There is a little check at the top of entry.py which decides if importlib
is available. At present this has no test coverage. To add this we will
need to import the module twice, once with importlib and once without.
In preparation for allowing a test to control the importing of this
module, remove all global imports of the 'entry' module.
Rather that overwrite this, append to it, in case the caller has already
set up the path correctly.
The tool has changed slightly since it was originally written. Update the
tests to suit.
The tests were broken by two separate commits which adjusted the output
when boards are listed. Fix this by adding back a PowerPC board and
putting the name of each board in the test.
Fixes: b9f7d881 (powerpc, 5xx: remove some "5xx" remains)
Fixes: 8d7523c5 (buildman: Allow showing the list of boards with -n)
Accessing the network slows down the test and limits the environment in
which it can be run. Add an option to disable network tests.
The checkpatch tool was updated but the patman tests were not. Fix this.
These warnings are not useful for binman tests. Disable them.
At present these tests use the same filename as patman. This adds
confusion when running all tests, since error messages look very similar.
In fact binman tries to run the wrong tests at present.
Rename the tests.
These test programs are includedd as binary files in U-Boot to avoid
having to build them (and associated toolchain differences). Instructions
on building are in the files themselves, but it seems better to provide
a Makefile which can be manually run when desired.
Add a Makefile, separate from the normal build system, to handle this.
The process is not obvious. Add a little section to explain how to move a
board to use binman.
There is a debugging option in the Makefile to allow people to figure out
which u-boot.dtsi files are used in the build. But is it not easy to use
since it only shows files it finds, not those it is looking for. Update it
and update the mention of it to the docs.
This support has been deprecated since v2017.09 due to security issues.
We now remove this support.
Prior to this commit, tools/Makefile pulls all libfdt files from
lib/libfdt.
lib/libfdt/ and scripts/dtc/libfdt have the same copies for the
followings 6 files:
fdt.c fdt_addresses.c fdt_empty_tree.c fdt_overlay.c fdt_strerr.c
fdt_sw.c
This commit changes them to #include ones from scripts/dtc/libfdt.
Unfortunately, U-Boot locally modified the following 3 files:
fdt_ro.c fdt_wip.c fdt_rw.c
I did not touch them in order to avoid unpredictable impact.
The fdt_region.c is U-Boot own file. This is also borrowed from
lib/libfdt/.
The pylibfdt is used by dtoc (and, indirectly by binman), but there
is no reason why it must be generated in the tools/ directory.
Recently, U-Boot switched over to the bundled DTC, and the directory
structure under scripts/dtc/ now mirrors the upstream DTC project.
So, scripts/dtc/pylibfdt is the best location.
I also rewrote the Makefile in a cleaner Kbuild style.
The scripts from the upstream have been moved as follows:
lib/libfdt/pylibfdt/setup.py -> scripts/dtc/pylibfdt/setup.py
lib/libfdt/pylibfdt/libfdt.i -> scripts/dtc/pylibfdt/libfdt.i_shipped
The .i_shipped is coped to .i during building because the .i must be
located in the objtree when we build it out of tree.
U-Boot bundles a patched copy of libfdt, so it's wrong to attempt to
include it <like/this>. This breaks the build for me when I have dtc
fully installed in my host -- as happened earlier tonight with
Buildroot, for example.
There are several other occurrences throughout the code where '<libfdt'
matches. I'm not modifying these because I have no clue why the
<systemwide> include style is being used -- IMHO wrongly.
Signed-off-by: Jan Kundrát <jan.kundrat@cesnet.cz>
This function is called when signing configuration nodes. Adjust
the error message.
I do not know why we do not need to show the error message in case of
ENOSPC. Remove the if-conditional that seems unnecessary.
If -K option is missing when you sign image nodes, it fails with
an unclear error message:
tools/mkimage Can't add hashes to FIT blob: -1
It is hard to figure out the cause of the failure.
In contrast, when you sign configuration nodes, -K is optional because
fit_config_process_sig() returns successfully if keydest is unset.
Probably this is a preferred behavior when you want to update FIT with
the same key; you do not have to update the public key in this case.
So, this commit changes fit_image_process_sig() to continue signing
without keydest. If ->add_verify_data() fails, show a clearer error
message, which has been borrowed from fit_config_process_sig().
The "algo_name" points to a property in a blob being edited. The
pointer becomes stale when fit_image_write_sig() inserts signatures.
Then crypto->add_verify_data() writes wrong data to the public key
destination.
The fw_env utility family has a default environment compiled in
which ties it quite strongly to the U-Boot source/config it has
been built with. Allow to display the U-Boot version it has been
built with using the -v/--version argument.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Both "conf_name" and "sig_name" point to the name of config node.
The latter should be the name of the signature node.
Last user of this option went away in commit:
fdc7718999 ("board: usb_a9263: Update to support DT and DM")
All BMP files were being treated as though they had a 40 byte header.
There are several BMP header formats consisting of additional data.
This was causing some of the header to be read as color information,
skewing the color palette.
Signed-off-by: Jon Smith <jtsmith@pdiarm.com>
fit_handle_file function does not quote input and output files while preparing
command to run DTC to convert .its to .itb. This results in a failure if input
or output files contain spaces in their names. Quote input and output files in
DTC command to avoid this failure.
Signed-off-by: Mirza, Taimoor <Taimoor_Mirza@mentor.com>
Move the % arch outside the double quote so that the missing toolchain
message is displayed correctly.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
The recent changes to these files did not completely fix the previous
issues, or introduced different (minor) issues. In cmd/gpt.c we need to
dereference str_disk_guid to be sure that malloc worked. In
cmd/nvedit.c we need to be careful that we can also fit in that leading
space when adding to the string. And in tools/fit_image.c we need to
re-work the error handling slightly in fit_import_data() so that we only
call munmap() once. We have two error paths here, one where we have an
fd to close and one where we do not. Adjust labels to match this.
Reported-by: Coverity (CID: 167366, 167367, 167370)
Coverity has found some problems with the return paths in parts of this
code. We have a case where we were going to the wrong part of the
unwind (open() failed so we cannot close the fd), a case where we were
only free()ing our buf on the error path and finally a case where we did
not munmap in the failure path.
Reported-by: Coverity (CID: 138492, 138495, 143064)
Add support for rk3128 package header in mkimage tool.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Corresponds to 375506d (File writing nit) from upstream
(https://github.com/ulfalizer/Kconfiglib).
Adds proper 'imply' support and fixes a few minor issues, one of which
previously triggered the following weird warning:
configs/taurus_defconfig: /tmp/tmpisI45S:6: warning: assignment to SPL_LDSCRIPT changes mode of containing choice from "arch/$(ARCH)/cpu/u-boot-spl.lds" to "y"
The change in 8639f69 (genconfig.py: Print defconfig next to warnings)
was reapplied.
tools/moveconfig.py previously depended on a hack that merged 'select's
with 'imply's. It was modified to look at the union of
Symbol.get_selected_symbols() and Symbol.get_implied_symbols(), which
should give the same behavior.
tools/genboardscfg.py was verified to produce identical board.cfg's
before and after the change.
Signed-off-by: Ulf Magnusson <ulfalizer@gmail.com>
In some cases, such as FreeBSD, the path to an alternative dtc needs to
be used. Rather than override the one given in the Makefile on the
command line, make this part of the build configuration.
This adds a new entry type for Intel Video BIOS Table.
Add a header that indicates that the files generated by dtoc should not be
modified.
Tested-by: Kever Yang <kever.yang@rock-chips.com>
At present dtoc has a very simplistic view of phandles. It assumes that
a property has only a single phandle with a single argument (i.e. two
cells per property).
This is not true in many cases. Enhance the implementation to scan all
phandles in a property and to use the correct number of arguments (which
can be 0, 1, 2 or more) when generating the C code. For the struct
definitions, use a struct which can hold the maximum number of arguments
used by the property.
We want to support more than one phandle argument. It makes sense to use
an array for this rather than discrete struct members. Adjust the code to
support this. Rename the member to 'arg' instead of 'id'.
When writing values from properties which contain phandles, dtoc currently
writes 8 phandles per line. Change this to write one phandle per line.
This helps reduce line length, since phandles are generally longer and may
have arguments.
Rather than naming the phandle struct according to the number of cells it
uses (e.g. struct phandle_2_cell) name it according to the number of
arguments it has (e.g. struct phandle_1_arg). This is a more intuitive
naming.
Update this function to return more detail about a property that contains
phandles. This will allow (in a future commit) more accurate handling of
these properties.
This function will need to have access to class members once we enhance it
to support multiple phandle values. In preparation for that, move it into
the class.
Now that the Fdt class can map phandles to the associated nodes, use that
instead of a separate implementation.
Add a map from phandles to nodes. This can be used by clients of the the
class instead of maintaining this themselves.
At present dtoc assumes that all 'reg' properties have both an address and
a size. For I2C devices we do not have this. Adjust dtoc to cope.
Reported-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
When using 32-bit addresses dtoc works correctly. For 64-bit addresses it
does not since it ignores the #address-cells and #size-cells properties.
Update the tool to use fdt64_t as the element type for reg properties when
either the address or size is larger than one cell. Use the correct value
so that C code can obtain the information from the device tree easily.
Alos create a new type, fdt_val_t, which is defined to either fdt32_t or
fdt64_t depending on the word size of the machine. This type corresponds
to fdt_addr_t and fdt_size_t. Unfortunately we cannot just use those types
since they are defined to phys_addr_t and phys_size_t which use
'unsigned long' in the 32-bit case, rather than 'unsigned int'.
Add tests for the four combinations of address and size values (32/32,
64/64, 32/64, 64/32). Also update existing uses for rk3399 and rk3368
which now need to use the new fdt_val_t type.
Suggested-by: Heiko Stuebner <heiko@sntech.de>
Reported-by: Kever Yang <kever.yang@rock-chips.com>
Large arrays can result in lines with hundreds or thousands of characters
which is not very editor-friendly. To avoid this, addjust the tool to
group values 8 per line.
When dealing with multi-cell values we need a type that can hold this
value. Add this and a function to process it from a list of cell values.
Tested-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
We need to be able to search back up the tree for #address-cells and
#size-cells. Record the parent of each node to make this easier.
In order to display the company's logo via the API of DM_VIDEO,
and add the logo files of both Atmel and Microchip.
Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
This section of the settings file may be missing. Handle that gracefully
rather than emitting an error.
Also update patman to write this section when a new settings file is
created.
Fixes: e11aa602 (patman: add support for omitting bouncing addresses)
Reviewed-by: Chris Packham <judge.pckham@gmail.com>
Tested-by: Bin Meng <bmeng.cn@gmail.com>
Add support for reading a list of bouncing addresses from a in-tree file
(doc/bounces) and from the ~/.patman config file. These addresses are
stripped from the Cc list.
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com <mailto:philipp.tomsich@theobroma-systems.com>>
