo and fetch from a repo. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-04-04patman: Allow reading metadata from a list of commitsSimon Glass
We normally read from the current branch, but buildman will need to look at commits from another branch. Allow the metadata to be read from any list of commits, to provide this flexibility. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-04-04patman: Allow commands to raise on error, or notSimon Glass
Make raise_on_error a parameter so that we can control which commands raise and which do not. If we get an error reading the alias file, just continue. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-04-04patman: Make command methods return a CommandResultSimon Glass
Rather than returning a list of things, return an object. That makes it easier to access the returned items, and easier to extend the return value later. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-04-04patman: Add cros_subprocess library to manage subprocessesSimon Glass
This adds a new library on top of subprocess which permits access to the subprocess output as it is being generated. We can therefore give the illusion that a process is running independently, but still monitor its output so that we know what is going on. It is possible to display output on a terminal as it is generated (a little like tee). The supplied output function is called with all stdout/stderr data as it arrives. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-04-04patman: Use bright ANSI colours by defaultSimon Glass
Rather than the rather dull colours, use bright versions which normally look better and are easier to read. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-04-04patman: Use ANSI colours only when outputting to a terminalSimon Glass
It is easy to detect whether or not the process is connected to a terminal, or piped to a file. Disable ANSI colours automatically when output is not to a terminal. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-27checkpatch.pl: Add 'debug' to the list of logFunctionsTom Rini
While the kernel mainly uses pr_debug(...), etc, for debug messages, we use debug(...). Add this to the list of logFunctions so that they are correctly checked (and not warned against) for long string literals. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-11env: Allow accessing non-mtd devicesLubomir Rintel
In certain cases, memory device is present as flat file or block device (via mmc or mtdblock layer). Do not attempt MTD operations against it. Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
2013-03-11Fix a couple typoes in tools/env/READMERobert P. J. Day
2013-03-11tools: update checkpatch to latest upstream versionKim Phillips
i.e., from the linux kernel's commit be987d9f80354e2e919926349282facd74992f90 Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2013-02-19fw_env.config: Correct "fw_saveenv" to "fw_setenv".Robert P. J. Day
Fix a comment in the fw_env.config file, no functional change. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2013-02-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-02-07treewide: include libfdt_env.h before fdt.hKim Phillips
and, if including libfdt.h which includes libfdt_env.h in the correct order, don't include fdt.h before libfdt.h. this is needed to get the fdt type definitions set from the project environment before fdt.h uses them. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Jerry Van Baren <gvb.uboot@gmail.com>
2013-01-31patman: Allow use outside of u-boot treeVadim Bendebury
To make it usable in git trees not providing a patch checker implementation, add a command line option, allowing to suppress patch check. While we are at it, sort debug options alphabetically. Also, do not raise an exception if checkpatch.pl is not found - just print an error message suggesting to use the new option, and return nonzero status. . unit test passes: $ ./patman -t <unittest.result.TestResult run=7 errors=0 failures=0> . successfully used patman in the autotest tree to generate a patch email (with --no-check option) . successfully used patman in the u-boot tree to generate a patch email . `patman --help' now shows command line options ordered alphabetically Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Acked-by: Doug Anderson <dianders@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-01-31patman: Add settings to the list of modules to doctestDoug Anderson
The settings modules now has doctests, so run them. Signed-off-by: Doug Anderson <dianders@chromium.org>
2013-01-31patman: Add the concept of multiple projectsDoug Anderson
There are cases that we want to support different settings (or maybe even different aliases) for different projects. Add support for this by: * Adding detection for two big projects: U-Boot and Linux. * Adding default settings for Linux (U-Boot is already good with the standard patman defaults). * Extend the new "settings" feature in .patman to specify per-project settings. Signed-off-by: Doug Anderson <dianders@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-01-31patman: Add support for settings in .patmanDoug Anderson
This patch adds support for a [settings] section in the .patman file. In this section you can add settings that will affect the default values for command-line options. Support is added in a generic way such that any setting can be updated by just referring to the "dest" of the option that is passed to the option parser. At the moment options that would make sense to put in settings are "ignore_errors", "process_tags", and "verbose". You could override them like: [settings] ignore_errors: True process_tags: False verbose: True The settings functionality is also used in a future change which adds support for per-project settings. Signed-off-by: Doug Anderson <dianders@chromium.org>
2013-01-31patman: Add a call to get_maintainer.pl if it existsDoug Anderson
For Linux the best way to figure out where to send a patch is with the "get_maintainer.pl" script. Add support for calling it from patman. Support is added unconditionally for "scripts/get_maintainer.pl" in case it is helpful for any other projects. Signed-off-by: Doug Anderson <dianders@chromium.org>
2013-01-31patman: Add all CC addresses to the cover letterDoug Anderson
If we're sending a cover letter make sure to CC everyone that we're CCing on each of the individual patches. Signed-off-by: Doug Anderson <dianders@chromium.org>
2013-01-31patman: Cache the CC list from MakeCcFile() for use in ShowActions()Doug Anderson
Currently we go through and generate the CC list for patches twice. This gets slow when (in a future CL) we add a call to get_maintainer.pl on Linux. Instead of doing things twice, just cache the CC list when it is first generated. Signed-off-by: Doug Anderson <dianders@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-01-31patman: Look for checkpatch in the scripts directoryDoug Anderson
The Linux kernel stores checkpatch.pl in the scripts directory. Add that to the search path to make things more automatic for kernel development. Signed-off-by: Doug Anderson <dianders@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-01-31patman: Allow tests to run even if patman is in the pathDoug Anderson
Several of the patman doctests assume that patman was run with: ./patman Fix them so that they work even if patman is run with just "patman" (because patman is in the path). Signed-off-by: Doug Anderson <dianders@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-01-31patman: Add spaces back into patman testDoug Anderson
The patman test code was failing because some extra spaces got stripped when it was applied. These spaces are critical to the test code working. Signed-off-by: Doug Anderson <dianders@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-01-28tools: imximage: Let .name field be more genericFabio Estevam
Since this structure is not i.MX5x specific, remove the '5x' to make it more generic. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-01-21mx23: config: Enable mxsboot tool for i.MX23 based boardsOtavio Salvador
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2013-01-08Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-01-08Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-01-05tools: imximage: Load a size that is multiple of 512Fabio Estevam
In order to mx53 ROM to properly load the U-boot image, its header size should be multiple of 512 bytes. This issue was observed with gcc 4.6.2/4.7.3, which caused data aborts: U-Boot 2013.01-rc2-00172-gf8cfcf1-dirty (Dec 26 2012 - 13:13:28) Board: MX53 LOCO I2C: ready DRAM: 1 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 In: serial Out: serial Err: serial CPU: Freescale i.MX53 family rev2.1 at 1000 MHz Reset cause: WDOG Net: FEC Warning: FEC using MAC address from net device Hit any key to stop autoboot: 0 data abort MAYBE you should read doc/README.arm-unaligned-accesses pc : [<aff72220>] lr : [<aff721fc>] sp : af565e20 ip : af566918 fp : 00000000 r10: 00000003 r9 : affabb5b r8 : af565f58 r7 : 00000000 r6 : 36747fff r5 : af5668e8 r4 : 36747fff r3 : af5668ec r2 : af5668eb r1 : 00000000 r0 : af5668e8 Flags: NzcV IRQs off FIQs off Mode SVC_32 Resetting CPU ... resetting ... ,and this patch fixes it. Also, even though the ROUND macro is already defined in common.h, the reason for redefining it in image.h is explained by Stefano Babic: "I will remark a previous comment - even if including common.h seems a good idea to avoid duplications, it makes tools like mkimage to depend on the selected board, because <board>_config must run. Even if this is not a problem for us u-boot developers, it becomes an issue when these tools are included in distros (like u-boot-tools in Ubuntu) and cannot be packaged." Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-12-20Revert "fw_env: fix building w/out a config.h"Tom Rini
I had missed Joe's NAK on this patch, so... This reverts commit 92ace272d06cec1d7f1533bb9edf914fb5845fba. Signed-off-by: Tom Rini <trini@ti.com>
2012-12-19fw_env: fix building w/out a config.hMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
2012-12-19fw_env: fix incorrect usage of open(O_CREAT)Mike Frysinger
When using open(), the O_CREAT flag must be given a mode, otherwise it uses random garbage from the stack. Also, it can fail to build: In file included from /usr/include/fcntl.h:290:0, from fw_env_main.c:42: In function 'open', inlined from 'main' at fw_env_main.c:97:9: /usr/include/bits/fcntl2.h:50:24: error: call to '__open_missing_mode' declared with attribute error: open with O_CREAT in second argument needs 3 arguments Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-19fw_env: fix type of lenMike Frysinger
This variable is assigned by a size_t, and is printed that way, but is incorrectly declared as an int. Which means we get warnings: fw_env.c: In function 'fw_setenv': fw_env.c:409:5: warning: format '%zu' expects argument of type 'size_t', but argument 3 has type 'int' [-Wformat] Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Handle write-once ethaddr and serial# genericallyJoe Hershberger
Use the variable access flags to implement the protection for ethaddr and serial# instead of hard-coding them. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Add support for access control to .flagsJoe Hershberger
Add support for read-only, write-once, and change-default. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13tools/env: Add environment variable flags supportJoe Hershberger
Currently just validates variable types as decimal, hexidecimal, boolean, ip address, and mac address. Call env_acl_validate_setenv_params() from setenv() in fw_env.c. If the entry is not found in the env .flags, then look in the static one. This allows the env to override the static definitions, but prevents the need to have every definition in the environment distracting you. Need to build in _ctype for isdigit for Linux. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-11Correct comment to show the parameters as defined in tools/mkimage.hLars Rasmusson
Signed-off-by: Lars Rasmusson <Lars.Rasmusson@sics.se>
2012-11-14patman: Issue empty change logs for unchanged patchesSimon Glass
Often a particular patch may change only for some versions of a series. For versions where there is no change, issue a change log indicating that (for example 'Changes in v4: None'). For such lines, don't add a blank line afterwards, to conserve space. Use list.insert() instead of list = [item] + list. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stefan Roese <sr@denx.de>
2012-11-05Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-11-04patman: Add additional tags to ignoreSimon Glass
The BRANCH= tag can be used to indicate the destination branch for a commit. Ignore this tag. Also ignore the gerrit 'Commit-Ready:' tag. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-27Merge remote-tracking branch 'u-boot-imx/master'Albert ARIBAUD
2012-10-26Merge remote-tracking branch 'u-boot-ti/master'Albert ARIBAUD
2012-10-25omapimage: Add support for byteswapped SPI imagesTom Rini
Add MLO.byteswap as a target to spl/Makefile and un-guard the first MLO rule so we don't have to duplicate it. Signed-off-by: Tom Rini <trini@ti.com>
