path: root/tools
2016-02-08tools: env: update usage stringsAndreas Fenkart
Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-02-08tools: env: factor out parse_common_argsAndreas Fenkart
2016-02-08tools: env: shift optind arguments and fix argument indicesAndreas Fenkart
2016-02-08tools: env: parse aes key / suppress flag into argument structAndreas Fenkart
disabled original parsing, but not yet removed since the argument indexing needs to be fixed Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-02-08tools: env: introduce setenv/printenv argument structsAndreas Fenkart
goal is to use getopt for all argument parsing instead of adhoc parsing in fw_getenv/fw_setenv functions Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-02-08tools: env: make parse_aes_key statelessAndreas Fenkart
2016-02-08tools: env validate: pass values as 0-based arrayAndreas Fenkart
passing argv/argc can produce off-by-one errors Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2016-02-02tools: mxsboot: Use more portable cpu_to_le32()Bin Meng
Currently when building mxsboot on certain machines it reports: HOSTCC tools/mxsboot tools/mxsboot.c: In function 'mx28_create_sd_image': tools/mxsboot.c:560: warning: implicit declaration of function 'htole32' /tmp/cchLIV6q.o: In function 'main': mxsboot.c:(.text+0x6d8): undefined reference to 'htole32' mxsboot.c:(.text+0x6e7): undefined reference to 'htole32' mxsboot.c:(.text+0x6f6): undefined reference to 'htole32' mxsboot.c:(.text+0x705): undefined reference to 'htole32' mxsboot.c:(.text+0x711): undefined reference to 'htole32' /tmp/cchLIV6q.o:mxsboot.c:(.text+0x71d): more undefined references to 'htole32' follow collect2: ld returned 1 exit status make[1]: *** [tools/mxsboot] Error 1 make: *** [tools] Error 2 The solution is to use cpu_to_le32() instead which is more portable, just like other U-Boot tools [1] do. [1] http://lists.denx.de/pipermail/u-boot/2014-October/192919.html Suggested-by: Marek Vasut <marex@denx.de> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Marek Vasut <marex@denx.de>
2016-01-21rockchip: Add a script to parse datasheetsSimon Glass
This script has proved useful for parsing datasheets and creating register shift/mask values for use in header files. Include it in case it is useful for others. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-20dm: video: test: Test that bitmap display works correctlySimon Glass
Add a test for the 'bmp' command. Test both the uncompressed and compressed versions of the file, since they use different code paths. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2016-01-20patman: Add --thread optionMateusz Kulikowski
Add option to create threaded series of patches. With it, it will be possible to create patch threads like this: [PATCH 0/10] Add support for time travel [PATCH 1/10] Add Flux Capacitor driver [PATCH 2/10] Add Mr. Fusion driver (...) Internally it will call git send-email with --thread option Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-01-14Merge branch 'master' of git://git.denx.de/u-boot-x86Tom Rini
2016-01-14arm: mvebu: Add runtime detection of UART (xmodem) boot-modeStefan Roese
This patch adds runtime detection of the Marvell UART boot-mode (xmodem protocol). If this boot-mode is detected, SPL will return to the BootROM to continue the UART booting. With this patch its now possible, to generate a U-Boot image that can be booted either from the strapped boot-device (e.g. SPI NOR, MMC, etc) or via the xmodem protocol from the UART. In the UART case, the kwboot tool will dynamically insert the UART boot-device type into the image. And also patch the load address in the header, so that the mkimage header will be skipped (as its not expected by the Marvell BootROM). This simplifies the development for Armada XP / 38x based boards. As no special images need to be generated by selecting the MVEBU_BOOTROM_UARTBOOT Kconfig option. Since the Kconfig option MVEBU_BOOTROM_UARTBOOT is not needed any more, its now completely removed. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Phil Sutter <phil@nwl.cc> Cc: Kevin Smith <kevin.smith@elecsyscorp.com>
2016-01-14arm: mvebu: Move SoC selection (A38X vs AXP) into KconfigStefan Roese
Until now, the SoC selection for the ARCH_MVEBU platforms has been done in the config header. Using CONFIG_ARMADA_XP in a non-clear way. As it needed to get selected for AXP and A38x based boards. This patch now changes this to move the SoC selection to Kconfig. And also uses CONFIG_ARCH_MVEBU as a common define for both AXP and A38x. This makes things a bit clearer - especially for new board additions. Additionally the defines CONFIG_SYS_MVEBU_DDR_AXP and CONFIG_SYS_MVEBU_DDR_A38X are replaced with the already available CONFIG_ARMADA_38X and CONFIG_ARMADA_XP. And CONFIG_DDR3 is removed, as its not referenced anywhere. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-13tools: microcode-tool: Support parsing header file with a license blockBin Meng
The microcode header files in the Intel Chief River FSP package have a license comment block. Update the microcode-tool to support parsing it and extract the license text to the .dtsi file. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-01-08rockchip: Drop a debug message when outputing SPI imagesSimon Glass
There is an unnecessary sector count displayed. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-08rockchip: Enable generation of SPI imagesSimon Glass
This feature was dropped at some point. Restore it. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-12-18tools: zynqimage: Clean up check_paramsNathan Rossi
Clean up the param checking, removing some code paths that will never happen. Signed-off-by: Nathan Rossi <nathan@nathanrossi.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Tom Rini <trini@konsulko.com> Reported-by: Coverity (CID 133251) Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-16Merge git://git.denx.de/u-boot-rockchipTom Rini
2015-12-13tools: env: include compiler.hPeter Robinson
With gcc 5.2 and later we get a bunch of "error: unknown type name" for 'uint8_t', 'uint32_t' and friends. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-12-13rockchip: mkimage: use imagename to select spl hdr & spl sizeJeffy Chen
Our chips may have different spl size and spl header, so use imagename(passed by "mkimage -n") to select them now. Signed-off-by: Jeffy Chen <jeffy.chen@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-13Revert "rockchip: Add max spl size & spl header configs"Jeffy Chen
This reverts commit 10b4615f9d7e177ec7fe644fbb2616e0e0956f6e Signed-off-by: Jeffy Chen <jeffy.chen@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-10buildman: README: add links for toolchains not available on kernel.orgThomas Chou
Add links for toolchains not available on kernel.org. The sh4 toolchains from kernel.org dose not work for some boards, so use the sh from Sourcery. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-12-07mkimage: Fix warning from fix for generating multi and script images againMarek Vasut
Seems 6ae6e160 broke creating images in certain cases, there are two problems with that patch. First is that the expression "!x == 4 || !x == 6" is ambiguous. The intention here was "!(x == 4) || !(x == 6)" based on reading further in the file, where this was borrowed from. This however is interpreted by gcc as "(!x) == 4 || (!x) == 6" and always false. gcc-5.x will warn about this case. The second problem is that we do not want to test for the case of "(NOT x is 4) OR (NOT x is 6)" but instead "(x is not equal to 4) AND (x is not equal to 6)". This is because in those two cases we already execute the code question in another part of the file. Rewrite the expression and add parenthesis for clarity. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Philippe De Swert <philippedeswert@gmail.com> Cc: Simon Glass <sjg@chromium.org> [trini: Re-word Marek's explanation]
2015-12-05mkimage : Fix generating multi and script imagesPhilippe De Swert
Seems 92a655c3 broke creating multi and script type images. Since the file1:file2:file3 string does not get split up, it fails on trying to open an non-existing file. mkimage -A arm -O linux -T multi -C none -d zImage:splash.bmp:device.dtb uimage tools/mkimage: Can't open zImage:splash.bmp:device.dtb: No such file or directory Since the sizes of the different parts seem to get added in the actual routine that handles multi and script type images, we can probably skip the bit of the code that causes the failure for that type of images. Signed-off-by: Philippe De Swert <philippedeswert@gmail.com>
2015-12-01rockchip: Add support for rk's second level loaderJeffy Chen
The Rockchip boot ROM could load & run an initial spl loader, and continue to load a second level boot-loader(which stored right after the initial loader) when it returns. Modify idblock generation code to support it. Signed-off-by: Jeffy Chen <jeffy.chen@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01rockchip: Add max spl size & spl header configsJeffy Chen
Our chips may have different max spl size and spl header, so we need to add configs for that. Signed-off-by: Jeffy Chen <jeffy.chen@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Dropped CONFIG_ROCKCHIP_MAX_SPL_SIZE from rk3288_common.h, Added $(if...) to tools/Makefile to fix widespread build breakage Signed-off-by: Simon Glass <sjg@chromium.org> Series-changes: 8 - Drop CONFIG_ROCKCHIP_MAX_SPL_SIZE from rk3288_common.h, - Add $(if...) to tools/Makefile to fix widespread build breakage
2015-11-29tools/kwbimage: fix size computations for v1 imagesReinhard Pfau
Fix computation of haeder size and binary header size. Size of opt header and some 32bit values were not taken into account. This could result in invalid boot images (due to the wrong binary header size, the image could claim to have another extension header after the binary extension although there is none). Use "uint32_t" instead of "unsigned int" for header size computation. Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc> Reviewed-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-11-29tools/kwbimage: fix endianess issueReinhard Pfau
KWB image header values are in little endian (LE). So adding appropriate cpu_to_leXX() calls to allow building those images on BE hosts, too. Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc> Reviewed-by: Stefan Roese <sr@denx.de>
2015-11-29tools/kwbimage.c: Make sure that the resulting image is 4-byte alignedStefan Roese
With the dtb added to the main U-Boot image, it can happen, that the resulting image is not 4-byte aligned. As the dtb tends to be unaligned. But the image needs to be 4-byte aligned. At least the Marvell hdrparser tool complains if its unaligned. By returning 1 here in kwbimage_generate(), called via tparams->vrec_header() in mkimage.c, mkimage will automatically pad the resulting image to a 4-byte size if necessary. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <eibach@gdsys.de>
2015-11-19tools: zynqimage: Add Xilinx Zynq boot header generation to mkimageNathan Rossi
As with other platforms vendors love to create their own boot header formats. Xilinx is no different and for the Zynq platform/SoC there exists the "boot.bin" which is read by the platforms bootrom. This format is described to a useful extent within the Xilinx Zynq TRM. This implementation adds support for the 'zynqimage' to mkimage. The implementation only considers the most common boot header which is un-encrypted and packed directly after the boot header itself (no XIP, etc.). However this implementation does take into consideration the other fields of the header for image dumping use cases (vector table and register initialization). Signed-off-by: Nathan Rossi <nathan@nathanrossi.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-11-18Allow fw env tools to be available as libraryStefano Babic
Sometimes it can be useful to link the fw_ tools instead of having the fw_setenv/fw_printenv installed. Patch exports the tool as library and allowes to link it with own programs. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-18tools/env: allow config filename to be passed via command line argumentMichael Heimpold
When for example generating/manipulating SD card/eMMC images which contain U-Boot and its environment(s), it is handy to use a given configuration file instead of the compiled-in default one. And since the default configuration file is expected under /etc it's hard for an usual linux user account without special permissions to use fw_printenv/fw_setenv for this purpose. So allow to pass an optional filename via a new '-c' command line argument. Example: $ ln -s fw_printenv tools/env/fw_setenv $ cat fw_env.config test.img 0x20000 0x20000 test.img 0x40000 0x20000 $ tools/env/fw_printenv -c ./fw_env.config fdt_file fdt_file=imx28-duckbill.dtb $ tools/env/fw_setenv -c ./fw_env.config fdt_file imx28-duckbill-spi.dtb $ tools/env/fw_printenv -c ./fw_env.config fdt_file fdt_file=imx28-duckbill-spi.dtb Signed-off-by: Michael Heimpold <mhei@heimpold.de>
2015-11-17tools/kwbimage.c: Fix generation of binary headerStefan Roese
The binary header ends with one lword, defining if another header follows this one. This additions 4 bytes need to be taken into account in the generation of the header size. And the complete 4 bytes at the end of this binary header need to get cleared. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Kevin Smith <kevin.smith@elecsyscorp.com>
2015-11-16tools/proftool: fix use-after-freeVincent Stehlé
The read_trace_config() can dereference the line pointer after freeing it on its error path. Avoid that. This was found by Coverity Scan. Signed-off-by: Vincent Stehlé <vincent.stehle@freescale.com> Cc: Simon Glass <sjg@chromium.org>
2015-11-10Various Makefiles: Add SPDX-License-Identifier tagsTom Rini
After consulting with some of the SPDX team, the conclusion is that Makefiles are worth adding SPDX-License-Identifier tags too, and most of ours have one. This adds tags to ones that lack them and converts a few that had full (or in one case, very partial) license blobs into the equivalent tag. Cc: Kate Stewart <kstewart@linuxfoundation.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-04fdtgrep: Simplify the alias generation codeSimon Glass
We don't need to allocate a new region list when we run out of space. The outer function can take care of this for us. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-10-24Fix bad return value checks (detected with Coccinelle)Thomas Huth
In the "Getting Started with Coccinelle - KVM edition" presentation that has been held by Julia Lawall at the KVM forum 2015 (see the slides at http://events.linuxfoundation.org/sites/events/files/slides/tutorial_kvm_0.pdf), she pointed out some bad return value checks in U-Boot that can be detected with Coccinelle by using the following config file: @@ identifier x,y; identifier f; statement S; @@ x = f(...); ( if (x < 0) S | if ( - y + x < 0) S ) This patch now fixes these issues. Signed-off-by: Thomas Huth <huth@tuxfamily.org>
2015-10-21kwbimage: Align payload size to 4 bytesStefan Roese
The MVEBU BootROM does not allow non word aligned payloads. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-10-13Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-10-11Fix variation in timestamps caused by timezone differences.Vagrant Cascadian
When building with SOURCE_DATE_EPOCH set, avoid use of mktime in default_image.c, which converts the timestamp into localtime. This causes variation based on timezone when building u-boot.img and u-boot-sunxi-with-spl.bin targets. Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Tested-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Paul Kocialkowski <contact@paulk.fr>
2015-10-11tools/mkimage.c: Clarify help text for -D slightlyTom Rini
Try and make it clear that -D will replace all arguments passed to dtc and is not appending them. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-07imximage: fix commands other than write_dataTroy Kisky
When CHECK_BITS_SET was added, they forgot to add a new command table, and instead overwrote the previous table. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-10-07imximage: header.length of 4 is validTroy Kisky
2015-09-30Merge git://git.denx.de/u-boot-marvellTom Rini
2015-10-01tools: kwboot: Add support for UART boot mode patching for Armada XP/38xStefan Roese
Currently, kwboot only allows dynamic UART boot mode patching for SoCs with header version 0 (Orion, Kirkwood). This patch now enables this "-p" feature also for SoCs with header version 1 (Armada XP / 38x etc). With this its possible now to use the UART boot mode without on images that are generated for other boot devices, like SPI. So no need to change BOOT_FROM to "uart" for UART xmodem booting any more. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Kevin Smith <kevin.smith@elecsyscorp.com> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <eibach@gdsys.de>
2015-09-29sunxi: (mksunxiboot) signature to indicate "sunxi" SPL variantBernhard Nortmann
This patch follows up on a discussion of ways to improve support for the sunxi FEL ("USB boot") mechanism, especially with regard to boot scripts, see: https://groups.google.com/d/msg/linux-sunxi/wBEGUoLNRro/rHGq6nSYCQAJ The idea is to convert the (currently unused) "pad" bytes in the SPL header into an area where data can be passed to U-Boot. To do this safely, we have to make sure that we're actually using our "sunxi" flavor of the SPL, and not the Allwinner boot0. The modified mksunxiboot introduces a special signature to the SPL header in place of the "pub_head_size" field. This can be used to reliably distinguish between compatible versions of sunxi SPL and anything else (older variants or Allwinner's boot0). Signed-off-by: Bernhard Nortmann <bernhard.nortmann@web.de> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-09-29sunxi: move SPL-related definitions to platform-specific includeBernhard Nortmann
The sunxi platform currently doesn't seem to make any use of the asm/arch-sunxi/spl.h file. This patch moves some declarations from tools/mksunxiboot.c into it. This enables us to reuse those definitions when extending the sunxi board code (boards/sunxi/boards.c). Signed-off-by: Bernhard Nortmann <bernhard.nortmann@web.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-09-28tools: moveconfig: Update the URL for nds32 toolchainBin Meng
Give a full URL for a working nds32 toolchain for U-Boot. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
