Sphinx expects Return: and not @return to indicate a return value.
find . -name '*.c' -exec \
sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \;
find . -name '*.h' -exec \
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Do not check for kwbimage configuration file when just showing information
about existing kwbimage file.
The check for kwbimage configuration file is required only when creating
kwbimage, not when showing information about image or when extracting data
from image.
With this change, it is possible to call mkimage -l and dumpimage -l also
for existing kwbimage file.
Signed-off-by: Pali Rohár <pali@kernel.org>
Reviewed-by: Marek Behún <marek.behun@nic.cz>
When there is no -p argument for dumpimage tool specified, extract the main
data image from kwbimage file. This makes dumpimage consistent with other
image formats.
Despite the official specification, BootROM does not look at the lowest bit
of ext field but rather checks if ext field is non-zero.
Moreover original Marvell doimage tool puts into the mhdr->ext field the
number of extended headers, so basically it sets ext filed to non-zero
value if some extended header is present.
Fix U-Boot dumpimage and kwboot tools to parse correctly also kwbimage
files created by Marvell doimage tool, in the same way as the BootROM is
doing it when booting these images.
Avoid casting const to non-const.
To regenerate kwbimage from existing image, it is needed to have kwbimage
config file. Add a new option to generate kwbimage config file from
existing kwbimage when '-p 1' option is given.
For debugging purposes it is good to know where the binary image would be
loaded and also it is needed to know if printed size is image size or the
size of header together with image.
Make it unambiguous by showing that printed size is not the size of the
whole header, but only the size of executable code, and print also the
executable offset of this binary image. Load/execute address is the offset
relative to the base address (either 0x40004000 or 0x40000000).
Data delay is stored as 8-bit number in kwbimage structure. Ensure the
given value is at most 255.
This alignment is required only for platforms based on Sheeva CPU core
which are A370 and AXP. Now when U-Boot build system correctly propagates
LOAD_ADDRESS there is no need to have enabled 128-bit boundary alignment on
platforms which do not need it. Previously it was required because load
address was implicitly rounded to 128-bit boundary and U-Boot build system
expected it and misused it. Now with explicit setting of LOAD_ADDRESS there
is no guessing for load address anymore.
BootROM loads kwbimage header to L2-SRAM and BootROM reserve only 192 kB for it.
Function image_headersz_v1() may return zero on fatal errors.
In this case the function already printed an error message.
Check the return value of image_headersz_v1() in kwbimage_generate(),
and exit on zero value with EXIT_FAILURE.
ARM executable code included in kwbimage binary header, which is not
position independent, needs to be loaded and executed by BootROM at the
correct fixed address.
Armada BootROMs load kwbimage header (in which the executable code is also
stored) at fixed address 0x40004000 or 0x40000000 which is mapped to
L2-SRAM (L2 Cache as SRAM). Address 0x40004000 is used on Armada platforms
with Sheeva CPU core (A370 and AXP) where BootROM uses MMU with 0x4000
bytes for MMU translation table. Address 0x40000000 is used on all other
platforms.
Thus the only way to specify load and execute address of this executable
code in binary kwbimage header is by filling dummy arguments into the
binary header, using the same mechanism we already have for achieving
128-bit boundary alignment on A370 and AXP SoCs.
Extend kwbimage config file parser to allow to specify load address as
part of BINARY command with syntax:
BINARY path_to_binary arg1 arg2 ... argN LOAD_ADDRESS address
If the specified load address is invalid or cannot be used, mkimage will
throw fatal error and exit. This will prevent generating kwbimage with
invalid load address for non-position independent binary code.
If no load address is specified, kwbimage will not fill any the dummy
arguments, thus it will behave the same as before this change.
For other changes it is required to know if CPU core is Sheeva or not.
Therefore add a new command CPU for specifying CPU.
Preserve the order of BINARY, DATA and DATA_DELAY commands as they appear
in the input file. They may depend on each other.
Register set header consists of sequence of DATA commands followed by
exactly one DATA_DELAY command. Thus if we are generating image with
multiple DATA_DELAY commands, we need to create more register set headers.
Fix calculation of image size with multiple DATA_DELAY commands and
correctly set pointer to struct register_set_hdr_v1 when initializing new
register set header.
Deduplicate code that finishes OPT_HDR_V1_REGISTER_TYPE header by
extracing it into separate function.
Mark all local functions as static.
When genboardscfg.py is run on machines with 255 or more cores, the
process will consume more than 1024 file descriptors, which is a common
standard ulimit for user processes. As a consequence it will fail with a
lenghty Python trace, with the almost hidden message:
OSError: [Errno 24] Too many open files
It's somewhat questionable whether that level of parallelity is actually
useful for genboardscfg, so we limit the *default* number of jobs to the
safe number of 240, to avoid the problem.
If a user persists, she can still force a higher number via the -j
parameter - hopefully having raised the ulimit accordingly beforehand.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Python doesn't naturally support tilde (~) as a user-home marker in
paths, but git-config does. So we need to resolve it before continuing.
We also shouldn't blindly join the top-level tree with the aliasesfile
path, because it might be an absolute path.
This resolves warnings like the following:
Warning: Cannot find alias file '/path/to/source/tree/~/.git-email'
Seen when git-config is like:
$ git config sendemail.aliasesfile
~/.git-email
Signed-off-by: Brian Norris <briannorris@chromium.org>
Reviewed-by: Otavio Salvador <otavio@ossystems.com.br>
At present binman writes fake blobs to the current directory. This is not
very helpful, since the files serve no useful purpose once binman has
finished. They clutter up the source directory and affect future runs,
since the files in the current directory are often used in preference to
those in the board directory.
To avoid these problems, write them to the output directory instead.
Move the file-creation code to the Entry base class, so it can be used by
any entry type that needs it. This is required since some entry types,
such as Entry_blob_ext_list, are not subclasses of Entry_blob.
Use a unique number instead of the current 203, which is used by 203_fip
as well. Reformat the code to avoid a long line.
Bring us to the focal-20220105 tag and rebuild our images on top of
this.
https://source.denx.de/u-boot/custodians/u-boot-amlogic into next
- disable CONFIG_NET_RANDOM_ETHADDR when unnecessary on amlogic based configs
- meson64_android: add board specific env settings, in order to support VIM3/L for android
- add changes to support VIM3/L android boot by using meson64_android.h config
While converting to binman for an imx8mq board, it has been found that
building in the u-boot CI fails. This is because an imx8mq requires an
external binary (signed_hdmi_imx8m.bin). If this file cannot be found
mkimage fails.
To be able to build this board in the u-boot CI a binman option
(--fake-ext-blobs) is introduced that can be switched on via the u-boot
makefile option BINMAN_FAKE_EXT_BLOBS. With that the needed dummy files are
created.
Signed-off-by: Heiko Thiery <heiko.thiery@gmail.com>
Recent changes caused fields in the image main header to be modified
after the header checksum had already been computed. Move the checksum
computation to once again be the last operation performed on the header.
Fixes: 2b0980c24027 ("tools: kwbimage: Fill the real header size into the main header")
Signed-off-by: Pierre Bourdon <delroth@gmail.com>
Reviewed-by: Pali Rohár <pali@kernel.org>
https://source.denx.de/u-boot/custodians/u-boot-efi
Pull request for efi-2022-01-rc4-4
UEFI:
* allow for more than 16 KiB UEFI variable size when using StMM
Others:
* make watchdog sysreset compatible with separate poweroff driver
* avoid OpenSSL deprecation warnings
At present this uses RGB555 format for blitting to a display. Sandbox uses
565 and that seems to be more normal for BMP as well. Update the code
accordingly and add a test.
Note that this likely breaks the theadorable board so we may need to
discuss supporting both formats.
Add a compressed 16bpp BMP file and a test to cover this.
Our Gitlab CI buildsystem is set up to treat warnings as errors.
With OpenSSL 3.0 a lot of deprecation warnings occur.
With the patch compatibility with OpenSSL 1.1.1 is declared.
In the long run we should upgrade our code to use the current API.
A -Wdiscarded-qualifiers warning is muted by casting.
rk3568 is the first SoC which supports idb header v2.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Rockchip BootRom supports new idb header v2 instead of legacy version.
Add support for it so that we can generate image for new SoCs.
Signed-off-by: Yi Liu <liuyi@rock-chips.com>
We are going to have more than one version header, add the version in the
header info.
The first 4byte of idbimage is a magic number instead of signature,
correct it.
At present one must hack the Makefile to see what is going on with these
files. Also it doesn't quite work correctly.
Fix this by using an environment variable for debugging. Update the docs
also.
This was added as a hack to work around not having an in-tree devicetree.
Now that this is fixed it is not needed.
Drop it.
Prepare v2022.01-rc4
Commit "fw_setenv: lock the flash only if it was locked before"
checks for Locked status with uninitialized erase data.
Address by moving the test for MEMISLOCKED.
Fixes: 8a726b852502 ("fw_setenv: lock the flash only if it was locked before")
Signed-off-by: Joakim Tjernlund <joakim.tjernlund@infinera.com>
When outputting a devicetree we should not align the struct section to a
16-byte boundary. The normal position is fine, which is 8-byte aligned.
This avoids leaving adding 8 extra zero bytes in the output tree in the
case where the reserved section is empty (i.e has 16 zero bytes).
Add the 'missing-msg' for blobs for more detailed output on missing system
firmware and SEBoot blobs.
Signed-off-by: Ivan Mikhaylov <ivan.mikhaylov@siemens.com>
Fix minor typos:
Instead of joining hard coded '..' to the run-time path of the executable,
take just a dirname out of it. Besides that, use $(srctree) where it makes
sense.
Importing libraries in Python caches the bytecode by default.
Since we run scripts in source tree it ignores the current directory
settings, which is $(srctree), and creates cache just in the middle
of the source tree. Move cache to the current directory.
This format is used in firmware binaries so we may as well supported it.
With this patch binman supports creating, listing and updating FIPs, as
well as extracting files from one, provided that an FDTMAP is also present
somewhere in the image.
Add support for this format which is used by ARM Trusted Firmware to find
firmware binaries to load.
FIP is like a simpler version of FMAP but uses a UUID instead of a name,
for each entry.
It supports reading a FIP, writing a FIP and parsing the ATF source code
to get a list of supported UUIDs.
This method name is more commonly used for this function. Use it
consistently.
Sometimes it is useful to have a list of related external blobs in a
single entry. An example is the DDR binaries used by meson. There are
9 files in total. Add support for this, so we don't have to have a
separate entry for each.
Add a function to read a list of strings from the devicetree.
In some cases entries encapsulate other data and it is useful to access
the data within. An example is the fdtmap which consists of a 16-byte
header, followed by a devicetree.
Provide an option to specify an alternative format when extracting files.
In the case of fdtmap, this is 'fdt', which produces an FDT file which can
be viewed with fdtdump.
If an older version of binman is used to list images created by a newer
one, it is possible that it will contain entry types that are not
supported. At present this produces an error.
Adjust binman to use a plain 'blob' entry type to cope with this, so the
image can at least be listed.
At present it is necessary to symlink files containing external blobs into
the U-Boot tree in order for binman to find them. This is not very
convenient.
Add two new environment/Makefile variables to help with this. Add
documentation as well, fixing a related nit.
