We mostly move config options from board header files to Kconfig,
but sometimes config defines come from CONFIG_SYS_EXTRA_OPTIONS.
Historically, CONFIG_SYS_EXTRA_OPTIONS originates in boards.cfg,
which was used as a central database of configuration prior to the
Kconfig conversion.
Now, we want to migrate to primary entries in Kconfig rather than
option list in CONFIG_SYS_EXTRA_OPTIONS, so it should be helpful to
have the tool to cleanup CONFIG_SYS_EXTRA_OPTIONS automatically.
I want to reuse this routine in the next commit.
Correct the clean-up of such defines that continue across multiple
lines, like follows:
#define CONFIG_FOO "this continues to the next line " \
"this line should be removed too" \
"this line should be removed as well"
Show code diff in color if --color option is given.
The header cleanup feature of this tool now removes empty ifdef's,
successive blank lines as well as moved option defines. So, we
want to see a little more context to check which lines were deleted.
It is true that we can see it by "git diff", but it would not work
in the --dry-run mode. So, here, this commit.
The tools/moveconfig.py has a feature to cleanup #define/#undef's
of moved config options, but I want this tool to do a better job.
For example, when we are moving CONFIG_FOO and its define is
surrounded by #ifdef ... #endif, like follows:
#ifdef CONFIG_BAR
# define CONFIG_FOO
#endif
The header cleanup will leave empty #ifdef ... #endif:
#ifdef CONFIG_BAR
#endif
Likewise, if a define line between two blank lines
<blank line>
#define CONFIG_FOO
<blank lines.
... is deleted, the result of the clean-up will be successive empty
lines, which is a coding-style violation.
It is tedious to remove left-over garbage lines manually, so I want
the tool to take care of this. The tool's job is still not perfect,
so we should check the output of the tool, but I hope our life will
be much easier with this patch.
The clean tree (make mrproper) and compilers are required when moving
config options, but not needed when we only cleanup headers.
The files in include/generated are generated during build and removed
by "make mrproper", so it has no point to touch them by this tool.
For those who just want to build a board, it is useful to see a quick hint
right at the start of the documentation. Add a few commands showing how to
download toolchains and build a board.
The current code for setting up the toolchain config always writes the new
paths to an item called 'toolchain'. This means that it will overwrite any
existing toolchain item with the same name. In practice, this means that:
buildman --fetch-arch all
will fetch all toolchains, but only the path of the final one will be added
to the config. This normally works out OK, since most toolchains are the
same version (e.g. gcc 4.9) and will be found on the same path. But it is
not correct and toolchains for archs which don't use the same version will
not function as expected.
Adjust the code to use a complete glob of the toolchain path.
It doesn't make sense to complain about missing toolchains when the
--fetch-arch option is being used. The user is presumably aware that there
is a toolchain problem and is actively correcting it by running with this
option.
Refactor the code to avoid printing this confusing message.
The function comment should say 'buildman'. Fix it.
Use colour to make it easier to see what is going on. Also print a message
before downloading a new toolchain. Mention --fetch-arch in the message that
is shown when there are no available toolchains, since this is the quickest
way to resolve the problem.
When there are no toolchains a warning is printed. But in some cases this is
confusing, such as when the user is fetching new toolchains.
Adjust the function to supress the warning in this case.
When buildman is run via a symlink, this test fails. Fix it to work the same
way as buildman itself.
If there is no ~/.buildman file, buildman currently complains and exists. To
make things a little more friendly, create an empty one automatically. This
will not allow things to be built, but --fetch-arch can be used to handle
that.
Tidy up some problems found by a recent review.
Format warnings (-Wformat) were shown in printf() calls after defining
DEBUG macro.
Update format string and explicitly cast variables to suppress all
warnings.
Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com>
Add support for rockchip rk33 series Soc like rk3368 and rk3399
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
This code does not match the fdt version in fdt.py. When dtoc is unable to
use the Python libfdt library, it uses the fallback version, which does not
widen arrays correctly.
Fix this to avoid a warning 'excess elements in array initialize' in
dt-platdata.c which happens on some platforms.
Reported-by: Tom Rini <trini@konsulko.com>
Tested-by: Tom Rini <trini@konsulko.com>
[NOTE: I took v1 of these patches in, and then v2 came out, this commit
is squashing the minor deltas from v1 -> v2 of updates to c236ebd and
2b9ec76 into this commit - trini]
- Added an additional NULL check, as suggested by Simon Glass to
fit_image_process_sig
- Re-formatted the comment blocks
Signed-off-by: Mario Six <mario.six@gdsys.cc>
[For merging the chnages from v2 back onto v1]
When signing images, we repeatedly call fit_add_file_data() with
successively increasing size values to include the keys in the DTB.
Unfortunately, if large keys are used (such as 4096 bit RSA keys), this
process fails sometimes, and mkimage needs to be called repeatedly to
integrate the keys into the DTB.
This is because fit_add_file_data actually returns the wrong error
code, and the loop terminates prematurely, instead of trying again with
a larger size value.
This patch corrects the return value and also removes a error message,
which is misleading, since we actually allow the function to fail. A
(hopefully helpful) comment is also added to explain the lack of error
message.
This is probably related to 1152a05 ("tools: Correct error handling in
fit_image_process_hash()") and the corresponding error reported here:
https://www.mail-archive.com/u-boot@lists.denx.de/msg217417.html
Try to avoid adhoc iteration of the environment. Reuse fw_getenv
to find the variables that should be printed. Only use open-coded
iteration when printing all variables.
For backwards compatibility, keep emitting a newline when
printing with value_only.
Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
forward declaration not needed when re-ordered
there are two groups of functions:
- application ready tools: fw_setenv/fw_getenv/fw_parse_script
these are used, when creating a single binary containing multiple
tools (busybox like)
- file access like: open/read/write/close
above functions are implemented on top of these. applications
can use those to modify several variables without creating a
temporary batch script file
tested with "./scripts/kernel-doc -html -v tools/env/fw_env.h"
A negative value for the offset is treated as a backwards offset for
from the end of the device/partition for block devices. This aligns
the behavior of the config file with the syntax of CONFIG_ENV_OFFSET
where the functionality has been introduced with
commit 5c088ee841f9 ("env_mmc: allow negative CONFIG_ENV_OFFSET").
Currently flash_read completes a crucial part of the environment
device configuration, the device type (mtd_type). This is rather
confusing as flash_io calls flash_read conditionally, and one might
think flash_write, which also makes use of mtd_type, gets called
before flash_read. But since flash_io is always called with O_RDONLY
first, this is not actually the case in reality.
However, it is much cleaner to complete and verify the config early
in parse_config. This also prepares the code for further extension.
Reviewed-by: Andreas Fenkart
Fix a number of typos, including:
* "compatble" -> "compatible"
* "eanbeld" -> "enabled"
* "envrionment" -> "environment"
* "FTD" -> "FDT" (for "flattened device tree")
* "ommitted" -> "omitted"
* "overriden" -> "overridden"
* "partiton" -> "partition"
* "propogate" -> "propagate"
* "resourse" -> "resource"
* "rest in piece" -> "rest in peace"
* "suport" -> "support"
* "varible" -> "variable"
Devices which use of-platdata have their own platdata. However, in many
cases the driver will have its own auto-alloced platdata, for use with the
device tree. The ofdata_to_platdata() method converts the device tree
settings to platdata.
With of-platdata we would not normally allocate the platdata since it is
provided by the U_BOOT_DEVICE() declaration. However this is inconvenient
since the of-platdata struct is closely tied to the device tree properties.
It is unlikely to exactly match the platdata needed by the driver.
In fact a useful approach is to declare platdata in the driver like this:
struct r3288_mmc_platdata {
struct dtd_rockchip_rk3288_dw_mshc of_platdata;
/* the 'normal' fields go here */
In this case we have dt_platadata available, but the normal fields are not
present, since ofdata_to_platdata() is never called. In fact driver model
doesn't allocate any space for the 'normal' fields, since it sees that there
is already platform data attached to the device.
To make this easier, adjust driver model to allocate the full size of the
struct (i.e. platdata_auto_alloc_size from the driver) and copy in the
of-platdata. This means that when the driver's bind() method is called,
the of-platdata will be present, followed by zero bytes for the empty
'normal field' portion.
A new DM_FLAG_OF_PLATDATA flag is available that indicates that the platdata
came from of-platdata. When the allocation/copy happens, the
DM_FLAG_ALLOC_PDATA flag will be set as well. The dtoc tool is updated to
output the platdata_size field, since U-Boot has no other way of knowing
the size of the of-platdata struct.
This property is not useful for of-platdata, so omit it.
When swig is not available, we can still build correctly. So make this
optional. Add a comment about how to enable this build.
Add a Python version of the libfdt library which contains enough features to
support the dtoc tool. This is only a very bare-bones implementation. It
requires the 'swig' to build.
This tool can produce C struct definitions and C platform data tables.
This is used to support the of-platdata feature.
This Python library provides a way to access the contents of the device
tree. It uses fdtget, so is inefficient for larger device tree files.
Signed-off-by: Teddy Reed <teddy.reed@gmail.com>
Reported-by: Coverity (CID: 150277)
We should not be returning -1 as an error code. This can mask a situation
where we run out of space adding things to the FIT. By returning the correct
error in this case (-ENOSPC) it can be handled by the higher-level code.
This may fix the error reported by Tom Van Deun here:
although I am not sure as I cannot actually repeat it.
Reported-by: Tom Van Deun <tom.vandeun@wapice.com>
Reviewed-by: Teddy Reed <teddy.reed@gmail.com>
The error code may provide useful information for debugging. Add it to the
error string.
Update the error-handling code for -A, -C and -O to show a list of valid
options when an invalid one is provided.
Reported-by: Vinoth Eswaran <evinoth1206@gmail.com>
The existing error code only displays image types which are claimed by a
particular U_BOOT_IMAGE_TYPE() driver. But this does not seem correct. The
mkimage tool should support all image types, so it makes sense to allow
creation of images of any type with the tool.
When an incorrect image type is provided, use generic code to display the
error.
Add a generic function which can display a list of items in any category.
This will allow displaying of images for the -A, -C, -O and -T flags. At
present only -T is supported.
The fit_write_images() function incorrectly uses the long name for the
architecture. This cannot be parsed with the FIT is read. Fix this by using
the short name instead.
This is not needed. Drop it.
There is no need to set params.fit_image_type while parsing the arguments.
It is set up later anyway.
When auto-fit is used, it is not valid to create a FIT without an image
file. Add a check for this to avoid a very confusing error message later
("Can't open (null): Bad address").
There is a special case in the code when auto-fit is used. Add a comment to
make it easier to understand why this is needed.
The default image type is supposed to be IH_TYPE_KERNEL, as set in the
'params' variable. Honour this with auto-fit also.
The following python error:
Traceback (most recent call last):
File "./tools/patman/patman", line 144, in <module>
series = patchstream.FixPatches(series, args)
File "./tools/patman/patchstream.py", line 477, in FixPatches
commit = series.commits[count]
IndexError: list index out of range
is seen when:
- 'END' is missing in those tags
- those tags are put in the last part in a commit message
- the commit is not the last commit of the series
Add testing logic to see if a new commit starts.
