path: root/tools
2019-01-14buildman: Add support for building with clangSimon Glass
Add a -O option which allows building with clang. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-01-14buildman: Deal nicely with invalid build-status fileSimon Glass
The 'done' files created by buildman may end up being empty if buildman runs out of disk space while writing them. This error is then persistent, since even if disk space is reclaimed and the build retries, the empty file causes an exception in the builder thread. Deal with this silently by doing a rebuild. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-01-14buildman: Drop comment about Ctrl-C problemSimon Glass
This bug is now fixed, so drop this comment. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-01-09tools: imx8image: set dcd_skip to truePeng Fan
To B0[+] chips, dcd_skip needs to be true. For A0 chip, it needs to be false, however A0 chip is no longer being supported anymore. Considering we are moving code from imx-mkimage to uboot mkimage, to make sure we not introduce some surprise, we still keep dcd_skip code there. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-01-01Merge tag 'u-boot-imx-20190101' of git://www.denx.de/git/u-boot-imxTom Rini
imx for 2019.01 - introduce support for i.MX8M - fix size limit for Vhybrid / pico boards - several board fixes - w1 driver for MX2x / MX5x
2019-01-01imx: imx8mq: build flash.binPeng Fan
Build flash.bin for i.MX8MQ, it will include signed hdmi firmware, spl, ddr firmware, fit image(bl31.bin, u-boot-nodtb.bin, dtb). Burn it to 33KB offset of SD card. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-01-01tools: add i.MX8M image supportPeng Fan
i.MX8M bootable image type is like i.MX6/7, but there is signed HDMI firmware image in front of A53 bootable image, which is also has an IVT header. Here we also include fit image to generate a bootable image. Signed-off-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Stefano Babic <sbabic@denx.de>
2019-01-01tools: improve portability of imx_cntr_image.shMartin Husemann
Replace non-portable operator == with = The operator == in sh(1) / test(1) is non-POSIX and only implemented by some shells (like bash). It is equivalent to the standard defined operator =.
2018-12-15tools: mtk_image: replace strncpy(d, s, sizeof(d)) with snprintf()Andy Shevchenko
Starting from version 8 the GCC, i.e. C compiler, starts complaining about possible '\0' terminator loss or, as in this case, garbage copy. In function ‘mtk_image_set_gen_header’, inlined from ‘mtk_image_set_header’ at tools/mtk_image.c:733:3: tools/mtk_image.c:659:2: warning: ‘strncpy’ specified bound 12 equals destination size [-Wstringop-truncation] strncpy(hdr->boot.name, bootname, sizeof(hdr->boot.name)); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ In function ‘mtk_brom_parse_imagename’, inlined from ‘mtk_image_check_params’ at tools/mtk_image.c:388:9: tools/mtk_image.c:325:5: warning: ‘strncpy’ specified bound 32 equals destination size [-Wstringop-truncation] strncpy(lk_name, val, sizeof(lk_name)); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Replace it with snprintf() to tell compiler how much room we have in the destination buffer for source string. Fixes: 3b975a147c3c ("tools: MediaTek: add MTK boot header generation to mkimage") Cc: Ryder Lee <ryder.lee@mediatek.com> Cc: Weijie Gao <weijie.gao@mediatek.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Weijie Gao <weijie.gao@mediatek.com>
2018-12-15tools: add a generic config for native tools buildingOtavio Salvador
The motivation for this is to allow distributions to distribute all possible tools in a generic way, avoiding the need of specific tools building for each machine. Especially on OpenEmbedded / Yocto Project ecosystem, it is very common each BSP to end providing their specific tools when they need to generate images for some SoC (e.g MX23 / MX28 in meta-freescale case). Using this, we can package the tools doing: $: make tools-only_defconfig $: make tools-only Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> [trini: Add MAINTAINERS entry for myself, add to .travis.yml, make U-Boot itself buildable to not trip up other frameworks] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-12-08Roll CRC16-CCITT into the hash infrastructurePhilipp Tomsich
The CRC16-CCITT checksum function is useful for space-constrained applications (such as obtaining a checksum across a 2KBit or 4KBit EEPROM) in boot applications. It has not been accessible from boot scripts until now (due to not having a dedicated command and not being supported by the hash infrstructure) limiting its applicability outside of custom commands. This adds the CRC16-CCITT (poly 0x1021, init 0x0) algorithm to the list of available hashes and adds a new crc16_ccitt_wd_buf() to make this possible. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> [trini: Fix building crc16.o for SPL/TPL] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-12-05buildman/toolchain.py: handle inconsistent tarball namesTrevor Woerner
Unfortunately, for some releases the kernel.org toolchain tarball names adhere to the following pattern: <hostarch>-gcc-<ver>-nolib-<targetarch>-<type>.tar.xz e.g.: x86_64-gcc-8.1.0-nolibc-aarch64-linux.tar.xz while others use the following pattern: <hostarch>-gcc-<ver>-nolib_<targetarch>-<type>.tar.xz e.g.: x86_64-gcc-7.3.0-nolibc_aarch64-linux.tar.xz Notice that the first pattern has dashes throughout, while the second has dashes throughout except just before the target architecture which has an underscore. The "dash throughout" versions from kernel.org are: 8.1.0, 6.4.0, 5.5.0, 4.9.4, 4.8.5, 4.6.1 while the "dash and underscore" versions from kernel.org are: 7.3.0, 4.9.0, 4.8.0, 4.7.3, 4.6.3, 4.6.2, 4.5.1, 4.2.4 This tweak allows the code to handle both versions. Note that this tweak also causes the architecture parsing to get confused and find the following two bogus architectures, "2.0" and "64", which are explicitly checked for, and removed. Signed-off-by: Trevor Woerner <trevor@toganlabs.com> Reviewed-by: Simon Glass <sjg@chromium.org> Change single quotes to double quotes: Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-05buildman/toolchain.py: fix toolchain directoryTrevor Woerner
The hexagon toolchain (4.6.1) from kernel.org, for example, was packaged in a way that is different from most toolchains. The first entry when unpacking most toolchain tarballs is: gcc-<version>-nolib/<targetarch>-<system> e.g.: gcc-8.1.0-nolibc/aarch64-linux/ The first entry of the hexagon toolchain, however, is: gcc-4.6.1-nolibc/ This causes the buildman logic in toolchain.py::ScanPath() to not be able to find the "*gcc" executable since it looks in gcc-4.6.1-nolib/{.|bin|usr/bin} instead of gcc-4.6.1/hexagon-linux/{.|bin|usr/bin}. Therefore when buildman tries to download a set of toolchains that includes hexagon, the script fails. This update takes the second line of the tarball unpacking (which works for all the toolchains I've tested from kernel.org) and parses it to take the first two elements, separated by '/'. It makes this logic a bit more robust. Signed-off-by: Trevor Woerner <trevor@toganlabs.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-03rsa: add a structure for the paddingPhilippe Reynes
The rsa signature use a padding algorithm. By default, we use the padding pkcs-1.5. In order to add some new padding algorithm, we add a padding framework to manage several padding algorithm. The choice of the padding is done in the file .its. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-28tools: MediaTek: add MTK boot header generation to mkimageRyder Lee
This patch adds support for MTK boot image generation. Signed-off-by: Weijie Gao <weijie.gao@mediatek.com> Signed-off-by: Ryder Lee <ryder.lee@mediatek.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-26tools/file2include: don't use malloc.h for mallocJonathan Gray
stdlib.h is the header for malloc since at least c89/c90. Previously this would fail to build on OpenBSD and fallback to the wrong header: In file included from u-boot/tools/file2include.c:21: u-boot/include/malloc.h:875:5: error: function-like macro 'CONFIG_IS_ENABLED' is not defined Signed-off-by: Jonathan Gray <jsg@jsg.id.au> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-11-26tools: .gitignore: add prelink-riscvLukas Auer
Ignore tools/prelink-riscv. Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Rick Chen <rick@andestech.com>
2018-11-20binman: Set the pathname correctly for ELF filesSimon Glass
At present, stripped files don't have the right pathname which means that blob compression cannot be used. Fix this. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-20binman: Drop an unnecessary comma in blob handlingSimon Glass
This comma is not needed. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-20binman: Add a way to enable debugging from the buildSimon Glass
When the build fails due to something wrong in binman it is sometimes useful to get a full backtrace showing the location of the failure. Add a BINMAN_DEBUG environment variable to support this along with some documentation. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-20buildman: Show boards with warning with w+Simon Glass
At present we should boards with warnings in the same way as those with errors. This is not ideal. Add a new 'warn' state and show these listed in yellow to match the actual warning lines printing with -e. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-20buildman: Rename the good, better, worse variablesSimon Glass
At present we don't distinguish between errors and warnings when printing the architecture summary. Rename the variables to better describe their purpose. 'Worse' at present means we got an error, so use that as the name. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-20buildman: Detect dtc warningsSimon Glass
At present messages from the device-tree compiler like this: arch/arm/dts/socfpga_arria10_socdk_sdmmc.dtb: Warning (avoid_unnecessary_addr_size): /clocks: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property are detected as errors since they don't match the gcc warning regex. Add a new one for dtc to fix this. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-20buildman: Only print toolchain probing with -vSimon Glass
At present --list-tool-chains prints a lot of information about the toolchain-probing process. This is generally not very interesting. Update buildman to print this only if --list-tool-chains is given with -v. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-16armv7R: K3: am654: Add support for generating build targetsLokesh Vutla
Update Makefiles to generate: - tiboot3.bin: Image format that can be processed by ROM. Below is the tiboot3.bin image format that is required by ROM: _______________________ | X509 | | Certificate | | ____________________ | | | | | | | u-boot-spl.bin | | | | | | | |___________________| | |_______________________| Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
2018-11-14buildman: Add a --boards option to specify particular boards to buildSimon Glass
At present 'buildman sandbox' will build all 5 boards for the sandbox architecture rather than the single board 'sandbox'. The only current way to exclude sandbox_spl, sandbox_noblk, etc. is to use -x which is a bit clumbsy. Add a --boards option to allow individual build targets to be specified. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-06tools: imx8image: flatten container header only when creating containerPeng Fan
If there is no CONTAINER entry, there is no need to flatten container header. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2018-11-06tools: imx8image: fix coverity CID 184233Peng Fan
Fix: CID 184233: (NEGATIVE_RETURNS) Using variable "container" as an index to array "imx_header.fhdr". Reported-by: Coverity Signed-off-by: Peng Fan <peng.fan@nxp.com>
2018-11-06tools: imx8image: fix coverity CID 184234Peng Fan
Fix: CID 184234: (TAINTED_SCALAR) Using tainted variable "header.num_images - 1" as an index into an array "header.img". Reported-by: Coverity Signed-off-by: Peng Fan <peng.fan@nxp.com>
2018-11-06tools: imx8image: check lseek return valuePeng Fan
Check lseek return value. Fix Coverity CID: 184236 184235 184232 Reported-by: Coverity Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2018-11-02MIPS: make size of relocation table fixed but configurableDaniel Schwierzeck
Currently the size of the relocation table will be shrunk to the actual size needed. Although this gives a maximal space saving, it messes up the _end symbol. This breaks features like appended DTBs because the _end symbol doesn't point to the real end of the U-Boot binary. Remove the size shrinking and make the size of the relocation table fixed but configurable. This follows the Linux approach and the user can adjust the size to his needs. Also rename the relocation table section from .rel to .data.reloc to follow the Linux approach and to avoid ambiguities with the .rel.* sections added by the linker. Reported-by: Lars Povlsen <lars.povlsen@microsemi.com> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-10-25Merge tag 'u-boot-imx-20181025' of git://git.denx.de/u-boot-imxTom Rini
Merged imx8 architecture, fix build for imx8 + warnings
2018-10-25imx: mkimage: avoid stop CI when required files not existsPeng Fan
Introduce a new script to check whether file exists and use that check in Makefile to avoid break CI system. The script return 1 when the required files not exists, return 0 when files exists. The script will ignore check to u-boot-dtb.bin, because if there is something wrong to generate u-boot-dtb.bin, there must be some code error. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2018-10-22binman: Add a test for Intel reference codeSimon Glass
Unfortunately the test was not included in the original implementation. Add one. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-22tools: add i.MX8/8X image supportPeng Fan
i.MX8/8X bootable image type is container type. The bootable image, containers a container set which supports two container. The 1st container is for SECO firmware, the 2nd container needs to include scfw, m4_0/1 image, ACore images per your requirement. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2018-10-22binman: Add support for Intel reference codeSimon Glass
Some platforms use this instead of FSP to set up the platform, including memory. Add support for this in binman. This is needed for chromebook_samus, for example. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-10-09dtoc: Fix the value of SetInt()Simon Glass
This does not set the correct value at present. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09binman: Move to three-digit test-file numbersSimon Glass
We now have 99 tests. Before adding any more, rename everything to three digits. This helps to preserve the ordering of tests and makes it easier to find things. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-08binman: Run tests concurrentlySimon Glass
At present the tests run one after the other using a single CPU. This is not very efficient. Bring in the concurrencytest module and run the tests concurrently, using one process for each CPU by default. A -P option allows this to be overridden, which is necessary for code-coverage to function correctly. This requires fixing a few tests which are currently not fully independent. At some point we might consider doing this across all pytests in U-Boot. There is a pytest version that supports specifying the number of processes to use, but it did not work for me. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-08patman: Don't clear progress in tout unless it was usedSimon Glass
At present calling Uninit() always called ClearProgress() which outputs a \r character as well as spaces to remove any progress information on the line. This can mess up the normal output of binman and other tools. Fix this by outputing this only when progress information has actually been previous written. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-08tools: Set an initial value for indirSimon Glass
This variable is not documented or set up in the module. Fix this. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-08buildman: dtoc: Suppress unwanted output from testSimon Glass
There are a few test cases which print output. Suppress this so that tests can run silently in the normal case. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-08binman: Separate out testSplBssPad()Simon Glass
At present this test runs binman twice, which means that the temporary files from the first run do not get cleaned up. Split this into two tests to fix this problem. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-08binman: Fix up removal of temporary directoriesSimon Glass
At present 'make check' leaves some temporary directories around. Part of this is because we call tools.PrepareOutputDir() twice in some cases, without calling tools.FinaliseOutputDir() in between. Fix this. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-08binman: Add a default path to libfdt.pySimon Glass
This module is often available in the sandbox_spl build created by 'make check'. Use this as a default path so that just typing 'binman -t' (without setting PYTHONPATH) will generally run the tests. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-08buildman: Make the toolchain test more forgivingSimon Glass
The filenames of the toolchains on kernel.org changes every now and then. Fix it for the current change, and make the test use a regex so that it has a better chance of passing with future changes too. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-08patman: Handle unicode in _ProjectConfigParser testsSimon Glass
With Python 2.7.15rc1, ConfigParser.SafeConfigParser has unfortunately started returning unicode, for unknown reasons. Adjust the code to handle this by converting everything to unicode. We cannot convert things to ASCII since email addresses may be encoded with UTF-8. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-05Merge branch 'master' of git://git.denx.de/u-boot-socfpgaTom Rini
2018-10-04rockchip: Fix rkimage format for SPL boot over USBDaniel Gröber
The 'rkimage' format used for booting rockchip boards over USB seems to have been broken since commit 7bf274b9caab ("rockchip: mkimage: use imagename to select spl hdr & spl size"). That commit adds an offset of RK_SPL_HDR_START(=2048) to the location the 'RKxx' header is written at. However the bootrom expects this header to be the first four bytes of the image, not at offset 2048. This appears to have been a copy paste error since the 'rksd' and 'rkspi' image types do require this offset. Furthermore commit 111bcc4fb6cb ("rockchip: mkimage: pad the header to 8-bytes (using a 'nop') for RK3399"), commit 3d54eabcafec9 ("rockchip: spl: RK3399: use boot0 hook to create space for SPL magic") and commit 308277569229 ("rockchip: mkimage: update rkimage to support pre-padded payloads") changed the way the space for the 'RKxx' header is allocated and written to the image without adjusting 'rkimage'. This commit fixes those mistakes and makes it possible to load u-boot SPL over USB once more. (Tested on RK3399) Signed-off-by: Daniel Gröber <daniel@dps.uibk.ac.at> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-10-03tools: socfpga: fix sfp_verify_headerAtsushi Nemoto
Fix sfp_verify_header to return correct version number. This fixes "Not a sane SOCFPGA preloader" error message with v1 header. Signed-off-by: Atsushi Nemoto <atsushi.nemoto@sord.co.jp>
