The -i option of the dumpimage tool has been removed so it should no
longer be documented in the README file. Refer readers to the tool's
help output rather than maintain a copy of the usage in the README.
Finally, adjust the example dumpfile invocation in imagetool.h to use
the -o option instead of the removed -i option.
Fixes: 12b831879a76 ("tools: dumpimage: Simplify arguments")
Signed-off-by: Tyler Hicks <tyhicks@linux.microsoft.com>
Cc: Martyn Welch <martyn.welch@collabora.com>
Acked-by: Martyn Welch <martyn.welch@collabora.com>
In the function get_random_data, strerrno is called with
the variable ret (which is the return of the function
clock_gettime). It should be called with errnor. This
commit fixes this mistake.
Reported-by: Coverity (CID: 312956)
Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
According to the manpage of rand, it is recommended
to use random instead of rand. This commit updates
the function get_random_data to use random.
Reported-by: Coverity (CID: 312953)
Add a commit tag to allow the Patchwork URL to be specified in a commit.
This can be handy for when you submit code to multiple projects but don't
want to use the -p option.
Add an argument to allow specifying the the patchwork URL. This also adds
this feature to the settings file, either globally, or on a per-project
basis.
Add a new argument to allow the URL of the patchwork server to be
speciified. For now this is hard-coded in the main file, but future
patches will move it to the settings file.
At present values from the settings file are only applied to the main
parser. With the new parser structure this means that some settings are
ignored.
Update the implementation to set defaults across the main parser and all
subparsers. Also fix up the comments, since ArgumentParser is being used
now.
The arguments of this error are incorrectly formatted. Fix it.
At present patman tries to assume a default subcommand of 'send', to
maintain backwards compatibility. However it does not cope with
arguments added to the default command, so for example 'patman -t'
does not work.
Update the logic to handle this. Also update the CC command to use 'send'
explicitly, since otherwise patman gets confused with the patch-filename
argument.
While reviewing feedback it is helpful to see the review comments on the
command line to check that each has been addressed. Add an option to
support that.
Update the workflow documentation to describe the new features.
Add support for parsing the contents of a patchwork 'patch' web page
containing comments received from reviewers. This allows patman to show
these comments in a simple 'snippets' format.
A snippet is some quoted code plus some unquoted comments below it. Each
review is from a unique person/email and can produce multiple snippets,
one for each part of the code that attracts a comment.
Show the file and line-number info at the top of each snippet if
available.
It is tedious to add review tags into the local branch and errors can
sometimes be made. Add an option to create a new branch with the review
tags obtained from patchwork.
Before sending out a new version of a series for review, it is important
to add any review tags (e.g. Reviewed-by, Acked-by) collected by
patchwork. Otherwise people waste time reviewing the same patch
repeatedly, become frustrated and stop reviewing your patches.
To help with this, add a new 'status' subcommand that checks patchwork
for review tags, showing those which are not present in the local branch.
This allows users to see what new review tags have been received and then
add them.
Sample output:
$ patman status
1 Subject 1
Reviewed-by: Joe Bloggs <joe@napierwallies.co.nz>
2 Subject 2
Tested-by: Lord Edmund Blackaddër <weasel@blackadder.org>
Reviewed-by: Fred Bloggs <f.bloggs@napier.net>
+ Reviewed-by: Mary Bloggs <mary@napierwallies.co.nz>
1 new response available in patchwork
The '+' indicates a new tag. Colours are used to make it easier to read.
At present if we fail to find the upstream then the error output is piped
to wc, resulting in bogus results. Avoid the pipe and check the output
directly.
Sometimes warnings are associated with a file and sometimes with the
patch as a whole. Update the regular expression to handle both cases,
even in emacs mode. Also add support for detecting new files.
Use the subject of the Commit object when printing it out.
These lines can indicate a continuation of an error and should not be
ignored. Fix this.
Fixes: 666eb15e923 ("patman: Handle checkpatch output with notes and code")
Tidy up the extra 's' when there is only a single warning. Fix the empty
print statement also.
On balance it is easier to use an iterator here, particularly if we need
to insert lines due to new functionality. The only niggle is the need to
keep the previous iterator value around in one case.
Convert this test to use iter().
Add tests that check that warnings are generated when expected.
The current functional tests run most of patman. Add a smaller test that
just checks tag handling with the PatchStream class.
This is not used. Drop it.
If the Series-xxx tag is not recognised patman currently reports a fatal
error. This is inconvenient if a new feature is later added to patman that
an earlier version does not support.
Report a warning instead, to allow the user to take action if needed, but
still allow operation to proceed.
At present warnings are produced across the whole set of patches when
parsing them. It is more useful to associate each warning with the patch
(or commit) that generated it.
Attach warnings to the Commit object and move them out of PatchStream.
Also avoid generating duplicate warnings for the same commit.
Add a new function in PatchStream to collect the warnings generated while
parsing the stream. This will allow us to adjust the logic, such as
dealing with per-commit warnings.
Two of the warnings are in fact internal errors, so change them to raise
and exception.
Add missing documentation and type information. Fix up some missing docs
on exceptions also.
Drop a few arguments that are not used in functions.
Some variables are too short or shadow other variables or types. Fix these
to keep pylint3 happy.
Rename these functions to lower case as per PEP8.
These constants should use upper case. Update them to keep pylint3 happy.
Update the indenting to keep pylint3 happy.
Add a new Series-links tag to tell patman how to find the series in
patchwork. Each item is the series ID optionally preceded by the series
version that the link refers to. An empty version indicates this is the
latest series.
For example:
Series-links: 209816 1:203302
Documentation is added in a later patch.
This fixes all but the ones about too many variables/statements.
One test still uses its own function for capturing output. Modify it to
use the standard one in test_util
Fix up various indentation and other minor things to make pylint3 happier.
The current instructions are out-of-date. Fix them.
This operation was unfortunately broken by a recent change. It is now
necessary to use -i in addition to -n, if there are errors or warnings in
the patches.
Correct this by always showing the summary information.
Fixes: f3653759758 ("patman: Move main code out to a control module")
A recent change removed the base offset from the calculation. This is
used on coral to find the FSP-S binary. Fix it.
Fixes: a9fad07d4b8 ("binman: Avoid reporting image-pos with compression")
With a recent change this entry stores only part of the section data,
leaving out the padding at the end. Fix this by using GetPaddedData() to
get the data. Add this function to the base Entry class also.
Fixes: d1d3ad7d1fe ("binman: Move section padding to the parent")
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip
- New PX30 board: Engicam PX30.Core;
- Fix USB HID support for rock960;
- Remove host endianness dependency for rockchip mkimage;
- dts update for rk3288-tinker;
- Enable console MUX for some ROCKPi boards;
- Add config-based ddr selection for px30;
The Rockchip boot ROM expects little-endian values in the image header.
When running mkimage on a big-endian machine, these values need to be
byteswapped before writing or verifying the header.
This change fixes cross-compiling U-Boot SPL for the RK3399 SoC from a
big-endian ppc64 host machine.
Signed-off-by: Samuel Holland <samuel@sholland.org>
Reviewed-by: Kever Yang<kever.yang@rock-chips.com>
Refactor the implementation slightly so that section data is not
rebuilt when it is already available.
We still have GetData() set up to rebuild the section, since we don't
currently track when things change that might affect a section. For
example, if a blob is updated within a section, we must rebuild it.
Tracking that would be possible but is more complex, so it left for
another time.
With the previous changes, it is now possible to compress entire
sections. Add some tests to check that compression works correctly,
including updating the metadata.
Also update the documentation.
At present this function adds up the total size of entries to work out the
size of a section's contents. With compression this is no-longer enough.
We may as well bite the bullet and build the section contents instead.
Call _BuildSectionData() to get the (possibly compressed) contents and
GetPaddedData() to get the same but with padding added.
Note that this is inefficient since the section contents is calculated
twice. Future work will improve this.
This affects testPackOverlapMap() since the error is reported with a
different section size now (enough to hold the contents). Update that at
the same time.
At present this function assumes that the size of a section is at least as
large as its contents. With compression this is often not the case. Relax
this constraint by using the uncompressed size, if available.
This method introduces a separation between packing and checking that is
different for sections. In order to handle compression properly, we need
to be able to deal with a section's size being smaller than the
uncompressed size of its contents. It is easier to make this work if
everything happens in the Pack() method.
The only real user of CheckEntries() is entry_Section and it can call it
directly. Drop the call from 'control' and handle it locally.
At present CheckSize() is called from the function that packs the entries.
Move it up to the main Pack() function so that _PackEntries() can just
do the packing.
This is only used by entry_Section and that class already calls it. Avoid
calling it twice. Also drop it from the documentation.
At present sorting and expanding entries are side-effects of the
CheckEntries() function. This is a bit confusing, as 'checking' would
not normally involve making changes.
Move these steps into the Pack() function instead.
This function just calls CheckEntries() in the only non-trivial
implementation. Drop it and use CheckEntries() directly.
